MariaDB Anyone using MariaDB 10.4.8 on live and busy site?
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by rdan, Sep 18, 2019.
    12,578
    8:16 PM
    minor version downgrades are fine to do though depends on what updates were made in 10.4.10 versus 10.4.8. MariaDB 10.4.9/10.4.10 has security and bug fixes it MariaDB 10.4.10 Release Notes including a criticial InnoDB bug which can prevent MariaDB server from starting up if it has Full Text InnoDB tables with Foreign Keys. So you'd want to be on MariaDB 10.4.10 if that situation applies to you otherwise, MariaDB MySQL server will not restart/start up.
    10.4.9
  2. negative
    negative Active Member
    415
    50
    1:16 PM
    1.9.10
    10.1.11
    10.4.8 works fine without any problem now in realtime server/websites.
    Mysql server restarting or starting without any issue.
    It didn't effected for me.
    I will think switch to never version of 10.4 family if everything is okay again (related issues with LIMIT clauses)
  3. Xon
    Xon Active Member
    173
    61
    6:16 PM
    Yeah changing optimizer_use_condition_selectivity=1 looks to have fixed things. Kinda yikes it causes such performance issues :(
    12,578
    8:16 PM
    That's a strange one if 10.4.8 works. Let us know how the next update goes for 10.4.11 :)
    Thanks for the confirmation :) I'd probably be waiting till 10.4.2x releases to revisit 10.4 myself :D
  5. negative
    415
    50
    1:16 PM
    1.9.10
    10.1.11
    These problems fixed in mariadb 10.5 ? Anyone experienced? especially @Xon
  6. Xon
    Xon Active Member
    173
    61
    6:16 PM
    While there is a MariaDB 10.4.12 which contains a bunch of optimizer bugfixes, I still need to set optimizer_use_condition_selectivity=1 for some of my add-ons
    :edit: still does it for Mariadb 10.5.1 :(
    12,578
    8:16 PM
    Thanks for the heads up. Seems like this will take quite a long time to iron out the issues ! Wonder if MySQL 8.0 is also having similar issues ?
  8. Nuno
    Nuno New Member
    11:16 AM
    Seems this was my problem too.
    FORCE INDEX was being ignored on a complex query, making it doing a full table scan, which was causing 100% CPU usage (just for that query running) and never getting results.
    optimizer_use_condition_selectivity = 1 fixed the problem.
    How are they not aware of this and how have they not reverted this yet?!?!
    12,578
    8:16 PM
    Yeah seems to be the case still. For Centmin Mod 123.09beta01 and higher at least for optional MariaDB 10.4 update, I have made optimizer_use_condition_selectivity = 1 the default for this anyway.
  10. rdan
    6:16 PM
    I have new server install with this config, but seems mysql_secure_installation isn't run.
    I can't find it on the logs also.
  11. rdan
    6:16 PM
    Why is this commented out by default @eva2000 ?
  12. Meirami
    Meirami Active Member
    154
    1:16 PM
    Same here. I ran it manually.
    12,578
    8:16 PM
    for mariadb 10.4 the routine is different but it should of run see code at centminmod/centminmod
    you can verify if it was run if there's 4 files generated
    • /root/centminlogs/mariadb10.4-check-users-before.log
    • /root/centminlogs/mariadb10.4-check-users-after.log
    • /root/.my.cnf would have been populated with mysql root password and /root/centminlogs/set-dot-my.cnf.log would of been created
    what did you run manually ? as mariadb 10.4 is different from other previous versions
    because optimizer_use_condition_selectivity=1 resolved most of the issues IIRC
  14. rdan
    6:16 PM
    This is blank file on my server.
    Yes created fine.
    I think he mean: mysql_secure_installation
  15. Meirami
    154
    1:16 PM
    Sorry. I mean that I ran mysql_secure_installation manually.
    I have empty mariadb10.4-check-users-after.log.
    Other files are created.
    I used mysql_secure_installation to remove anonymous user. And that's why I thought it didn't run, because of anon user.
    Anyway, maybe I misunderstood something...
    12,578
    8:16 PM
    From my past tests MariaDB 10.4 doesn't create an anonymous user and is more secure and the MySQL user table has actually moved, so hence why I did MariaDB 10.4 securing differently at centminmod/centminmod. See Authentication in MariaDB 10.4 — Understanding the Changes - MariaDB.org
    This is example output for mariadb10.4-check-users-after.log but can be done when you run the command on MariaDB 10.4 server
    mysql -e "select concat(user, '@', host, ' => ', json_detailed(priv)) from mysql.global_priv;"
    Don't post your output publicly on the forums as it is your mysql root and mysql user's login details. Centmin Mod makes MariaDB 10.4 use old mysql_native_password for best compatibility (see MariaDB - Interesting look at what's new in MariaDB 10.4)
    | concat(user, '@', host, ' => ', json_detailed(priv))        |
    | root@localhost => {
       "access": 1073741823,
       "plugin": "mysql_native_password",
       "authentication_string": "*A177D80C40E567CF2F14D9CD0F14E650BCF0091F",
       "auth_or":
               "plugin": "unix_socket"
       "password_last_changed": 1568844540
    | mysql@localhost => {
       "access": 18446744073709551615,
       "authentication_string": "invalid",
       "auth_or":
    See there is no anonymous user by default in MariaDB 10.4 to need removing. Only root user (which Centmin Mod enables with a root password you can see via authentication string hash of the root password) and the default mysql user (which is disabled with authentication string = invalid Authentication in MariaDB 10.4 — Understanding the Changes - MariaDB.org
    MariaDB 10.4 has drastic changes to way it usually handles authentication from previous versions etc so ensure you're familiar with them MariaDB - Interesting look at what's new in MariaDB 10.4. Otherwise, probably best to stick with MariaDB 10.3 if you're unsure.
  17. rdan
    6:16 PM
    Not on my situation.
    My new installed server with 10.4 without it, CPU load always stays 40-45%.
    Now I apply that config (5 minutes ago before I take the screenshot), CPU load is almost nothing (just below 10%):
  18. Recep Baltas
    Recep Baltas New Member
    5
    1:16 PM
    anyone using the latest stable version?
  19. negative
    415
    50
    1:16 PM
    1.9.10
    10.1.11
    version 10.4.8 still perfect for me without any problem however i'm interesting that answer if our problems fixed in 10.5.x too.
  20. buik
    2,044
    527
    Flanders
    12:16 PM
