SSL Cloudflare Almalinux Cloudflare SSL issue
Discussion in 'Domains, DNS, Email & SSL Certificates' started by fly, Mar 7, 2024.
  1. fly
    fly Member
    109
    16
    4:41 AM
    @eva2000 I'm not sure this warrants a whole thread because I think I'm missing something completely obvious...
    I just built an Alma 8 server and freshly installed Centmin 130. Everything works fine (other than a self signed cert error) when going directly to the server. Once I turn on the Cloudflare DNS proxy, it says the origin server timed out. I'm running Cloudflare SSL as Full not Strict, so it shouldn't care about the self signed cert. But that's not even the error anyway.
    What dumb thing did I miss?
    52,767
    12,078
    6:41 PM
    How was Nginx HTTPS vhost created? centmin.sh menu option 2, 22 or nv command line? Try testing Centmin Mod Nginx origin curl header check response by bypassing Cloudflare CDN proxy using
    domain=yourdomain.com
    curl -Ikv --resolve $domain:443:SERVER_IP https://$domain
    and
    domain=www.yourdomain.com
    where yourdomain.com is your domain and SERVER_IP is real server IP address
  3. fly
    fly Member
    109
    16
    4:41 AM
    It was created with option 2.
    Its a subdomain, so I only ran the first of your commands, but they timed out.
    52,767
    12,078
    6:41 PM
    is CSF Firewall and LFD services running and nginx/php-fpm?
    systemctl status csf lfd nginx php-fpm --no-pager | sed -e "s|$HOSTNAME|hostname|g"
    what if you restart the services
    systemctl restart csf lfd nginx php-fpm
    check nginx config
    nginx -t
  5. fly
    fly Member
    109
    16
    4:41 AM
    All those were running. Restart didn't help. And nginx -t just gives me this warning:
    nginx: [warn] the "listen ... http2" directive is deprecated
    Just to reiterate, everything is working - until I turn on the Cloudflare proxy.
    52,767
    12,078
    6:41 PM
    That's normal as it's just a warning. I take it you only running Nginx version built from initial Centmin Mod install? The next time you run centmin.sh menu option 4 recompile for Nginx 1.25.4 or higher, it will automatically take care of existing Nginx vhosts with older http2 parameter in listen directive and convert to using http2 directive standalone.
    Maybe CSF Firewall on your server has accidentally blocked Cloudflare IP addresses? You can check if you have Cloudflare whitelisted IP ranges that Centmin Mod setup in /etc/csf/csf.allow
    grep -i cloudflare /etc/csf/csf.allow
    See if any Cloudflare IPs are blocked in /etc/csf/csf.deny
    Who's the web host? Do they also have a separate Firewall in front of the Centmin Mod based server? i.e. AWS EC2, Azure etc might have their own Firewall in front too.
  7. fly
    fly Member
    109
    16
    4:41 AM
    I see the CF IPs in allow, and just what seems to be default stuff in deny (mostly shodan).
    It's an EC2 instance with a security group...
    oh my god. I did indeed miss something dumb. I reused a security group that only allowed 80/443 in through a load balancer that I'm not using for this instance.
    *slinks away slowly*
    52,767
    12,078
    6:41 PM
    :LOL: at least you figured it out relatively quickly :)
