Upgrade Beta 9 does not start anymore
Discussion in 'Install & Upgrades or Pre-Install Questions' started by SeaTea, May 20, 2016.
  1. SeaTea
    SeaTea Member
    49
    13
    the Netherlands
    7:21 PM
    Nginx:1.11
    MariaDB-10
    I updated beta-9 yesterday and all worked normally then on my test-server. Today I got a warning after closing centmin that I should update image-magic via the remi repo. I thought it was updated already but I did the update anyway. After this update finished, centmin does not start anymore. It just echo's the current directory and waits forever. The menu is not showing
    I cannot see anything in logfiles and don't know where to look what's going on....
    Any idea where I should look ??
    I restored a full backup of the harddisk and it worked again, but as soon as I performed the yum update of imageMagick the same happened, centmin script does not show/start.
    How could I find out why the script does not continue and shows the menu ?
    See some screendump text below:
      New YUM Updates available for host dev.xxx.xx
      To list available YUM Updates type:
      yum list updates --disableplugin=priorities --enablerepo=remi
      To updates type:
      yum update --disableplugin=priorities --enablerepo=remi
    [root@dev ~]# yum update --disableplugin=priorities --enablerepo=remi
    Loaded plugins: fastestmirror
     * base: nl.mirror.babylon.network
     * epel: nl.mirror.babylon.network
     * extras: nl.mirror.babylon.network
     * remi: remi.mirrors.cu.be
     * rpmforge: mirror.nl.leaseweb.net
     * updates: nl.mirror.babylon.network
    Resolving Dependencies
    --> Running transaction check
    ---> Package ImageMagick-last.x86_64 0:6.9.4.1-1.el7.remi will be updated
    ---> Package ImageMagick-last.x86_64 0:6.9.4.3-1.el7.remi will be an update
    ---> Package ImageMagick-last-c++.x86_64 0:6.9.4.1-1.el7.remi will be updated
    ---> Package ImageMagick-last-c++.x86_64 0:6.9.4.3-1.el7.remi will be an update
    ---> Package ImageMagick-last-c++-devel.x86_64 0:6.9.4.1-1.el7.remi will be updated
    ---> Package ImageMagick-last-c++-devel.x86_64 0:6.9.4.3-1.el7.remi will be an update
    ---> Package ImageMagick-last-devel.x86_64 0:6.9.4.1-1.el7.remi will be updated
    ---> Package ImageMagick-last-devel.x86_64 0:6.9.4.3-1.el7.remi will be an update
    ---> Package ImageMagick-last-libs.x86_64 0:6.9.4.1-1.el7.remi will be updated
    ---> Package ImageMagick-last-libs.x86_64 0:6.9.4.3-1.el7.remi will be an update
    Dependencies Resolved
     Package        Arch                                                      Version        Repository                                               Size
    Updating:
     ImageMagick-last                                                              x86_64                                                    6.9.4.3-1.el7.remi                                                      remi                                                     69 k
     ImageMagick-last-c++                                                          x86_64                                                    6.9.4.3-1.el7.remi                                                      remi                                                    165 k
     ImageMagick-last-c++-devel                                                    x86_64                                                    6.9.4.3-1.el7.remi                                                      remi                                                    104 k
     ImageMagick-last-devel                                                        x86_64                                                    6.9.4.3-1.el7.remi                                                      remi                                                    104 k
     ImageMagick-last-libs                                                         x86_64                                                    6.9.4.3-1.el7.remi                                                      remi                                                    2.2 M
