Sysadmin benchmarks problem to check the Network Speed Tests
Discussion in 'System Administration' started by adamus007p, Apr 17, 2020.
  1. adamus007p
    adamus007p Member
    254
    12:39 PM
    Hello,
    I want to make a benchmark - Network Speed Tests:
    curl -s https://raw.githubusercontent.com/masonr/yet-another-bench-script/master/yabs.sh | bash
    iperf3 Network Speed Tests (IPv4):
    Provider                  | Location (Link)           | Send Speed      | Recv Speed
    Bouygues Telecom          | Paris, FR (10G)           | busy            | busy
    Online.net                | Paris, FR (10G)           | busy            | busy
    WorldStream               | The Netherlands (10G)     | busy            | busy
    wilhelm.tel               | Hamburg, DE (10G)         | busy            | busy
    Biznet                    | Bogor, Indonesia (1G)     | busy            | busy
    Hostkey                   | Moscow, RU (1G)           | busy            | busy
    Velocity Online           | Tallahassee, FL, US (10G) | busy            | busy
    Airstream Communications  | Eau Claire, WI, US (10G)  | busy            | busy
    Hurricane Electric        | Fremont, CA, US (10G)     | busy            | busy
    how to unlock it, to make a Network Speed Tests? :)
    2. can you provide me a good script to bench network globally?
    check the connectivity
    Thank you in advance :)
  2. adamus007p
    adamus007p Member
    254
    12:39 PM
    just use?
    csf -x
    csf -e
    46,655
    10,590
    8:39 PM
    iperf uses TCP port 5001 https://www.linode.com/docs/networking/diagnostics/install-iperf-to-diagnose-network-speed-in-linux/
    So you need to open up and whitelist that port in CSF Firewall's TCP_IN and TCP_OUT comma separated list of ports in /etc/csf/csf.conf config file as per outline on official Centmin Mod site at CSF Firewall - CentminMod.com LEMP Nginx web stack for CentOS
    You can run these commands to backup CSF Firewall config and add port 5001 to your whitelist for TCP_IN and TCP_OUT
    csf --profile backup cmm-b4-iperf-whitelist
    egrep '^TCP_|^TCP6_|^UDP_|^UDP6_' /etc/csf/csf.conf
    sed -i "s/TCP_IN = \"/TCP_IN = \"5001,/g" /etc/csf/csf.conf
    sed -i "s/TCP6_IN = \"/TCP6_IN = \"5001,/g" /etc/csf/csf.conf
    sed -i "s/TCP_OUT = \"/TCP_OUT = \"5001,/g" /etc/csf/csf.conf
    sed -i "s/TCP6_OUT = \"/TCP6_OUT = \"5001,/g" /etc/csf/csf.conf
    once you edit /etc/csf/csf.conf, you need to restart CSF Firewall
    csf -ra
  4. adamus007p
    adamus007p Member
    254
    12:39 PM
  5. adamus007p
    adamus007p Member
    254
    12:39 PM
    46,655
    10,590
    8:39 PM
    You can't as you need for other end to have iperf. You can use just speedtest-cli tool sivel/speedtest-cli
    download it to /usr/local/binx/speedtest-cli
    wget -4 -O /usr/local/bin/speedtest-cli https://raw.githubusercontent.com/sivel/speedtest-cli/master/speedtest.py
    chmod +x /usr/local/bin/speedtest-cli
    help info
    speedtest-cli -h
    usage: speedtest-cli [-h] [--no-download] [--no-upload] [--single] [--bytes]
                         [--share] [--simple] [--csv]
                         [--csv-delimiter CSV_DELIMITER] [--csv-header] [--json]
                         [--list] [--server SERVER] [--exclude EXCLUDE]
                         [--mini MINI] [--source SOURCE] [--timeout TIMEOUT]
                         [--secure] [--no-pre-allocate] [--version]
    Command line interface for testing internet bandwidth using speedtest.net.
    https://github.com/sivel/speedtest-cli
    optional arguments:
      -h, --help            show this help message and exit
      --no-download         Do not perform download test
      --no-upload           Do not perform upload test
      --single              Only use a single connection instead of multiple. This
                            simulates a typical file transfer.
