Automatic nightly YUM updates with yum-cron for CentOS 7 Only
Discussion in 'System Administration' started by eva2000, Sep 28, 2014.
  1. Eduardo
    Eduardo Member
    38
    6:15 AM
    1.7.9
    yes, its centminmod beta. I've removed postfix and replaced with ssmpt to use with mandrill.
    Thanks for your help :)
  2. rdan
    5:15 PM
    This one seems working for me, as I didn't update ES to 1.5.1 knowing it's updated now :D
    But I don't receive an email :/
    59,574
    12,539
    7:15 PM
    check your /var/log/maillog for your email address to see what happened around time of yum update, you can use yum history info to find the specific time yum ran
    yum history
    yum history info IDNUMBER
  4. pamamolf
    4,127
    12:15 PM
    If i just install yum-cron and edit the /etc/yum/yum-cron-hourly.conf it will run every hour?
    And if i want to run it every 30 minutes how can set it?
    59,574
    12,539
    7:15 PM
    yes for CentOS 7, it allows you to run different update_cmd settings in hourly from daily one
    daily yum-cron referenced in /etc/cron.daily/0yum-daily.cron
    cat /etc/cron.daily/0yum-daily.cron
    #!/bin/bash
    # Only run if this flag is set. The flag is created by the yum-cron init
    # script when the service is started -- this allows one to use chkconfig and
    # the standard "service stop|start" commands to enable or disable yum-cron.
    if [[ ! -f /var/lock/subsys/yum-cron ]]; then
      exit 0
    fi
    # Action!
    exec /usr/sbin/yum-cron
    hourly yum-cron referenced in /etc/cron.hourly/0yum-hourly.cron
    cat /etc/cron.hourly/0yum-hourly.cron
    #!/bin/bash
      exit 0
    fi
    # Action!
    exec /usr/sbin/yum-cron /etc/yum/yum-cron-hourly.conf
    haven't done it myself but I suppose for CentOS 7, you can copy the /etc/cron.hourly/0yum-hourly.cron file to say /root/tools/yum-custom.cron and then replace it's contents with
    #!/bin/bash
      exit 0
    fi
    exec /usr/sbin/yum-cron /etc/yum/yum-cron-custom.conf
    chmod 0700 the /root/tools/yum-custom.cron file and then setup custom cronjob for /root/tools/yum-custom.cron file
    then copy /etc/yum/yum-cron-hourly.conf to /etc/yum/yum-cron-custom.conf and edit /etc/yum/yum-cron-custom.conf accordingly
  6. pamamolf
    4,127
    12:15 PM
    On Centos 7.1 i can't find the:
    CHECK_ONLY=
    What i am doing wrong?
    I can't find it on the daily file:
    /etc/yum/yum-cron.conf
    and can't find it also at the hourly:
    59,574
    12,539
    7:15 PM
    did you even install yum-cron ?
    yum list yum-cron
  8. pamamolf
    4,127
    12:15 PM
    Yes as i can see all the rest settings:
    yum-cron.noarch                    3.4.3-125.el7.centos
    nano /etc/yum/yum-cron.conf
    [commands]
    #  What kind of update to use:
    # default                            = yum upgrade
    # security                           = yum --security upgrade
    # security-severity:Critical         = yum --sec-severity=Critical upgrade
    # minimal                            = yum --bugfix upgrade-minimal
    # minimal-security                   = yum --security upgrade-minimal
    # minimal-security-severity:Critical =  --sec-severity=Critical upgrade-minimal
    update_cmd = default
    # Whether a message should be emitted when updates are available,
    # were downloaded, or applied.
    update_messages = yes
    # Whether updates should be downloaded when they are available.
    download_updates = yes
    # Whether updates should be applied when they are available.  Note
    # that download_updates must also be yes for the update to be applied.
    apply_updates = no
    # Maximum amout of time to randomly sleep, in minutes.  The program
    # will sleep for a random amount of time between 0 and random_sleep
    # minutes before running.  This is useful for e.g. staggering the
    # times that multiple systems will access update servers.  If
    # random_sleep is 0 or negative, the program will run immediately.
    # 6*60 = 360
    random_sleep = 360
    [emitters]
    # Name to use for this system in messages that are emitted.  If
    # system_name is None, the hostname will be used.
    system_name = None
    # How to send messages.  Valid options are stdio and email.  If
    # emit_via includes stdio, messages will be sent to stdout; this is useful
    # to have cron send the messages.  If emit_via includes email, this
    # program will send email itself according to the configured options.
    # If emit_via is None or left blank, no messages will be sent.
    emit_via = stdio
    # The width, in characters, that messages that are emitted should be
    # formatted to.
    ouput_width = 80
    [commands]
    # Whether a message should emitted when updates are available.
    update_messages = no
    # Whether updates should be downloaded when they are available. Note
    # that updates_messages must also be yes for updates to be downloaded.
    download_updates = no
    # that both update_messages and download_updates must also be yes for
    # the update to be applied
    apply_updates = no
    random_sleep = 15
    [emitters]
    system_name = None
    emit_via = stdio
    # formatted to.
    ouput_width = 80
    59,574
    12,539
    7:15 PM
    oh you meant the variable CHECK__ONLY i thought you meant the files were missing.
    CentOS7 doesn't use CHECK_ONLY read the config files it's controlled by 3 variables - see apply_updates = no is the default
    [commands]
    apply_updates = no
  10. pamamolf
    4,127
    12:15 PM
    Does that mean that i must set it to yes to get the notification on my email?
