Email auto emails are not working
Discussion in 'Domains, DNS, Email & SSL Certificates' started by dooma, Jul 20, 2017.
  1. dooma
    dooma Active Member
    326
    34
    Cairo
    3:12 AM
    Thanks, I opened a case and it worked fine. But what do you suggest the sending limit should be?, I requested a high number of 40000 messages and 14 msgs per second but I think this too much.
    Also, Should I go out of sandbox in all regions to make sure that mails will be reached to members from different regions ?
    60,082
    12,584
    11:12 AM
    Region is only for where you setup SES smtp from which reaches all users worldwide it should be one closest to where your server is located as speed between your server and smtp server is important
    As to limit do rough calculation of emails you send and double it. 50000 and 14/s is usually the low mark that they set. I usually start at 250000 and 50/s
  3. dooma
    dooma Active Member
    326
    34
    Cairo
    3:12 AM
    hi
    why xenforo is sending all emails to inbox but blesta is sending to inbox except hotmail to "junk" ?
    thanks
    60,082
    12,584
    11:12 AM
