Magento Anyone can help me Nginx's directives for Magento 2?
Discussion in 'Ecommerce / Shopping cart usage' started by Hai Pham, Sep 19, 2016.
  1. Hai Pham
    Hai Pham New Member
    7
    12:37 AM
    1.11.4
    MariaDB 10
    Dear all,
    In the package of Magento 2, It has a file nginx.conf.example, I want to combine this file with default settings in #2 menu of Centminmod.
    Thank you in advanced.
    Have a nice day!
    55,425
    12,257
    3:37 AM
  3. Hai Pham
    Hai Pham New Member
    7
    12:37 AM
    1.11.4
    MariaDB 10
    Thank you for your quick reply eva2000,
    This is the sample code in the nginx.conf.example. I just need SEO URL rewrite for Magento 2, but I think the sample is optimal for security and speed.
    # Magento Vars
    # set $MAGE_ROOT /path/to/magento/root;
    # set $MAGE_MODE default; # or production or developer
    # Example configuration:
    # upstream fastcgi_backend {
    #    # use tcp connection
    #    # server  127.0.0.1:9000;
    #    # or socket
    #    server   unix:/var/run/php5-fpm.sock;
    # server {
    #    listen 80;
    #    server_name mage.dev;
    #    set $MAGE_ROOT /var/www/magento2;
    #    set $MAGE_MODE developer;
    #    include /vagrant/magento2/nginx.conf.sample;
    root $MAGE_ROOT/pub;
    index index.php;
    autoindex off;
    charset off;
    add_header 'X-Content-Type-Options' 'nosniff';
    add_header 'X-XSS-Protection' '1; mode=block';
    location /setup {
        root $MAGE_ROOT;
        location ~ ^/setup/index.php {
            fastcgi_pass   fastcgi_backend;
            fastcgi_index  index.php;
            fastcgi_param  SCRIPT_FILENAME  $document_root$fastcgi_script_name;
            include        fastcgi_params;
        location ~ ^/setup/(?!pub/). {
            deny all;
        location ~ ^/setup/pub/ {
            add_header X-Frame-Options "SAMEORIGIN";
    location /update {
        root $MAGE_ROOT;
        location ~ ^/update/index.php {
            fastcgi_split_path_info ^(/update/index.php)(/.+)$;
            fastcgi_param  PATH_INFO        $fastcgi_path_info;
        # deny everything but index.php
        location ~ ^/update/(?!pub/). {
            deny all;
        location ~ ^/update/pub/ {
    location /pub {
        location ~ ^/pub/media/(downloadable|customer|import|theme_customization/.*\.xml) {
            deny all;
        alias $MAGE_ROOT/pub;
    location /static/ {
        if ($MAGE_MODE = "production") {
            expires max;
        location ~* \.(ico|jpg|jpeg|png|gif|svg|js|css|swf|eot|ttf|otf|woff|woff2)$ {
            add_header Cache-Control "public";
            expires +1y;
            if (!-f $request_filename) {
                rewrite ^/static/(version\d*/)?(.*)$ /static.php?resource=$2 last;
        location ~* \.(zip|gz|gzip|bz2|csv|xml)$ {
            add_header Cache-Control "no-store";
            expires    off;
    location /media/ {
        try_files $uri $uri/ /get.php?$args;
        location ~ ^/media/theme_customization/.*\.xml {
            deny all;
            expires +1y;
            expires    off;
    location /media/customer/ {
        deny all;
    location /media/downloadable/ {
        deny all;
    location /media/import/ {
        deny all;
    location ~ cron\.php {
        deny all;
    location ~ (index|get|static|report|404|503)\.php$ {
        try_files $uri =404;
        fastcgi_param  PHP_FLAG  "session.auto_start=off \n suhosin.session.cryptua=off";
        fastcgi_param  PHP_VALUE "memory_limit=256M \n max_execution_time=600";
        fastcgi_read_timeout 600s;
        fastcgi_connect_timeout 600s;
        fastcgi_param  MAGE_MODE $MAGE_MODE;
    55,425
    12,257
    3:37 AM
    let's see the default Centmin Mod 123.09beta01 nginx vhost generated to HTTP (non-HTTPS) for domain.com at /usr/local/nginx/conf/conf.d/domain.com.conf would look like this for starters.
