PHP-FPM Double letters an issue? Do you want to use Zend OPcache prompt ?
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Jon Snow, May 28, 2019.
  1. Jon Snow
    Jon Snow Active Member
    921
    191
    3:07 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    Is this an issue when updating software with CMM? Notice the 2nd "Y".
    Do you want to use Zend OPcache [y/n] ? yy
    Sometimes my keyboard double-press the letter and I hit ENTER quickly.
    59,718
    4:07 AM
    i recently updated that Zend Opcache prompt to default to = y so you can hit enter on that line and it would be yes by default, but i realise folks maybe use to entering = y at that prompt so i made the script also detect yy, yY or YY variations as same as y so even if you do hit enter on yy it will be treated like single y :)
