Best way migrate from vps to vps 50GB
Discussion in 'System Administration' started by Max, Apr 1, 2020.
  1. Max
    Max Member
    125
    5
    5:25 PM
    Hello
    How can I best migrate 50GB Centminmod VPS 1 to 1 to a new VPS ?
    max
  2. buik
    2,037
    527
    Flanders
    6:25 PM
    That depends on the VPS provider.
    For example with Linode and Digital Ocean you can easily upgrade your VPS to a VPS with 50GB with the cloning / image tool. Afterwards extend the partition and check everything and you're done.
  3. Max
    Max Member
    125
    5
    5:25 PM
    Is from ramnode to upcloud.
  4. Max
    Max Member
    125
    5
    5:25 PM
    dd if=/dev/sda | gzip | ssh root@target 'gzip -d | dd of=/dev/sda' ?
    would that work?
  5. buik
    2,037
    527
    Flanders
    6:25 PM
  6. Max
    Max Member
    125
    5
    5:25 PM
    ah ok thanks buik
  7. Max
    Max Member
    125
    5
    5:25 PM
    55,458
    12,257
    2:25 AM
    That is usually the proper way to move data regardless of control panel at least on linux it is. You learn this way and you will be able to move data on any server even if it isn't Centmin Mod based. If you note the summary post at Upgrade - Nginx - Insight Guide - Centmin Mod Site Data Migration Guide you can practice this process without doing actual DNS updates for domain so the test new server will just be a test run which you can do over and over to practice without touching live server until you are confident in the process.
    For moving site data there's 2 general guides where the principles & steps of backing up and moving data is the same just slightly different for
    1. Moving Centmin Mod site data to another Centmin Mod server
    2. Moving cPanel/WHM site data to Centmin Mod server
    Those guides move alot more than just the site(s) in question but config files etc. You can use your own best judgement as to the config files and whether you want to move them or just use the fresh server setup Centmin Mod config files as they get auto optimised for the server Centmin Mod initially installed on.
    If your old site isn't centmin mod or cpanel/whm based, then those guides won't be 100% applicable. But the general overview of what needs moving and where everything is structured in Centmin Mod LEMP environment is worth reading up on.
    Also official site configuration files page explains the Centmin Mod structure of where the important files are so you can decide on what to backup.
