Install Ask everything about Centminmod
Discussion in 'Install & Upgrades or Pre-Install Questions' started by zhaosin, Aug 11, 2014.
  1. zhaosin
    zhaosin New Member
    10:58 PM
    MariaDB 5.5
    I already install centminmod ( with only last command )
    After that, i run " centmin "
    Next, i run 2 to add new domain, finish
    Next, i run 4 to update nginx-1.7.4
    Next, i run 5 to update php 5.5.15
    - But it require install Zend OpCache ( i accepted and installed )
    Next, i run 21 to update all thing it write
    - But it require install Zend OpCache, too and display PHP 5.4
    So is it ok, have error or something not ok for VPS ??
    And how to check all version of PHP, Zend OpCache, Nginx... , all thing installed in VPS ??
    55,425
    12,257
    1:58 AM
    If this is a new install, you only had to run the following to get Nginx 1.7.4 and PHP 5.5.15 + Zend Opcache
    last step menu option 21 is not needed.
    To check 3 commands in SSH to run
    nginx -V
    php -v
    php --ri 'Zend OpCache'
    Then be sure to read Getting Started guide Getting Started Guide | Centmin Mod Community
    As to checking install, you have a full install.log file as outlined in troubleshooting How to troubleshoot Centmin Mod initial install issues | Centmin Mod Community so you can see if it all installed properly as in the install.log there's a post install check list that looks like this
    * Post-Install Check List....
    Check ccache Version:
    ccache version 3.1.6
    Copyright (C) 2009-2011 Joel Rosdahl
    version.
    Check Nginx Version:
    nginx version: nginx/1.7.2
    built by gcc 4.4.7 20120313 (Red Hat 4.4.7-4) (GCC)
    TLS SNI support enabled
    configure arguments: --with-cc-opt='-I/svr-setup/staticlibssl/include -I/usr/include' --with-ld-opt='-L/svr-setup/staticlibssl/lib -Wl,-rpath -lssl -lcrypto -ldl -lz' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_flv_module --with-http_realip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.1 --add-module=../headers-more-nginx-module-0.25 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --with-http_dav_module --add-module=../nginx-dav-ext-module-0.0.3 --with-openssl=../openssl-1.0.1h --with-libatomic --with-pcre=../pcre-8.35 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.8.31.4-beta
    Check PHP-FPM Version:
    PHP 5.4.30 (cli) (built: Jun 30 2014 10:39:01)
    MariaDB-common-5.5.38-1.el6.x86_64
    MariaDB-shared-5.5.38-1.el6.x86_64
    MariaDB-compat-5.5.38-1.el6.x86_64
    MariaDB-client-5.5.38-1.el6.x86_64
    MariaDB-server-5.5.38-1.el6.x86_64
    MariaDB-devel-5.5.38-1.el6.x86_64
    memcached 1.4.20
    Check CSF Firewall Version:
    csf: v7.03 (generic)
    SIEGE 3.0.6
    Copyright (C) 2014 by Jeffrey Fulmer, et al.
    FOR A PARTICULAR PURPOSE.
    pscontrol handler
    pscontrol edit
    pscontrol on
    pscontrol off
    pscontrol statson
    pscontrol statsoff
    Check mysqlreport version:
    Check NSD Bind Version:
    NSD version 3.2.17
    Written by NLnet Labs.
    Check YUM Repo List
    Loaded plugins: downloadonly, fastestmirror, priorities
    * base: linux.mirrors.es.net
    * epel: epel.mirror.freedomvoice.com
    * extras: mirror.hmc.edu
    * rpmforge: mirror.hmc.edu
    * updates: mirror.atlanticmetro.net
    1560 packages excluded due to repository priority protections
    repo id        repo name                                             status
    base           CentOS-6 - Base                                       4,859+1,508
    epel           Extra Packages for Enterprise Linux 6 - x86_64        8,383+2,579
    extras         CentOS-6 - Extras                                              14
    mariadb        MariaDB                                                       8+1
    rpmforge       RHEL 6 - RPMforge.net - dag                           3,205+1,510
    updates        CentOS-6 - Updates                                        802+301
    repolist: 17,271
  3. zhaosin
    zhaosin New Member
    10:58 PM
    MariaDB 5.5
    Can you give full information of your VPS installed with name and version of them ?
    And after i run 4 & 5 to update new, do i need re-install order option such as 6,7,10,15,18,19,20... or order option ?
