MariaDB Anyone using MariaDB 10.4.8 on live and busy site?
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by rdan, Sep 18, 2019.
  1. Xon
    Xon Active Member
    173
    61
    3:47 PM
    I recently had a client who was using XenForo 1.5 and Post Rating. With MariaDB 10.4.x it was causing what should have been 20% CPU usage turn into 500% CPU usage (the site would then become unresponsive).
    The issue was a join had been converted into a hash join without using an index; except this was the per-post cache table. Full table scan of something with as-many rows as the posts table. Oops. Force index via patching the Post Rating add-on fixed it.
    Then I identified standard XF1 join was causing similar behaviour and had to reach for the join_cache_level=0 hammer because patching them one by one just isn't feasible.
    This isn't surprising; Wordpress basically is a very small collection of tables with almost no joins when doing SQL queries. XenForo has a vastly more complex database schema.
  2. Xon
    Xon Active Member
    173
    61
    3:47 PM
    59,999
    12,566
    5:47 PM
    Ouch that's a huge difference ! MariaDB Jira bug tracker is insightful - there's even performance regressions from in MariaDB 10.3.18 from 10.3.17 being confirmed. Sometimes I feel like I should version lock minor MariaDB version updates to prevent them updating minor versions on yum updates until there's some time past to see if there's regressions LOL
    59,999
    12,566
    5:47 PM
  5. Xon
    Xon Active Member
    173
    61
    3:47 PM
    One of my XF1 add-ons is reliably crashing an Mariadb 10.4.8 instance o_O
    The query causing explosions is this;
    PHP:
    UPDATE IGNORE xf_conversation_message
    JOIN useress_unc_queue_content batch on batch
    .batch_user_id = ? and batch.batch_content_id = xf_conversation_message.message_id
    SET user_id
    = ?, username = ?
    WHERE user_id = ? and batch.batch_rank between '0' and NULL
    This was essentially a no-op in earlier version since" $value < NULL" always returns false (and the table useress_unc_queue_content is empty as well), but the NULL is reliably causing a hard crash. Casting to int before calling the SQL query and it work.
    Except running the broken query after patching & doing the updates does work! ( that is; there are no rows with a matching user_id, so it should be short circuiting the between check)
    What the heck.
    59,999
    12,566
    5:47 PM
    @Xon so this is on a XF customer's MariaDB 10.4.8 instance not yours as you already downgraded right ?
  7. Xon
    Xon Active Member
    173
    61
    3:47 PM
    Yes, it was the same client with XF1.5 & Post Rating causing massive performance issues with MariaDB 10.4.8. Except now with hard crashes for the database with a dumb (but valid) SQL query :(
    I might see if I can distill that into a small reproducible test case and submit it; but not sure when I'll have the time.
    59,999
    12,566
    5:47 PM
    Is this still with MariaDB 10.4 and default join_cache_level = 2 or at 0 ? I vaguely recall reading about optimizer_use_condition_selectivity default changes from value of 1 in MariaDB 10.3 to value of 4 also caused crashes in MariaDB 10.4 on jira bug tracker.
  9. Xon
    Xon Active Member
    173
    61
    3:47 PM
    MariaDB 10.4 & with join_cache_level=0
    :edit: wow, optimizer_use_condition_selectivity=4 also opens up a huge can of worms with optimizer regressions.
    59,999
    12,566
    5:47 PM
    ah missed your edited post - yeah so you confirmed setting from 4 to 1 helped too ?
  11. negative
    negative Active Member
    415
    50
    10:47 AM
    1.9.10
    10.1.11
    I upgraded my mariadb 10.4.10 today (with yum updates including kernel, and restarted after upgrades) and forum index page load increased dramatically.
    Now, it looks like about 14 seconds takes the query time on forum index page.
    That slow-down effect feels only on forum index
    I've tried to disable all add-ons, caching etc. But same. Even worse.
    When i enable the debug, i see that (most query time is only that query)
    And when i look the mysql slow query logs in server, i see same queries in hundreds.
    So should i turn back to 10.3 (i don't know how it is safe without problem) or should i modify some settings like which talking above ( optimizer_use_condition_selectivity=4, join_cache_level)
    P.S: That load problem doesn't effect to guests, only for logged users.
    @Xon @eva2000
    59,999
    12,566
    5:47 PM
    Try the variables workaround if that doesn't work downgrade manually. Not sure why you'd upgrade to MariaDB 10.4 if you read this thread first ??? Or you didn't know of MariaDB 10.4 regressions before hand ?
  13. negative
    415
    50
    10:47 AM
    1.9.10
    10.1.11
    @eva2000 , You are right but yesterday my mariadb version was 10.4.8 and website runs without any problem, fast like on 10.3. (even maybe faster) But as i told you, yum update came with 10.4.10 version so we have that problem for now.
    So do you have any instructions how can downgrade mariadb version to 10.3 now on centminmod ? Thanks
    59,999
    12,566
    5:47 PM
    MariaDB doesn't officially support major version downgrades Downgrading between Major Versions of MariaDB and I wouldn't be providing free support and specific manual instructions for such either. However, other members are free to help out if they want.
    Not knowing how to safely downgrade manually can be risky as you could loose MySQL data if not done correctly. So only do it if you know what you're doing or hire someone to do it properly and hope that person you hire does it properly. You can also test the downgrade process on a test VPS the MariaDB 10.3 to 10.4 upgrade then 10.3 downgrade process with a copy of your mysql data until you get it right yourself.
