Backupsy VPS SSH Key Problem
Discussion in 'System Administration' started by BoostN, Oct 3, 2014.
  1. BoostN
    BoostN Active Member
    134
    27
    8:16 PM
    1.13.6
    10.0.34
    I purchased the backupsy VPS and can't seem to get putty to connect VIA SSH with my keys. I've followed multiple tutorials to double check myself and I still can't get it to connect (Putty tells me "Server refused our key").
    Tut: How To Create SSH Keys with PuTTY to Connect to a VPS | DigitalOcean
    Any idea. I created a fresh key within puttygen and still no luck. I'm able to use the private/pub key for my digital ocean VPS's and my ServInt server with no problems.
    I've attached the ssdh_config file for reference. File permissions:
    .ssh 0700
    authorized_keys 0644
    This is not the default ssh_config file, it did not work. I made my changes based off my DO VPS in which my keys do work with..
    Thanks!
    55,802
    12,272
    11:16 AM
  3. Oktay Kilic
    Oktay Kilic New Member
    3:16 AM
    EL6 doesn't ship with the ssh key file in selinux so that is likely the issue. Try running: restorecon -R -v ~/.ssh
    Oktay
    55,802
    12,272
    11:16 AM
    Thanks for taking the time to join and reply @Oktay Kilic :)
    FYI, Centmin Mod LEMP stack disables selinux prior to Centmin Mod installation on a VPS server so probably isn't the issue.
  5. BoostN
    134
    27
    8:16 PM
    1.13.6
    10.0.34
    Which server should the private key be placed on? The backup server or the production server.
    55,802
    12,272
    11:16 AM
    private key usually would be on the server or client server that is doing the connecting from