      --bytes               Display values in bytes instead of bits. Does not
                            affect the image generated by --share, nor output from
                            --json or --csv
      --share               Generate and provide a URL to the speedtest.net share
                            results image, not displayed with --csv
      --simple              Suppress verbose output, only show basic information
      --csv                 Suppress verbose output, only show basic information
                            in CSV format. Speeds listed in bit/s and not affected
                            by --bytes
                            Single character delimiter to use in CSV output.
                            Default ","
      --csv-header          Print CSV headers
      --json                Suppress verbose output, only show basic information
                            in JSON format. Speeds listed in bit/s and not
                            affected by --bytes
      --list                Display a list of speedtest.net servers sorted by
                            distance
      --server SERVER       Specify a server ID to test against. Can be supplied
                            multiple times
      --exclude EXCLUDE     Exclude a server from selection. Can be supplied
                            multiple times
      --mini MINI           URL of the Speedtest Mini server
      --source SOURCE       Source IP address to bind to
      --timeout TIMEOUT     HTTP timeout in seconds. Default 10
      --secure              Use HTTPS instead of HTTP when communicating with
                            speedtest.net operated servers
      --no-pre-allocate     Do not pre allocate upload data. Pre allocation is
                            enabled by default to improve upload performance. To
                            support systems with insufficient memory, use this
                            option to avoid a MemoryError
      --version             Show the version number and exit
    To test different locations use --list to find the server ID and location you want to test and use --server SERVERID to test that location. Ensuring --secure flag is used which seems to require port 8080 TCP outbound open so CSF Firewall needs to open 8080 TCP_OUT and TCP6_OUT
    csf --profile backup cmm-b4-speedtest-cli
    sed -i "s/TCP_OUT = \"/TCP_OUT = \"8080,/g" /etc/csf/csf.conf
    sed -i "s/TCP6_OUT = \"/TCP6_OUT = \"8080,/g" /etc/csf/csf.conf
    csf -ra
    Or for testing location closest to your server use below
    speedtest-cli --share --secure
    Retrieving speedtest.net configuration...
    Testing from OVH SAS (xxx.xxx.xxx.xxx)...
    Retrieving speedtest.net server list...
    Selecting best server based on ping...
    Hosted by TelKel (Laval, QC) [6.62 km]: 9.605 ms
    Testing download speed................................................................................
    Download: 583.80 Mbit/s
    Testing upload speed................................................................................................
    Upload: 240.95 Mbit/s
    Share results: http://www.speedtest.net/result/9296127556.png
  7. adamus007p
    adamus007p Member
    254
    12:39 PM
    Is there is way to check for example 50 different servers?
    46,655
    10,590
    8:39 PM
    use --list and --server id flags to run 50 different speedtest-cli tests from different locations outputted by --list
                           distance
                           multiple times
    return first 10 results from --list
    speedtest-cli --list | head -n10
    17567) Bell Canada (Laval, QC, Canada) [6.62 km]
     6835) TelKel (Laval, QC, Canada) [6.62 km]
      911) Fibrenoire Internet (Montreal, QC, Canada) [9.56 km]
    16754) Bell Mobility (Montreal, QC, Canada) [9.56 km]
     4393) TELUS (Montreal, QC, Canada) [9.56 km]
    24707) TELUS Mobility (Montreal, QC, Canada) [9.56 km]
    12100) Openface Internet (Montreal, QC, Canada) [9.56 km]
     8825) Rogers (Montreal, QC, Canada) [9.56 km]
     6689) HOTServers LLC (Montreal, QC, Canada) [9.56 km]
  9. adamus007p
    adamus007p Member
    254
    12:39 PM
    one by one? I can paste a full list?
    Is there any way to sort like from different location not from the same or choose it manually?
    46,655
    10,590
    8:39 PM
    think only one by one
    as to locations i believe list of ordered by closest geographically to your server to furthest away so would need to dig into that and find geographic location's server ids you want to test
