PHP Build PHP with Profile-Guided Optimization for 7% speed increase?
Discussion in 'Nginx and PHP-FPM news & discussions' started by ethanpil, Oct 1, 2016.
  1. ethanpil
    ethanpil Active Member
    173
    55
    8:20 PM
    54,919
    12,240
    8:20 PM
    Nice will have to see if this can be applied to Centmin Mod source compiles :)
    this part would be hard to do when no sites are setup yet though ! but make for php recompiles
    more info PHP 7 Performance Improvements May Increase if You Optimize it to Your Application using to PGO - PHP Classes
  3. ethanpil
    173
    55
    8:20 PM
    Yes, I think simple it would be a 3 step process.
    1) Compile PHP with instrumentation.
    2) Centminmod server admin will access the websites pages and use common functions of the site to build profile.
    3) Recompile php using the generated profile
    I also think if we have many wordpress sites it would be good to automate the entire process.
    1) Install a test domain with basic wordpress
    2) Compile PHP with instrumentation.
    3) use curl to access front and backend pages of test domain
    4) Recompile php using the generated profile
    5) delete demo domain and DB
    54,919
    12,240
    8:20 PM
    might be easier if i can find out if make prof-gen survives subsequent php recompiles (i.e. make clean) as i could make it so initial first time php install compile uses make prof-gen, then let users run that php version for their sites and next time they recompile (not upgrade) the same php version via centmin.sh menu option 5, use make prof-use so it would be optimised for all sorts of already php requests/processing done.
    Will see :)
    54,919
    12,240
    8:20 PM
    more at High Performance PHP 7 | Intel® Software and interesting
    54,919
    12,240
    8:20 PM
    hmm doesn't seem to work for make prof-gen on PHP 5.6.26 so maybe PHP 7 only ?
    make prof-gen
    make: *** No rule to make target `prof-gen'.  Stop.
  7. ethanpil
    173
    55
    8:20 PM
    54,919
    12,240
    8:20 PM
    will test on PHP 7 and see
    found something useful GitHub - 01org/php_pgo_training_scripts
    * Authors:
    *   Gabriel Samoila <gabriel.c.samoila@intel.com>
    *   Bogdan Andone <bogdan.andone@intel.com>
    seems to suggest PHP 7 only !
    54,919
    12,240
    8:20 PM
  10. ethanpil
    173
    55
    8:20 PM
    I don't see in your guide how to differentiate between first and second compile. Also how can we recompile after significant changes to PHP codebase?
    54,919
    12,240
    8:20 PM
    It's all done in the same centmin.sh menu option 5 php recompile run for 1st and 2nd compilations using Intel provided training profiles for wordpress, drupal and mediawiki like PHP execution patterns GitHub - 01org/php_pgo_training_scripts
    54,919
    12,240
    8:20 PM
    I guess I could add options for users define additional php script paths to call against too. Or do it automatically just for the web root of each nginx vhost i.e. /home/nginx/domains/domain.com/public/index.php if index.php exists
  13. ethanpil
    173
    55
    8:20 PM
    FYI, if you look at the notes for the training profiles, they said its not as good as actual real world training.
    54,919
    12,240
    8:20 PM
    Hmmm. Seems from reading though it's better to use Intel provided PGO training scripts if you have more than one PHP web application on server that directing php to train against just Wordpress :) If you only had Wordpress and no other PHP scripts, then training aginst real Wordpress path would be optimal.
  15. ethanpil
    173
    55
    8:20 PM
    Should be an option to self train or not. For example, my servers 90% wordpress. Would prefer to squeeze an extra 3-4%! :)
    54,919
    12,240
    8:20 PM
    we'll see :D
    54,919
    12,240
    8:20 PM
    54,919
    12,240
    8:20 PM
