Can you help me for custom permalink vanilla forum in centminmod?
Discussion in 'Forum software usage' started by Tri Wahyu Budi Utomo, Feb 4, 2016.
  1. Tri Wahyu Budi Utomo
    Tri Wahyu Budi Utomo New Member
    19
    6:06 PM
    Nginx 1.9.10
    MariaDB 10.0.x
    because, standart permalink vanilla forum make a domain.com/index.php?p=/discussions .
    i want to set this to seo friendly permalink. so. domain.com/forum/discussions/post-id/post-name. Can you help me, Please ?
  2. dorobo
    dorobo Active Member
    420
    104
    7:06 PM
    latest
    latest
  3. Tri Wahyu Budi Utomo
    19
    6:06 PM
    Nginx 1.9.10
    MariaDB 10.0.x
    thanks for help me sir, but this tutor can't try. but after I tried no change. If it is demonstrated to be acceptable to rewrite the location where the permalink?
    whether it is in/usr/local/nginx/conf/conf.d/domain.com.conf?
  4. dorobo
    420
    104
    7:06 PM
    latest
    latest
    post the content of your domain.com.conf
  5. Tri Wahyu Budi Utomo
    19
    6:06 PM
    Nginx 1.9.10
    MariaDB 10.0.x
    this is domain.conf rewrite
    what i miss it?
    #server {
    #            listen   80;
    #            server_name domain.com;
      server_name domainl.com www.domain.com;
      # ssi  on;
      # access_log /home/nginx/domains/domain.com/log/access.log combined buffer=32k;
    try_files $uri $uri/ /index.php?q=$request_uri;
      #autoindex  on;
      #autoindex_localtime on;
    #try_files              $uri $uri/ /index.php;
    location ~ \.php {
          try_files $uri =404;
          fastcgi_pass unix:/var/run/php5-fpm.sock ;
          fastcgi_index index.php;
          include fastcgi_params;
          fastcgi_split_path_info ^(.+\.php)(.*)$;
    # Forum locations
      location ~ ^forum {
          index  index.php;
          try_files $uri $uri/ @forum;
    # rewrite
      location @forum {
        #pretty urls
            rewrite ^/forum(/.*)?$ /forum/index.php?p=$1 last;
  6. dorobo
    420
    104
    7:06 PM
    latest
    latest
    try changing this
    # Forum locations
      location ~ ^forum {
          index  index.php;
    # rewrite
      location @forum {
        #pretty urls
    to this
    location /forum {
    location @forum {
    rewrite ^/forum(.+)$ /forum/index.php?p=$1 last;
    50,892
    11,794
    9:06 PM
    But from you above posted domain.com.conf, you can remove this part
    location ~ \.php {
    as it's duplicated as all nginx vhosts by default have an include file php.conf at
    which already contains the location match
  8. Tri Wahyu Budi Utomo
    19
    6:06 PM
    Nginx 1.9.10
    MariaDB 10.0.x
    Thank you... work it.... and now move at subdomain not subfolder ... thank again :)
  9. Tri Wahyu Budi Utomo
    19
    6:06 PM
    Nginx 1.9.10
    MariaDB 10.0.x
    sorry, ask again.
    After I tried the permalink can already replace, but when in the category articles, click appear 404 not found. can you help me this problem? :)
    50,892
    11,794
    9:06 PM
    what permanlink format did you use ? does it have .html extensions ?
    In other words, are you using Wordpress permalinks or Nginx rewrite rules which have urls/links with .html extensions ?
    Centmin Mod default static files include file at /usr/local/nginx/conf/staticfiles.conf handles .html files via Nginx. But by using wordpress with .html extensions you tell Nginx not to serve .html files and serve via PHP-FPM (not ideal as it reduces performance if you use permalinks with .html extensions and thus use PHP-FPM to server .html files)
    If you must use .html extension permalinks, you need to comment out the .html location context from /usr/local/nginx/conf/staticfiles.conf and restart Nginx server as illustrated below with hash # in front
    location ~* \.(3gp|gif|jpg|jpeg|png|ico|wmv|avi|asf|asx|mpg|mpeg|mp4|pls|mp3|mid|wav|swf|flv|exe|zip|tar|rar|gz|tgz|bz2|uha|7z|doc|docx|xls|xlsx|pdf|iso)$ {
    gzip_static off;
    #add_header Pragma public;
    add_header Cache-Control "public, must-revalidate, proxy-revalidate";
    access_log off;
    expires 30d;
    break;
    location ~* \.(js)$ {
    access_log off;
    expires 30d;
    break;
    location ~* \.(css)$ {
    access_log off;
    expires 30d;
    break;
    #location ~* \.(html|htm|txt)$ {
    #add_header Cache-Control "public, must-revalidate, proxy-revalidate";
    #access_log off;
    #expires 1d;
    # break;
    location ~* \.(eot|svg|ttf|woff)$ {
    access_log off;
    expires 30d;
    break;
    You can also use SSH command shortcut below to launch nano linux text editor and edit file /usr/local/nginx/conf/staticfiles.conf
    statfilesinc
  11. Tri Wahyu Budi Utomo
    19
    6:06 PM
    Nginx 1.9.10
    MariaDB 10.0.x
    not use .html extension... you can cek this forum.digitalponsel.com . content can't be open :(
    50,892
    11,794
    9:06 PM
    To troubleshoot Nginx and PHP-FPM issues you'd want to check the domain site's vhost access.log and error.log logs located within directory at /home/nginx/domains/yourdomain.com/logs. You can see a full overview at centminmod.com/configfiles.html
    FAQ item 19 has more info on all Centmin Mod relevant log files locations and how to use tail command to view a sample of the entries.
    Also post the contents of your site's nginx vhost http /usr/local/nginx/conf/conf.d/yourdomain.com.conf and/or /usr/local/nginx/conf/conf.d/yourdomain.com.ssl.conf in BBCODE CODE tags as outlined at How to use forum BBCODE code tags | Centmin Mod Community
  13. Tri Wahyu Budi Utomo
    19
    6:06 PM
    Nginx 1.9.10
    MariaDB 10.0.x
    50,892
    11,794
    9:06 PM
  15. Tri Wahyu Budi Utomo
    19
    6:06 PM
    Nginx 1.9.10
    MariaDB 10.0.x
    sorry. this is url BigDinosaur Blog
    50,892
    11,794
    9:06 PM
    oh BigDinosaur Blog if you have additional vanilla nginx settings needed then yes you need to add them
    however, never used vanilla so no idea myself
  17. Tri Wahyu Budi Utomo
    19
    6:06 PM
    Nginx 1.9.10
    MariaDB 10.0.x
    to add the settings How do I? I tried failed to hold.
    50,892
    11,794
    9:06 PM
    to edit and add them, edit your site's nginx vhost http /usr/local/nginx/conf/conf.d/yourdomain.com.conf and/or /usr/local/nginx/conf/conf.d/yourdomain.com.ssl.conf
    as to specifically what to add you might want to ask vanilla support for the correct nginx rewrite rules and then post what they say here
  19. Tri Wahyu Budi Utomo
    19
    6:06 PM
    Nginx 1.9.10
    MariaDB 10.0.x
    Ok thank you. i will try
  20. Tri Wahyu Budi Utomo
    19
    6:06 PM
    Nginx 1.9.10
    MariaDB 10.0.x
    oh yaa, can you make idea other cms forum free but support centminmod?
