Can not connect FTP on CentOS 6.8 7.2 x64
Discussion in 'Other Centmin Mod Installed software' started by Manhhailua, Jul 7, 2016.
  1. Manhhailua
    Manhhailua Member
    39
    Hanoi
    1:56 PM
    1.11.1
    10.0.x
    I successfully installed Centmin to my VPS. I started with create a domain. Everything was fine but the FTP connection, I cannot connect to Pure-FTPD using created username and password:
    IP: 45.32.xxx
    FTP Username: xxx
    Password: xxxx
    46,623
    10,585
    4:56 PM
    I wouldn't publicly post your login info ! make sure to change username and password ASAP
    • Did you let the script generate a password for you or set your own ?
    • Did you make sure to enable explicit TLS/SSL mode and enable PASV passive mode like in 1st post here.
    • Which FTP client ? As not all FTP clients support FTP explicit TLS/SSL mode only clients listed at bottom of this post.
    From 1st post here, try the pure-pw commands to display pure-ftpd user details and change the user password. Also pure-pw manual is here and http://download.pureftpd.org/pub/pure-ftpd/doc/README.Virtual-Users
    list all pure-ftpd created virtual FTP users
    pure-pw list
    pure-pw list
    ftpuser /usr/local/nginx/html/./
    ftpuser2 /usr/local/nginx/html/./
    ftpuser3 /usr/local/nginx/html/./
    ftpuser4 /home/nginx/domains/domain1.com/./
    ftpuser6 /home/nginx/domains/sub.domain1.com/./
    ftpuser5 /home/nginx/domains/domain2.com/./
    to delete virtual FTP user
    pure-pw userdel FTPUSERNAME
    pure-pw mkdb
    change virtual FTP user's password
    pure-pw passwd FTPUSERNAME
    pure-pw mkdb
    show full details for an specific pure-ftpd virtual FTP user
    pure-pw show FTPUSERNAME
    password is encrypted
    pure-pw show ftpuser5
    Login : ftpuser5
    Password : $1$msgfvdN0$51dhLdPGiCQpQEwtZ30kF1
    UID : 500 (nginx)
    GID : 500 (nginx)
    Directory : /home/nginx/domains/domain2.com/./
    Full name :
    Download bandwidth : 0 Kb (unlimited)
    Upload bandwidth : 0 Kb (unlimited)
    Max files : 0 (unlimited)
    Max size : 0 Mb (unlimited)
    Ratio : 0:0 (unlimited:unlimited)
    Allowed local IPs :
    Denied local IPs :
    Allowed client IPs :
    Denied client IPs :
    Time restrictions : 0000-0000 (unlimited)
    Max sim sessions : 0 (unlimited)
    Filezilla Example
    with transfer settings set passive mode with Host = your server ip
    Filezilla settings
    Screenshots at Nginx - How to create FTP account for an domain? | Centmin Mod Community
    output for these 2 commands where USERNAME is the pure-ftpd virtual FTP username and /home/nginx/domains/domain1.com where domain1.com is your domain listed
    pure-pw list
    pure-pw show USERNAME
    ls -lahgR /home/nginx/domains/domain1.com
    example
     pure-pw list
    user1 /home/nginx/domains/domain1.com/./
    Password listed is shown encrypted so not the actual password
    pure-pw show user1
    Login : user1
    Password : $6$Q5lI1poh5aeEIDz0$GfbOwVYB5/sagwRAVo2L21rEb4qME0BKiPRtckJ/m4mdmPqA1kpuCjp2syH56Yvn2/DQy.lH4bVgOpAD6Ff8Y0
    UID : 1000 (nginx)
    GID : 1000 (nginx)
    Directory : /home/nginx/domains/domain1.com/./
    Full name :
    Allowed local IPs :
    Denied local IPs :
    Denied client IPs :
    /home/nginx/domains/domain1.com permissions
    /home/nginx/domains/domain1.com:
    total 4.0K
    drwxr-s--- 6 nginx 56 May 24 05:14 .
    drwxr-s--- 4 nginx 45 May 24 05:14 ..
    drwxr-s--- 2 nginx 6 May 24 05:14 backup
    drwxr-s--- 2 nginx 39 May 24 05:14 log
    drwxr-s--- 2 nginx 6 May 24 05:14 private
    drwxr-s--- 2 nginx 4.0K May 24 05:14 public
    /home/nginx/domains/domain1.com/backup:
    total 0
    drwxr-s--- 2 nginx 6 May 24 05:14 .
    drwxr-s--- 6 nginx 56 May 24 05:14 ..
    /home/nginx/domains/domain1.com/log:
    total 0
    drwxr-s--- 2 nginx 39 May 24 05:14 .
    -rw-r--r-- 1 nginx 0 May 24 05:14 access.log
    -rw-r--r-- 1 nginx 0 May 24 05:14 error.log
    /home/nginx/domains/domain1.com/private:
    total 0
    /home/nginx/domains/domain1.com/public:
    total 48K
    drwxr-s--- 2 nginx 4.0K May 24 05:14 .
    -rw-r----- 1 nginx 1.6K May 24 05:14 403.html
    -rw-r----- 1 nginx 1.6K May 24 05:14 404.html
    -rw-r----- 1 nginx 2.1K May 24 05:14 500.html
    -rw-r----- 1 nginx 2.1K May 24 05:14 502.html
    -rw-r----- 1 nginx 2.2K May 24 05:14 503.html
    -rw-r----- 1 nginx 7.6K May 24 05:14 503.jpg
    -rw-r----- 1 nginx 2.1K May 24 05:14 504.html
    -rw-r----- 1 nginx 2.2K May 24 05:14 50x.html
    -rw-r----- 1 nginx 1.4K May 24 05:14 index.html
    -rw-r----- 1 nginx 1.7K May 24 05:14 maintenance.html
    also check if your ip you connect from has been banned via
    csf -g IPADDRESS
    whitelist ip if you haven't already
    csf -a IPADDRESS
    also check your pure-ftpd logged messages in /var/log/messages
    awk '/pure-ftpd:/' /var/log/messages
  3. Manhhailua
    Manhhailua Member
    39
    Hanoi
    1:56 PM
    1.11.1
    10.0.x
    I've changed the above password and reconnect. It's successful with FileZilla FTP Client but Webstorm.
    [got no idea why my image cannot display]
    I tried create a new domain with new ftp user and auto generate random password then the connection was ok with only FileZilla FTP Client. But I do want to connect successfully in Webstorm (it's my major development IDE).
  4. Manhhailua
    Manhhailua Member
    39
    Hanoi
    1:56 PM
    1.11.1
    10.0.x
    It's okay now. I have to disable TLS/SSL Encrypted Mode. Is there any risky problem caused by my action?
