Axel problem on CentOS 6.8 64bit OS
Discussion in 'Bug Reports' started by rdan, Jun 21, 2016.
    1,410
    5:26 PM
    55,223
    12,253
    7:26 PM
  3. rdan
    1,410
    5:26 PM
    Thanks :D
  4. rdan
    1,410
    5:26 PM
    Installed fine now?
    55,223
    12,253
    7:26 PM
    Yup i need to update the last message to make it more clear though :)
  6. rdan
    1,410
    5:26 PM
    But for some reason on CentOS 6.8 one server it continue showing just like this until now.
    55,223
    12,253
    7:26 PM
    hmm sounds like autogen.sh in axel might have failed on centos 6.x vs centos 7.x due to maybe gettext version dependency
    will have to check but that's the theory :)
  8. rdan
    1,410
    5:26 PM
    But works fine in all CentOS 7 Server :).
    55,223
    12,253
    7:26 PM
    yup suspected as much ! CentOS 7 has newer gettext version that CentOS 6
    ./autogen.sh
    autopoint: *** The AM_GNU_GETTEXT_VERSION declaration in your configure.ac               file requires the infrastructure from gettext-0.18 but this version               is older. Please upgrade to gettext-0.18 or newer.
    autopoint: *** Stop.
    autoreconf: autopoint failed with exit status: 1
    We have a problem...
    centos 6
    rpm -qa gettext
    gettext-0.17-18.el6.x86_64
    55,223
    12,253
    7:26 PM
    updated 123.09beta01 to revert back to axel 2.6 for centos 6 and axel 2.11 for centos 7 for now
  11. arlon
    arlon Member
    95
    6
    4:26 PM
    1.13.6
    10.1
    i can't install 09beta got the following error: Latest Centos 6 64bit
    Resolving codeload.github.com... 192.30.253.120
    Connecting to codeload.github.com|192.30.253.120|:443... connected.
    Length: unspecified [application/x-gzip]
    Saving to: “axel-2.6.tar.gz”
    [ <=> ] 266,243 --.-K/s in 10s
    2016-06-21 03:15:38 (25.7 KB/s) - “axel-2.6.tar.gz” saved [266243]
    Download axel-2.6.tar.gz done.
    gzip: stdin: not in gzip format
    tar: Child returned status 1
    tar: Error is not recoverable: exiting now
    Error: axel-2.6.tar.gz extraction failed.
    55,223
    12,253
    7:26 PM
    Tried again on fresh centos os reload?
  13. rdan
    1,410
    5:26 PM
    55,223
    12,253
    7:26 PM
    looking at the github resolved ip it seems to the a specific ip 192.30.253.120 as i tried on different ip and axel-2.6.tar.gz is valid
    manually removing corrupted tar.gz files for axel and redownloading seems to work for me but for new installs will need to look into that
    manual fix works with cmds below
    AXEL_VER='2.6'
    AXEK_LINKFILE="axel-${AXEL_VER}.tar.gz"
    AXEK_LINK="https://github.com/eribertomota/axel/archive/${AXEL_VER}.tar.gz"
    AXEK_LINKGITLAB="https://gitlab.com/centminmod-github-mirror/axel/repository/archive.tar.gz?ref=${AXEL_VER}"
    AXEK_LINKLOCAL="https://centminmod.com/centminmodparts/axel/${AXEL_VER}.tar.gz"
    rm -rf /svr-setup/axel-*
    cd /svr-setup
    wget -O $AXEK_LINKFILE $AXEK_LINK
    tar xvzf axel-2.6.tar.gz
    notice different ip 192.30.252.130 for github download
    --2016-06-21 16:58:42--  https://github.com/eribertomota/axel/archive/2.6.tar.gz
    Resolving github.com (github.com)... 192.30.252.130
    Connecting to github.com (github.com)|192.30.252.130|:443... connected.
    HTTP request sent, awaiting response... 302 Found
    Location: https://codeload.github.com/eribertomota/axel/tar.gz/2.6 [following]
    --2016-06-21 16:58:42--  https://codeload.github.com/eribertomota/axel/tar.gz/2.6
    Resolving codeload.github.com (codeload.github.com)... 192.30.253.120
    Connecting to codeload.github.com (codeload.github.com)|192.30.253.120|:443... connected.
    Length: 266229 (260K) [application/x-gzip]
    Saving to: ‘axel-2.6.tar.gz’
    100%[================================================================================================================================================================================================================>] 266,229     --.-K/s   in 0.1s
    2016-06-21 16:58:42 (1.73 MB/s) - ‘axel-2.6.tar.gz’ saved [266229/266229]
    EDIT: looks end result is same ip redirect 192.30.253.120
    55,223
    12,253
    7:26 PM
    @RoldanLT try updated 123.09beta01 i added a routine to fallback to centminmod.com local mirror download if github version is corrupted
  16. rdan
    1,410
    5:26 PM
    That works fine.
  17. rdan
    1,410
    5:26 PM
    I didn't receive any error now.
    But I don't know how to re-install Axel just to be sure I have it working fine.
    55,223
    12,253
    7:26 PM
    delete the download tarball from /svr-setup it will trigger an axel update on centmin.sh launch
    cd /svr-setup