    #server {
    #            listen   80;
    #            server_name domain.com;
      # ssi  on;
      access_log /home/nginx/domains/domain.com/log/access.log main_ext buffer=256k flush=60m;
      include /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf;
      # server and/or vhost site
      #autoindex  on;
      #autoindex_localtime on;
    For Magento 2 transposed settings first create a copy of Centmin Mod's default php.conf include file for magento named /usr/local/nginx/conf/php_magento.conf as you'll need it for your location context match for location ~ ^/update/index.php part
    cp -a /usr/local/nginx/conf/php.conf /usr/local/nginx/conf/php_magento.conf
    Edit /usr/local/nginx/conf/php_magento.conf and comment out with hash # in front the line for fastcgi_split_path_info
    #fastcgi_split_path_info ^(.+?\.php)(/.*)$;
    Then the new /usr/local/nginx/conf/conf.d/domain.com.conf would look like below
    #server {
    #            listen   80;
      set $MAGE_ROOT /home/nginx/domains/domain.com/public;
      charset off;
      # ssi  on;
      #include /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf;
      #root /home/nginx/domains/domain.com/public;
      #include /usr/local/nginx/conf/503include-main.conf;
    location /setup {
        root $MAGE_ROOT;
            deny all;
    location /update {
        root $MAGE_ROOT;
            include /usr/local/nginx/conf/php_magento.conf;
            deny all;
      #include /usr/local/nginx/conf/503include-only.conf;
    location /pub {
            deny all;
    location /static/ {
            expires max;
            expires +1y;
            expires    off;
    location /media/ {
            deny all;
            expires +1y;
            expires    off;
        deny all;
        deny all;
        deny all;
        deny all;
      #include /usr/local/nginx/conf/staticfiles.conf;
    Note
    • Untested and no support by me, but other members are welcome to help.
    • HTTPS/SSL is created in separate /usr/local/nginx/conf/conf.d/domain.com.ssl.conf vhost when you answer yes to self-signed ssl cert creation during centmin.sh menu option 2 runs. So with Magento over HTTPS, you would need to transpose the rewrites only to /usr/local/nginx/conf/conf.d/domain.com.ssl.conf and follow instructions as outlined for switching from self-signed SSL to paid/browser trusted SSL certificates + HTTP to HTTPS redirect instructions at Nginx Vhost & NSD DNS Setup - CentminMod.com LEMP Nginx web stack for CentOS
    • Not too familar with how MAGE_ROOT is set for Magento and for root $MAGE_ROOT/pub; so leave that for you to figure out.
    • All the example .php location matches for fastcgi php are replaced with Centmin Mod default include /usr/local/nginx/conf/php.conf file and include /usr/local/nginx/conf/php_magento.conf file to process php.
    • Commented out Centmin Mod default added /usr/local/nginx/conf/staticfiles.conf includes file as Magento rules seem to have taken care of static file serving in a particular way
    • Changed the top level root definition from Centmin Mod default (commented out) to Magento 2 method
      which is defined by set variable further up
  5. Hai Pham
    Hai Pham New Member
    7
    12:37 AM
    1.11.4
    MariaDB 10
    Thank you very much eva2000. You are the best Linux System Admin I have ever seen. I will try and reply a feedback for your instruction.
    55,425
    12,257
    3:37 AM
    You're welcome... basically it's just pattern matching between magento example and Centmin Mod Nginx vhost generated defaults :)
  7. Hai Pham
    Hai Pham New Member
    7
    12:37 AM
    1.11.4
    MariaDB 10
    Dear Eva,
    Thank you for your editing, after installing I can not access admin, it said 404.
    I run nginx -t and receive 2 warning:
    nginx: [warn] conflicting server name "vinahc.com" on 0.0.0.0:80, ignored
    nginx: [warn] conflicting server name "vinahc.com" on 0.0.0.0:443, ignored
    How do I resolve conflict? and access admin panel, the hompage also break. You can check via Home Page
  8. Hai Pham
    Hai Pham New Member
    7
    12:37 AM
    1.11.4
    MariaDB 10
    I have fixed nginx's warning. I have named Hostname same as the domain I used. The virtual.conf and phpadmin_ssl.conf have server_name Hostname, just change it to localhost.
    55,425
    12,257
    3:37 AM
  10. cloud9
    cloud9 Premium Member Premium Member
    435
    118
    England
    6:37 PM
    1.25.3
    10.6.x
    @Hai Pham See here and help support Centminmod (yep, Eva is great :))
  11. nqservices
    nqservices Member
    70
    14
    6:37 PM
    Hi @Hai Pham
    I will also start testing CentminMOD with Magento latest version 2.1.2. About the nginx setup described on this thread, is it working for you? Or did you make any changes?
    Do you mind telling me from your experience any special change or setting to change in CentminMOD in order to work perfect with Magento 2?
  12. Hai Pham
    Hai Pham New Member
    7
    12:37 AM
    1.11.4
    MariaDB 10
    Dear nqservices,
    I setup Magento 2 with the configuration of eva2000, it works.
    I don't edit anything in the Nginx configuration file which is eva2000 gave to me.
  13. nqservices
    nqservices Member
    70
    14
    6:37 PM
    Hi @Hai Pham
    Thanks for the information. I will try that.
    Now in terms of Magento 2 performance, how is your store? Is it fast running with CentminMOD?
