[Solved] can not change "upload_max_filesize"
Discussion in 'Bug Reports' started by tonypt, Mar 3, 2017.
  1. tonypt
    tonypt New Member
    2:50 AM
    Really thanks for your help
    i have change the /etc/centminmod/php.d/a_customphp.ini
    date.timezone = UTC
    max_execution_time = 200
    short_open_tag = On
    realpath_cache_size = 1024k
    realpath_cache_ttl = 14400
    upload_max_filesize = 100M
    memory_limit = 512M
    post_max_size = 100M
    expose_php = Off
    mail.add_x_header = Off
    max_input_nesting_level = 128
    max_input_vars = 2000
    mysqlnd.net_cmd_buffer_size = 16384
    ;always_populate_raw_post_data=-1
    and change "nginx.conf"
    client_max_body_size 100m;
    last, i reboot my service
    but the php info still show me
    post_max_size 40M 40M
    upload_max_filesize 40M 40M
    anyone give me a help ,really thanks
    • CentOS Version: i.e. CentOS 6.5 64bit
    • Centmin Mod Version Installed: i.e. 123.08stable
    • Nginx Version Installed: 1.11.10
    • PHP Version Installed: i.e. 5.6.30
    • MariaDB MySQL Version Installed: i.e. 10.0.21
    • When was last time updated Centmin Mod code base ? : i.e. run centmin.sh menu option 23 submenu option 2
      Post output in CODE tags.
    55,335
    12,255
    4:50 AM
