Wordpress Autoptimize and default wpsecure include (403)
Discussion in 'Blogs & CMS usage' started by GamerJota, Jul 8, 2019.
  1. GamerJota
    GamerJota Member
    56
    7
    Chile
    5:51 PM
    Today I did a fresh Centminmod install, a new Wordpress site install and installed Autoptimize.
    It didn't work at first ending in 403 forbidden errors because Autoptimize uses .php files in "/wp-content/cache/autoptimize/" and I noticed there is not a whitelist exception by default at the "wpsecure" include created by centminmod.
    I had to add in "/usr/local/nginx/conf/wpincludes/example.com/wpsecure_example.com.conf" the following:
    # Whitelist Exception for Autoptimize
    location ~ ^/wp-content/cache/autoptimize/ {
    @eva2000 I suggest to add this by default to the whitelist exceptions.
    44,744
    10,201
    6:51 AM
    This must be something new added by Autoptimise for .php files in there so that's for the heads up ? what was the specific php filenames ? just to confirm as i did a quick check on my installs and there is no php files in that directory so far
    you can check with command below for php files in that directory - changing yourdomain.com to your domain name
    find /home/nginx/domains/yourdomain.com/public/wp-content/cache/autoptimize -type f -name "*.php"
  3. GamerJota
    GamerJota Member
    56
    7
    Chile
    5:51 PM
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_ad10cd46a043368685a36a611490d08e.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_fdd67d0316e33e8f57f8e3cbeaf5b490.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_76591f91de8e1ba757c75f2ed652aa08.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_abc35a4bde8dec6c6d73f14209355f11.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_f77808009f1eae29a6a8c846052f73c2.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_770afd24832e2d0e94a7b9c931f53a74.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_fe41a3f2e56f9b6b35fe998980929b3b.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_b544a41566826593bf1145e0c4c90d1e.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_c0753a18f5f80d711e27e808db6ea442.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_d41d8cd98f00b204e9800998ecf8427e.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_16ae5d6ed880d1c6aa79cd4c7b6d7768.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_a1ff06e5154f12492f76eed70f673334.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_622aff7c3e7445f19bbbeb6374341688.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_68825fd7eb65be21b1b63e5599cd6bfa.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_2ef91305dc6b3a23de6a67f6bb775e86.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_5bf2b216241ab5f72a7c65380b6737a4.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_d494c1f56a2d929fa48a6e70b3de5e86.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_9e3cabececb991c5a2bb5730f2efa452.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_2a7b30a980d688ca833f68bcfe2ddfa9.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_731f03c31740ee19500ea4fe74ead6b0.php
    /home/nginx/domains/example.com/public/wp-content/cache/autoptimize/autoptimize_single_0159ae675cfa1104544e2a579e024b7b.php
    Not whitelisting in wpsecure will result in getting 403 forbidden errors for those files when trying to visit the website and no javascript or styles will be rendered.
    44,744
    10,201
    6:51 AM
    those are saved when saved autoptimize settings seem to mess up for some reason, just going into autoptimize settings and on settings page hit save and clear cache to clear it out as only thing should be saved there is .css and .js files
  5. GamerJota
    GamerJota Member
    56
    7
    Chile
    5:51 PM
    I actually tried that multiple times for but for some odd reason those files are still requested by the browser even after clearing caches in the site (KeyCDN Cache Enabler) and Cloudflare, even tried in incognito mode and other browsers.
    44,744
    10,201
    6:51 AM
    tried restarting nginx + php-fpm afterwards ?
    nprestart
  7. GamerJota
    GamerJota Member
    56
    7
    Chile
    5:51 PM
    Yeah, of course, I tried it and it's still the same.
    44,744
    10,201
    6:51 AM
    what about
    1. clear keycdn cache
    2. clear autoptimize cache/save config settings
    3. disable autoptimize plugin and re-enable
  9. shevan
    shevan New Member
    13
    11:51 PM
    Nginx 15.5
    MariaDB 10
    Check out the Autoptimize FAQ
    How can I force the aggregated files to be static CSS or JS instead of PHP?
    44,744
    10,201
    6:51 AM
    yes that is meant to be checked = default
