Cache-Enabler Plugin Cache is not created or served
Discussion in 'Blogs & CMS usage' started by Chuong Luong, Oct 14, 2020.
    12,576
    6:40 PM
    You'd only need to downgrade Cache Enabler. I am looking into the process for this right now. As well as trying to convince Cache Enabler developers to either go back to 1.4.9 method or offer a choice of 1.4.9 method of query string inclusion in cache or 1.5.1 method of query string exclusion in cache at Query string cache policy · Issue #148 · keycdn/cache-enabler
    12,576
    6:40 PM
    @Chuong Luong try these SSH commands to downgrade to Cache Enabler 1.4.9 and install a plugin = block-specific-plugin-updates from Block Plugin Update to block Cache Enabler updates to 1.5.1 for now
    replace yourdomain.com in domain variable with your Wordpress domain
    domain=yourdomain.com
    wp plugin deactivate cache-enabler --allow-root --path=/home/nginx/domains/$domain/public
    wp plugin uninstall cache-enabler --allow-root --path=/home/nginx/domains/$domain/public
    wp plugin install cache-enabler --version=1.4.9 --force --activate --allow-root --path=/home/nginx/domains/$domain/public
    nprestart
    wp option update cache-enabler '{"expires":6,"clear_on_upgrade":1,"new_post":1,"new_comment":1,"update_product_stock":0,"webp":0,"compress":1,"excl_ids":"","excl_paths":"","excl_cookies":"","incl_parameters":"","minify_html":0}' --format=json --allow-root --path=/home/nginx/domains/$domain/public
    wp option patch update cache-enabler incl_parameters '/^fbclid|ref|mc_(cid|eid)|utm_(source|medium|campaign|term|content|expid)|gclid|fb_(action_ids|action_types|source)|age-verified|ao_noptimize|usqp|cn-reloaded|_ga|_ke$/' --allow-root --path=/home/nginx/domains/$domain/public
    wp option pluck cache-enabler incl_parameters --format=json --allow-root --path=/home/nginx/domains/$domain/public
    wp option get cache-enabler --format=json --path=/home/nginx/domains/$domain/public/ | jq
    wp plugin install block-specific-plugin-updates --activate --allow-root --path=/home/nginx/domains/$domain/public
    if [ "$(\wp option get bpu_update_blocked_plugins --allow-root --path=/home/nginx/domains/$domain/public >/dev/null 2>&1; echo $?)" -ne '0' ]; then wp option update bpu_update_blocked_plugins cache-enabler/cache-enabler.php --allow-root --path=/home/nginx/domains/$domain/public; else wp option add bpu_update_blocked_plugins cache-enabler/cache-enabler.php --allow-root --path=/home/nginx/domains/$domain/public; fi
    nprestart
    and also
    chown -R nginx:nginx /home/nginx/domains/$domain/public
  3. Chuong Luong
    Chuong Luong Member
    39
    3:40 PM
    My goodness, thanks for your help! The cache is working again! :D
    I run this:
    PHP:
    if [ $(wp option get bpu_update_blocked_plugins) ]; then wp option update bpu_update_blocked_plugins cache-enabler/cache-enabler.php --allow-root --path=/home/nginx/domains/$domain/public; else wp option add bpu_update_blocked_plugins cache-enabler/cache-enabler.php --allow-root --path=/home/nginx/domains/$domain/public; fi
    I get this:
    PHP:
    Error: This does not seem to be a WordPress installation.
    Pass --path=`path/to/wordpress` or run `wp core download`.
    Success: Added 'bpu_update_blocked_plugins' option.
    Is it successfull?
    12,576
    6:40 PM
    Good to hear :)
    Did you run that command in same SSH session as when you ran domain=yourdomain.com to populate your domain variable ?
    what if you run
    you can check the setting via
    should return
    12,576
    6:40 PM
    ah i see the problem my option check was missing the path updated above post but this is correct one
    12,576
    6:40 PM
  7. Chuong Luong
    Chuong Luong Member
    39
    3:40 PM
    Yep, running your edited code, return this:
    HTML:
    Success: Value passed for 'bpu_update_blocked_plugins' option is unchanged.
    I think that's a good for now. I will need to bookmark this thread and your thread, just in case :D Thank you for your help!!
    Also, I have another question:
    I am using htop to track process. What usually see is mostly php running (CPU 3-10%), while nginx rarely run (CPU 0-0.7%) even though the cache size is a few GB already. So, does cache successfully serve to visitors? I though nginx should run most of the time.
    12,576
    6:40 PM
    something for a new thread/topic but depends cache is only for guests, logged in users won't hit cache.
