Wordpress authentication required
Discussion in 'Blogs & CMS usage' started by Pawel4IT, May 1, 2020.
  1. Pawel4IT
    Pawel4IT New Member
    10:35 AM
    Hi I created a wordpress with choice 22
    By accessing miosito.com/wp-login.php what credentials should I give?
    49,599
    11,388
    7:35 PM
    When you run centmin.sh menu option 22 to create a Nginx based Wordpress site, there will be at end of the process all the relevant login details provided. If you answered yes to HTTP password protect login wp-login.php then those user/password details will be at end of centmin.sh menu option 22 run. As with all centmin.sh menu options logs are automatically saved at /root/centminlogs. So at end of centmin.sh menu option 22 run it will tell you were the log was saved.
    example at /root/centminlogs/centminmod_123.09beta01.b203_120719-221749_wordpress_addvhost.log
    vhost for domain.com wordpress setup successfully
    domain.com setup info log saved at:
    You can search for all the logs via grep filter below
    ls -lahrt /root/centminlogs/ | grep '_wordpress_addvhost.log'
    or find command
    find /root/centminlogs/ -type f -name "*_wordpress_addvhost.log"
    example output
    -rw-r--r--   1 root root  21K Feb  3 22:29 centminmod_123.09beta01.b421_030220-222801_wordpress_addvhost.log
    -rw-r--r--   1 root root  26K Apr 15 21:26 centminmod_123.09beta01.b490_150420-211636_wordpress_addvhost.log
    /root/centminlogs/centminmod_123.09beta01.b421_030220-222801_wordpress_addvhost.log
    /root/centminlogs/centminmod_123.09beta01.b490_150420-211636_wordpress_addvhost.log
    To reset Wordpress wp-login.php HTTP password created by centmin.sh menu option 22 wordpress auto installer, you can use htpasswd.sh script
    vhostname=yourdomain.com
    /usr/local/nginx/conf/htpasswd.sh create /home/nginx/domains/$vhostname/htpasswd_wplogin USERNAME PASSWORD
    where, you change USERNAME to your desired username and PASSWORD to your password and change yourdomain.com to your wordpress site's domain name
    then restart nginx
    ngxrestart
    Or if you want to disable http password protection comment out both these lines
       auth_basic "Private";
       auth_basic_user_file /home/nginx/domains/demodomain.com/htpasswd_wplogin;
    like
       #auth_basic "Private";
       #auth_basic_user_file /home/nginx/domains/demodomain.com/htpasswd_wplogin;
    then restart nginx
  3. Pawel4IT
    Pawel4IT New Member
    10:35 AM
    Perfect!
    Thank you
