Autoprotect nginx wrong path
Discussion in 'Bug Reports' started by pamamolf, May 27, 2016.
    4,101
    428
    8:33 AM
    Nginx-1.26.x
    Hi
    After installing Centminmod i enable from menu 23 the github update environment and i update it using the sub menu 2 :)
    The above change the path from :
    /usr/local/src/centminmod-123.09beta01
    to
    /usr/local/src/centminmod/
    but the cronjob is using the old path :
    11 */23 * * * /usr/local/src/centminmod-123.09beta01/tools/autoprotect.sh
    55,458
    12,257
    3:33 PM
    is this a update from older 123.09beta01 to latest 123.09beta01 only ?
    thanks for the heads up !
  3. pamamolf
    4,101
    428
    8:33 AM
    Nginx-1.26.x
    Just tested on a fresh installation :)
    It was already updated but i just run it to be ready for next updates so running it from latest version and not from an older version...
    55,458
    12,257
    3:33 PM
    Fixed up tools/autoprotect.sh cronjob set path with latest centmin mod 123.09beta01 updated code. Just update to latest 123.09beta01 code via centmin.sh menu option 23, submenu option 2 and then run centmin.sh once more after update code in place. The cronjob path should auto fix and you can confirm via command to list cronjobs
    crontab -l
