Auto Database Backup Script 1.0
Export and Upload your Database to Offsite location with Cron
  1. bojan horvatic
    bojan horvatic New Member
    6
    3:41 AM
    damn that was fast
    thanks mate!
    however, now I'm getting this
    Can't use an undefined value as a symbol reference at /usr/share/perl5/Net/FTP/dataconn.pm line 54.
    Hope you'll have the patience for this as well
    50,930
    11,809
    12:41 PM
    might need @Matt's input as I don't realy work much with perl heh
  3. Matt
    Matt Well-Known Member
    905
    409
    Rotherham, UK
    2:41 AM
    1.5.15
    MariaDB 10.2
    Need to see the full content of your script to see why it's not working, because line 54 is the last one of the upload script.
  4. bojan horvatic
    6
    3:41 AM
    Hi Matt
    Here it is, and thanks :)
    btw, I need it for the single database.
    #!/usr/bin/perl -w
    # Z22SE.co.uk
    # Used in conjunction with dbbackup.sh
    # Uploads current database backup, and removes files from remote location more than $old
    use Net::FTP;
    use Date::Manip;
    # FTP PARAMETERS
    $ftp_backup = 1;
    $today = UnixDate("today","%Y-%m-%d");
    $old = UnixDate("5 days ago","%Y-%m-%d");
    $ftp_host = "xxxxxxxxxxx";
    $ftp_port = "21";
    $ftp_user = "xxxxxxxxx";
    $ftp_pwd = "xxxxxxx";
    $ftp_dir = "databases";
    $dir = "/home/nginx/domains/eliterehabplacement.com/backup";
    # Array of Database Files to Upload
    @files = ("$dir/wp11571376db_6278.$today.sql.bz2");
    # Array of Old Database Files to be Deleted
    @old_files = ("wp11571376db_6278.$old.sql.bz2");
    &backup();
    # UPLOADING BACKUP TO BACKUP SERVER
    sub backup {
    if($ftp_backup == 1)
            my $ftp = Net::FTP->new($ftp_host, Port => $ftp_port, Debug => 0)
              or die "Cannot connect to server: $@";
            $ftp->login($ftp_user, $ftp_pwd)
              or die "Cannot login ", $ftp->message;
            $ftp->cwd($ftp_dir)
              or die "Can't CWD to remote FTP directory ", $ftp->message;
            $ftp->binary();
            foreach $file (@files) {
            $ftp->put($file)
              or warn "Upload failed ", $ftp->message;
            foreach $oldfile (@old_files) {
            $ftp->delete($oldfile)
               or warn "Delete failed ", $ftp->message;
            $ftp->quit();
    50,930
    11,809
    12:41 PM
  6. bojan horvatic
    6
    3:41 AM
    you are right but I'll change the pass later
    and I think only my server's IP allowed
    at least that was the idea :D
  7. Matt
    905
    409
    Rotherham, UK
    2:41 AM
    1.5.15
    MariaDB 10.2
    This might be because you are only uploading a single file, rather than an array with multiple files.
    Try this version
    #!/usr/bin/perl -w
    # Z22SE.co.uk
    use Net::FTP;
    use Date::Manip;
    # FTP PARAMETERS
    $ftp_backup = 1;
    $ftp_port = "21";
    $file = "$dir/wp11571376db_6278.$today.sql.bz2";
    $oldfile = "wp11571376db_6278.$old.sql.bz2";
    &backup();
    sub backup {
            $ftp->cwd($ftp_dir)
            $ftp->binary();
            $ftp->put($file)
            $ftp->quit();
  8. bojan horvatic
    6
    3:41 AM
    Thanks mate, I appreciate your help a lot
    Unfortunately it didn't work
    Perhaps it's something related to ovh backup thing
    got this message
  9. Matt
    905
    409
    Rotherham, UK
    2:41 AM
    1.5.15
    MariaDB 10.2
    Try changing this line:
    to
    my $ftp = Net::FTP->new($ftp_host, Port => $ftp_port, Debug => 0, Passive => 0)
    It's been a while since I last used this script.