    Transaction Summary
    Upgrade  5 Packages
    Total download size: 2.6 M
    Is this ok [y/d/N]: y
    Downloading packages:
    No Presto metadata available for remi
    (1/5): ImageMagick-last-c++-6.9.4.3-1.el7.remi.x86_64.rpm        | 165 kB  00:00:00
    (2/5): ImageMagick-last-devel-6.9.4.3-1.el7.remi.x86_64.rpm        | 104 kB  00:00:00
    (3/5): ImageMagick-last-6.9.4.3-1.el7.remi.x86_64.rpm        |  69 kB  00:00:00
    (4/5): ImageMagick-last-c++-devel-6.9.4.3-1.el7.remi.x86_64.rpm        | 104 kB  00:00:00
    (5/5): ImageMagick-last-libs-6.9.4.3-1.el7.remi.x86_64.rpm        | 2.2 MB  00:00:00
    Total        5.0 MB/s | 2.6 MB  00:00:00
    Running transaction test
    Transaction test succeeded
    Running transaction
      Updating   : ImageMagick-last-libs-6.9.4.3-1.el7.remi.x86_64        1/10
      Updating   : ImageMagick-last-6.9.4.3-1.el7.remi.x86_64        2/10
      Updating   : ImageMagick-last-devel-6.9.4.3-1.el7.remi.x86_64        3/10
      Updating   : ImageMagick-last-c++-6.9.4.3-1.el7.remi.x86_64        4/10
      Updating   : ImageMagick-last-c++-devel-6.9.4.3-1.el7.remi.x86_64        5/10
      Cleanup    : ImageMagick-last-c++-devel-6.9.4.1-1.el7.remi.x86_64        6/10
      Cleanup    : ImageMagick-last-devel-6.9.4.1-1.el7.remi.x86_64        7/10
      Cleanup    : ImageMagick-last-6.9.4.1-1.el7.remi.x86_64        8/10
      Cleanup    : ImageMagick-last-c++-6.9.4.1-1.el7.remi.x86_64        9/10
      Cleanup    : ImageMagick-last-libs-6.9.4.1-1.el7.remi.x86_64        10/10
      Verifying  : ImageMagick-last-6.9.4.3-1.el7.remi.x86_64        1/10
      Verifying  : ImageMagick-last-libs-6.9.4.3-1.el7.remi.x86_64        2/10
      Verifying  : ImageMagick-last-c++-6.9.4.3-1.el7.remi.x86_64        3/10
      Verifying  : ImageMagick-last-devel-6.9.4.3-1.el7.remi.x86_64        4/10
      Verifying  : ImageMagick-last-c++-devel-6.9.4.3-1.el7.remi.x86_64        5/10
      Verifying  : ImageMagick-last-c++-devel-6.9.4.1-1.el7.remi.x86_64        6/10
      Verifying  : ImageMagick-last-6.9.4.1-1.el7.remi.x86_64        7/10
      Verifying  : ImageMagick-last-c++-6.9.4.1-1.el7.remi.x86_64        8/10
      Verifying  : ImageMagick-last-devel-6.9.4.1-1.el7.remi.x86_64        9/10
      Verifying  : ImageMagick-last-libs-6.9.4.1-1.el7.remi.x86_64        10/10
    Updated:
      ImageMagick-last.x86_64 0:6.9.4.3-1.el7.remi     ImageMagick-last-c++.x86_64 0:6.9.4.3-1.el7.remi     ImageMagick-last-c++-devel.x86_64 0:6.9.4.3-1.el7.remi     ImageMagick-last-devel.x86_64 0:6.9.4.3-1.el7.remi     ImageMagick-last-libs.x86_64 0:6.9.4.3-1.el7.remi
    Complete!
    [root@dev ~]# centmin
    /usr/local/src/centminmod ~
    ^C
    ^C
    [root@dev ~]# cd /var/log
    [root@dev log]# centmin
    /usr/local/src/centminmod /var/log
    ^C
    [root@dev log]#
    55,189
    12,251
    3:21 AM
    was a bug with tools/imagemagick-fix.sh, update 123.09beta01 code again via centmin.sh menu option 23 sub menu option 2 and try again :)
  3. SeaTea
    SeaTea Member
    49
    13
    the Netherlands
    7:21 PM
    Nginx:1.11
    MariaDB-10
    But the menu does not start, centmin does not start (see code above), how to get the menu ?
    (I could restore the yesterday backup and try to update centmin, but like to know how to solve this situation :) )
    55,189
    12,251
    3:21 AM
  5. SeaTea
    SeaTea Member
    49
    13
    the Netherlands
    7:21 PM
    Nginx:1.11
    MariaDB-10
    That worked ! Thanks :)
    btw: how to get the 'black background' code quotes like you posted above ?
    55,189
    12,251
    3:21 AM
  7. SeaTea
    SeaTea Member
    49
    13
    the Netherlands
    7:21 PM
    Nginx:1.11
    MariaDB-10
    Ah, didn't know the "codeb" tag. Thanks again (y)
    55,189
    12,251
    3:21 AM
    You're welcome :)
