Install arabic letter instead of "n"
Discussion in 'Install & Upgrades or Pre-Install Questions' started by ahmed, Apr 15, 2017.
  1. ahmed
    ahmed Member
    243
    19
    9:19 PM
    I was trying to re-install a new domian using option 22
    and by mistake I entered an arabic letter as on screenshot, however the installation completed without a problem
    the arabice letter in the screenshot is on the same button of "N"
    maybe the system considred it as "N"?
    Or something else?
    https://www.dropbox.com/s/tszy3phvfj3xot1/Screenshot 2017-04-15 01.02.31.png?dl=0
    37,305
    8,152
    5:19 AM
    That prompt looks for n or N to disable mobile/tablet caching, if it doesn't find n or N it allows mobile/tablet caching. either way the routine continues on.