    55,425
    12,257
    1:58 AM
    Not sure I understand that question ?
    for Centmin Mod version you see that when you load centmin.sh and via file at /etc/centminmod-release
    cat /etc/centminmod-release
    1.2.3-eva2000.07
    or do you mean an overview page with all versions listed ? There currently isn't such a page available, command line can verify them all as suggested above
    No need to with .07 stable build, running menu option 4 to upgrade Nginx and option 5 to upgrade/download PHP is enough.
  5. zhaosin
    zhaosin New Member
    10:58 PM
    MariaDB 5.5
    "Not sure I understand that question ?
    for Centmin Mod version you see that when you load centmin.sh and via file at /etc/centminmod-release"
    Sorry for my bad english, mean, such as this topic -> Upgraded Linode VPS from 2GB to 4GB plan | Centmin Mod Community
    • CSF Firewall
    • Added: Elasticsearch 1.2.0
    Two that web stack already have in centminmod or not ? If not, how install them, and do any web stack you installed for this forum but you still not list in that topic ?
    55,425
    12,257
    1:58 AM
    CSF readme txt file linked at CSF Firewall - Centmin Mod - Menu based Nginx installer for CentOS servers or
    csf -v
    csf: v7.07 (generic)
    Elasticsearch is via 3rd party Axivo repo that is added to Centmin Mod .07 stable and higher for 64bit CentOS only.
    yum --enablerepo=axivo list elasticsearch -q
    Available Packages
    elasticsearch.x86_64                                                             1.3.1-1.el6                                                             axivo
    yum -y install java-1.7.0-openjdk
    yum --enablerepo=axivo install elasticsearch
  7. zhaosin
    zhaosin New Member
    10:58 PM
    MariaDB 5.5
    Do they really need for VPS ? And do anything else admin ??
    55,425
    12,257
    1:58 AM
  9. zhaosin
    zhaosin New Member
    10:58 PM
    MariaDB 5.5
    'Everything else is either in the Getting Started Guide | Centmin Mod Community or linked to within the guide'
    Can you write "it" here, my english very bad, i can't understand all things :(
    (it: mean everything else you installed for forum )
    55,425
    12,257
    1:58 AM
    That's all the basics installed that are provided with Centmin Mod, everything else is up to you and custom tailored to what you intend to use your Centmin Mod server for your site(s). I only provide the basic tools, everything else is up to you.
    I have added Bing Translator (see thread) to select pages of the official site including
  11. zhaosin
    zhaosin New Member
    10:58 PM
    MariaDB 5.5
    I already finished basic install
    Now i just need install xenforo, after i up source xenforo to VPS, next step is make database in phpmyadmin, but i can't find it anywhere :(
    55,425
    12,257
    1:58 AM
    Dedicated forum just for discussing Forum software like Xenforo Forum software usage | Centmin Mod Community With sticky thread to Centmin Mod Nginx + Forum software Guides | Centmin Mod Community and appropriate guides. The IP.Board has an example for database setup via SSH Nginx Vhost & Rewrites for IP.Board which is same for creating any MySQL database such as Xenforo.
    If you need phpmyadmin then check out phpmyadmin beta build Addon for Centmin Mod phpmyadmin.sh Addon | Centmin Mod Community
    And also another beta state Addon, mysqladmin_shell.sh at mysqladmin_shell.sh Shell based Addon | Centmin Mod Community
  13. zhaosin
    zhaosin New Member
    10:58 PM
    MariaDB 5.5
    VPS still load high with 1 RAM ( linode.com )
    My forum only have 10 members and 20 post, but CPU still load >95% -> down !!!
    So how i can do admin :(
    @eva2000
    55,425
    12,257
    1:58 AM
    how many cpu cores ?
    If you cpu has 4 cpu core/threads, then 100% = 100/4 = 25% cpu load average. Only when you reach 4x 100% = 400% are you really at 100% cpu load.
    So if you have 8 cpu threads cpu load of 1.0 = 1/8 = 0.125 cpu load. When you are at cpu load of 8.0, then you cpu load is 8/8 = 1.0 cpu load.
  15. zhaosin
    zhaosin New Member
    10:58 PM
    MariaDB 5.5
    I use a first plan in linode.com
    1 CPU core
    55,425
    12,257
    1:58 AM
  17. zhaosin
    zhaosin New Member
    10:58 PM
    MariaDB 5.5
    RAM 4 GB with 100 members, i think too much money to maintain with this data number :(
    55,425
    12,257
    1:58 AM
    Maybe try 2GB Linode VPS first ?
  19. zhaosin
    zhaosin New Member
    10:58 PM
    MariaDB 5.5
    Do you use location Fremont, CA for forum right ?
  20. zhaosin
    zhaosin New Member
    10:58 PM
    MariaDB 5.5
