Master Branch allow adjusting PHP-FPM FPM_MAX_SPAWN_RATE in 123.09beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Mar 31, 2021.
    46,426
    10,551
    6:52 AM
    - optionally allow end users to alter and adjust the PHP-FPM hardcoded FPM_MAX_SPAWN_RATE from default value of 32 max which limits how many additional dynamic PHP-FPM child processes can be spawned every 1 second. This means if you have set PHP-FPM process manager away from Centmin Mod default of pm = ondemand to pm = dynamic in /usr/local/etc/php-fpm.conf so you dynamically spawn PHP-FPM child processes, then it would take 30 seconds total to spawn 920 PHP-FPM child processes accounting for 2x spawn algorithm growth factor. So 1 second 8 additional PHP-FPM child processes spawned, then 2 seconds, 16 additional PHP-FPM child processes spawned, 3 seconds, 32 additional PHP-FPM child processes spawned, 4th second, 32 additional PHP-FPM child processes spawned - all the way to 30 seconds where 920 additional PHP-FPM child processes are spawned.
    - for PHP versions 8.0.x and below, to adjust the hardcoded FPM_MAX_SPAWN_RATE from default value of 32, you can set in persistent config file /etc/centminmod/custom_config.inc the variable FPM_MAX_SPAWN_RATE='64' to raise max value from 32 to 64 before running centmin.sh menu option 5 PHP recompilation/upgrades.
    - PHP 8.1.x development versions will not need this adjustment as PHP 8.1.x added a PHP-FPM config variable to adjust this, pm.max_spawn_rate in /usr/local/etc/php-fpm.conf. Centmin Mod 123.09beta01 currently doesn't support or has been tested with PHP 8.1.x dev versions as yet.
    - FPM_MAX_SPAWN_RATE generally won't need adjusting for most users considering it is used only for non-default Centmin Mod PHP-FPM pm = dynamic mode and you'd need alot of high traffic PHP-FPM requests and alot of cpu threads and server memory availability to handle the larger spawn rate effectively.