    Or just try the workaround mysql variables until 10.4.x has a fix.
    Or just create a new Centmin Mod VPS server with MariaDB 10.3 and migrate/backup and restore your data from MariaDB 10.4 server to the new server. Keep the old MariaDB 10.4 server until you're satisfied that MariaDB 10.3 server data migration is 100% working.
  15. negative
    415
    50
    10:47 AM
    1.9.10
    10.1.11
    That is sadly, there are no any example instructions in here for do it.
    As i see in another websites, someone advice that backup database, uninstall mariadb 10.4 with yum-remove command and install back the mariadb 10.3 and import the data back. So it will works but we will lost the mariadb integration with centminmod completely :/
    So if i install new centminmod server with mariadb 10.3 and useing the Centmin Menu #21 what does effects?
    59,999
    12,566
    5:47 PM
    no you won't loose centmin mod integration doing this - ensure you backup /etc/my.cnf before hand too as that has centmin mod per MariaDB version group settings i.e. [mariadb-10.3] so you can have settings specific to each MariaDB major version in same /etc/my.cnf.
    centmin.sh menu option 21 still updates centmin mod as usual. Centmin Mod only installs/configures MariaDB server, once it's installed it's independent
  17. negative
    415
    50
    10:47 AM
    1.9.10
    10.1.11
    So i mean that, my way is right for you too? I think you can help in this mean anyway. :)
    1. backup my.cnf
    2. export full mysql backup
    3. yum-remove mariadb 10.4
    4. yum-install mariadb 10.3
    5. restore my.cnf
    6. import mysql backup
    59,999
    12,566
    5:47 PM
    between step 3 and 4 would generally need to make a copy of /var/lib/mysql data in say /var/lib/mysql-backup and then delete all mysql data in /var/lib/mysql data directory - hence risky as if you didn't backup your data properly = data loss
    if you are not sure test on a test VPS with a copy of your migrated data or do not do the downgrade and just wait for 10.4 yum update fix and apply workaround variables.
    I can't emphasize on the potential risk of permanent data loss if you mess up and I wouldn't be providing any free support for fixing such mess ups.
  19. negative
    415
    50
    10:47 AM
    1.9.10
    10.1.11
    Thank you for your reply @eva2000
    And what about downgrade to 10.4.8 (older version) from 10.4.10
    It is not major version so can i switch between them ?
    Because i have no problem on 10.4.8. These problems occurring on 10.4.9 and later.
    MariaDB 10.4.9 Release Notes
    I see something like that for do it here;
    MariaDB - MariaDB 10.4.9, 10.3.19 and 10.2.28, 10.1.42 and 5.5.66 Now Available
    And i check the logs what changed after last yum update, i confirm that is problem occuring 100% after 10.4.9 and above. (i was working fine on 10.4.8) so that is here;
    [21:52][root@server ~]# yum history info
    Transaction ID : 157
    Begin time     : Mon Nov 18 00:31:16 2019
    Begin rpmdb    : 851:2ef1b75dbce1dd419edec0337471d87c33c1b026
    End time       :            00:35:08 2019 (232 seconds)
    End rpmdb      : 851:78d23d333b930d4d97f7cc34889ffbc69906823e
    User           : root <root>
    Return-Code    : Success
    Command Line   : update --disableplugin=priorities --setopt=deltarpm=0 --enablerepo=remi
    Transaction performed with:
        Installed     rpm-4.11.3-40.el7.x86_64                      @base
        Installed     yum-3.4.3-163.el7.centos.noarch               @base
        Installed     yum-metadata-parser-1.1.4-10.el7.x86_64       @anaconda
        Installed     yum-plugin-fastestmirror-1.1.31-52.el7.noarch @base
        Installed     yum-plugin-versionlock-1.1.31-52.el7.noarch   @base
    Packages Altered:
        Updated MariaDB-client-10.4.8-1.el7.centos.x86_64      @mariadb
        Update                 10.4.10-1.el7.centos.x86_64     @mariadb
        Updated MariaDB-common-10.4.8-1.el7.centos.x86_64      @mariadb
        Updated MariaDB-compat-10.4.8-1.el7.centos.x86_64      @mariadb
        Updated MariaDB-devel-10.4.8-1.el7.centos.x86_64       @mariadb
        Updated MariaDB-server-10.4.8-1.el7.centos.x86_64      @mariadb
        Updated MariaDB-shared-10.4.8-1.el7.centos.x86_64      @mariadb
        Updated galera-4-26.4.2-1.rhel7.el7.centos.x86_64      @mariadb
        Update           26.4.3-1.rhel7.el7.centos.x86_64      @mariadb
  20. negative
    415
    50
    10:47 AM
    1.9.10
    10.1.11
    And Finally, i word hard and test it on duplicated centminmod + website. After confirmed the issue fixed, i applied it on real server and everything works perfect now even on mariadb 10.4.8.
    In my researches, problem occuring after mariadb 10.4.9 and above.
    Now, i switched back to 10.4.8 version in realtime, problem is fixed. Also, that downgrade was minor downgrading so i didn't dump and import database. I just edit the yum repo and yum-downgrade command :)