    Bad english here sorry :(
    59,574
    12,539
    7:15 PM
    messages either go to stdio or email, default is stdio so for emails set emit_via = email
    emit_via = stdio
  12. pamamolf
    4,127
    12:15 PM
    And i miss also this parameter:
    YUM_PARAMETER=
    Any other related?
    59,574
    12,539
    7:15 PM
    don't believe there is an equivalent for CentOS 7 yum-cron
  14. pamamolf
    4,127
    12:15 PM
    It is useful to exclude something that you don't need :(
    Anyway, last question:
    There is no yum update as an option as yum upgrade removal of obsolete packages can be risky, as it may remove packages that i use?
    59,574
    12,539
    7:15 PM
    only way as obsolete pkgs could cause conflicts on update so either way it's a risk
    For CentOS 7, using sed replacements to enable yum-cron settings. This sets daily updates for full yum upgrades and hourly to security only updates.
        EMAIL=your@email.com
        sed -i "s|^email_to = root|email_to = ${EMAIL}|" /etc/yum/yum-cron.conf
        sed -i 's|^update_messages = no|update_messages = yes|' /etc/yum/yum-cron.conf
        sed -i 's|^download_updates = no|download_updates = yes|' /etc/yum/yum-cron.conf
        sed -i 's|^apply_updates = no|apply_updates = yes|' /etc/yum/yum-cron.conf
        sed -i 's|^emit_via = stdio|emit_via = email|' /etc/yum/yum-cron.conf
        sed -i "s|^email_to = root|email_to = ${EMAIL}|" /etc/yum/yum-cron-hourly.conf
        sed -i 's|^update_cmd = default|update_cmd = security|' /etc/yum/yum-cron-hourly.conf
        sed -i 's|^update_messages = no|update_messages = yes|' /etc/yum/yum-cron-hourly.conf
        sed -i 's|^download_updates = no|download_updates = yes|' /etc/yum/yum-cron-hourly.conf
        sed -i 's|^apply_updates = no|apply_updates = yes|' /etc/yum/yum-cron-hourly.conf
        sed -i 's|^emit_via = stdio|emit_via = email|' /etc/yum/yum-cron-hourly.conf
        egrep '^email_to|^update_messages|^download_updates|^apply_updates|^emit_via' /etc/yum/yum-cron.conf
        egrep '^email_to|^update_cmd|^update_messages|^download_updates|^apply_updates|^emit_via' /etc/yum/yum-cron-hourly.conf
        service yum-cron restart
  16. pamamolf
    4,127
    12:15 PM
    Ok this is what i did just to get a notification for updates on every hour check without downloading/installing anything:
    yum -y install yum-cron
    systemctl enable yum-cron.service
    /bin/systemctl start  yum-cron.service
    nano /etc/yum/yum-cron-hourly.conf
    apply_updates = no
    system_name = Server5
    emit_via = email
    email_to = myemail@gmail.com
    /bin/systemctl restart yum-cron.service
    And i am waiting for an email as i check manually and there are updates waiting :)
  17. pamamolf
    4,127
    12:15 PM
    Ok i set it at 00:30 about and now is 01:06 and no mail at all and running manually yum upgrade i can see updates waiting there :(
    Any ideas?
    [root@vultr ~]# grep yum.cron /var/log/cron | tail -10
    [root@vultr ~]#
    [root@vultr ~]# tail -10 /var/log/yum.log
    Sep 19 23:36:30 Installed: lshw-B.02.17-2.el7.x86_64
    Sep 20 00:09:41 Installed: hdparm-9.43-5.el7.x86_64
    Sep 26 22:23:37 Updated: python34u-setuptools-18.3.1-1.ius.centos7.noarch
    Sep 26 22:23:37 Updated: python34u-pip-7.1.2-1.ius.centos7.noarch
    Sep 26 22:23:48 Installed: fuse-libs-2.9.2-5.el7.x86_64
    Sep 26 22:23:48 Installed: libattr-devel-2.4.46-12.el7.x86_64
    Sep 26 22:23:48 Installed: libacl-devel-2.2.51-12.el7.x86_64
    Sep 26 22:23:48 Installed: fuse-devel-2.9.2-5.el7.x86_64
    Sep 26 22:23:48 Installed: lz4-devel-r131-1.el7.x86_64
    Sep 28 19:18:40 Installed: yum-cron-3.4.3-125.el7.centos.noarch
    [root@vultr ~]# ls -lahrt /var/log | grep cron
    -rw-r--r--  1 root       root  551K Sep  6 03:45 cron-20150906
    -rw-r--r--  1 root       root  629K Sep 14 03:40 cron-20150914
    -rw-r--r--  1 root       root  471K Sep 20 03:11 cron-20150920
    -rw-r--r--  1 root       root  547K Sep 27 03:35 cron-20150927
    -rw-r--r--  1 root       root  138K Sep 28 22:10 cron
    59,574
    12,539
    7:15 PM
    is yum-cron running ?
    service yum-cron start
    chkconfig yum-cron on
  19. pamamolf
    4,127
    12:15 PM
    Doesn't seem to run and i was use:
    and after editing the config i run:
    I think is the same as your commands but i run them again anyway:
    [root@vultr ~]# service yum-cron start
    Redirecting to /bin/systemctl start  yum-cron.service
    [root@vultr ~]# chkconfig yum-cron on
    Note: Forwarding request to 'systemctl enable yum-cron.service'.
    Is there any other way to check that is running ?
    59,574
    12,539
    7:15 PM
    how did you set it ?
