Bandwidth Monitoring ? Munin ?
Discussion in 'Feature Requests & Suggestions' started by nVidian, Mar 20, 2015.
  1. nVidian
    nVidian Member
    98
    2:17 PM
    1.7.9
    5.5
    Hi eva2000, how about bandwidth monitoring for every vhost ? with Munin ?
    Disk size monitoring will be sweet too.
    55,905
    12,281
    5:17 PM
    Munin is something left to end user. I wouldn't be maintaining such in Centmin Mod for now as Munin can use up alot of cpu, memory and disk resources which isn't idea for Centmin Mod which has majority of folks using it for low memory 256-512MB systems Centmin Mod Survey 2013-2014 | Centmin Mod Community
    maybe in future though :)
  3. nVidian
    nVidian Member
    98
    2:17 PM
    1.7.9
    5.5
    For me, the only issue with centminmod (or LEMP system ) is missing bandwidth & disk quota feature. Do you have any suggestion ? It doesnt has to be 'quota' feature, but monitoring will be enough so I could see which vhost/website has eat more resource.
  4. pamamolf
    4,101
    428
    10:17 AM
    Nginx-1.26.x
    Yes monitoring with Munin or any other related tool will be great but if it needs a lot of ram and cpu then is better to let us know how much Ram and Cpu needs about and give it as addon so the user can use it on high end servers :)
    55,905
    12,281
    5:17 PM
    how much resources munin needs depends on how busy your server is and what you have configured munin to track/log. Can take up gigabytes of disk space and memory and alot of cpu time and disk space for busy servers
  6. nVidian
    nVidian Member
    98
    2:17 PM
    1.7.9
    5.5
    This is small NGINX plugin : ngx_http_accounting_module Lax/ngx_http_accounting_module ยท GitHub
    Realtime netflow and status code monitor solution for nginx, need less memory and cpu than realtime log analyzing. Useful for http traffic accounting based on nginx config logic ( per-location-traffic or per-server-traffic ).
    Please consider it, :)
