Wordpress After Wordpress installation using Option 22, What's next?
Discussion in 'Blogs & CMS usage' started by quicksalad, Feb 10, 2016.
  1. quicksalad
    quicksalad Member
    228
    13
    7:10 PM
    Im done on Wordpress installation, how to access its menu?
    I don't have a domain name yet. Can I still access Wordpress menu?
    Thanks and apology for noob questions.
    55,811
    12,272
    11:40 PM
    Just setup the domains you want via centmin.sh menu option 22 i.e. newdomain.com
    If you want to preview newdomain.com on new centminmod server without updating DNS, on Windows PC edit your windows HOSTS file at c:\Windows\System32\Drivers\etc\hosts (see guide at Modify your hosts file | Knowledge Center | Rackspace Hosting or install Hostman app HostsMan - abelhadigital.com which can manage the file too and allows easy dns flushing when you make changes to the hosts file.
    c:\Windows\System32\Drivers\etc\hosts contents to preview without DNS update
    centminmodserver-ip-address newdomain.com
    to disable preview comment it out and flush dns for your system
    #centminmodserver-ip-address newdomain.com
    Hostsman app to flush dns and edit the c:\Windows\System32\Drivers\etc\hosts file
  3. quicksalad
    quicksalad Member
    228
    13
    7:10 PM
    Thank you for your prompt support @eva2000
  4. quicksalad
    quicksalad Member
    228
    13
    7:10 PM
    is it okay to install or input "y" for self certificate during Wordpress install setup? I didn't see this option on the Youtube video you created. Thanks
    55,811
    12,272
    11:40 PM
    it's new in 123.08stable and higher see Nginx Vhost & NSD DNS Setup - CentminMod.com LEMP Nginx web stack for CentOS
    when you answer yes centmin mod will auto generate a 2nd domain.com.ssl.conf vhost config file with all the ssl syntax and settings in place and generate a self-signed ssl certificate in it's place, you can then use the generated csr file to obtain a paid ssl certificate and concat your paid ssl certs as outlined at Nginx Vhost & NSD DNS Setup - CentminMod.com LEMP Nginx web stack for CentOS or you can disable ssl vhost by renaming file to domain.ssl.conf-disabled and save it for future use
  6. quicksalad
    quicksalad Member
    228
    13
    7:10 PM
    I assume that after running option 22 to install Wordpress, I don't need to add Nginx Vhost anymore?
    55,811
    12,272
    11:40 PM
  8. quicksalad
    quicksalad Member
    228
    13
    7:10 PM
    that was so fast, hopefully I didn't miss any config.
    Am I ready to start blogging?
    I'm trying to access /wp-admin but username and password isn't working.
    I use below details provided after install.
    Wordpress domain: mydomain.com
    Wordpress DB Name: wxxxxxxxxxxxx
    Wordpress DB User: wxxxxxxxxxxxxx
    Wordpress DB Pass: wxxxxxxxxxxxxxx
    Wordpress Admin User ID: 2xxxxxx
    Wordpress Admin User: vxxxxxxxxxxxxxxxxxxxxxxxx
    Wordpress Admin Pass: vxxxxxxxxxxxxxxxxxxxxxxxx
    Wordpress Admin Email: mydomain@gmail.com
    Please advise. Thanks
    55,811
    12,272
    11:40 PM
    should be
    but login issue could be with copy and paste, try highlight and copy and paste the logins and not double click on the logins that some ssh clients allow
    also could be a bug in generated passwords having characters in their that wp doesnt support.
    what's the password and username actually ?
    you can uninstall via uninstall script it auto generates too
    /root/tools/wp_uninstall_newdomain2.com.sh where newdomain2.com is your wordpress vhost domain name which allows you then to re-rin centmin.sh menu option 22 again
    is this on centmin 123.08stable or 123.09beta01
  10. quicksalad
    quicksalad Member
    228
    13
    7:10 PM
  11. quicksalad
    quicksalad Member
    228
    13
    7:10 PM
    with the URL above I'm able to login successfully but here's the screenshot on login screen. It's different on my first screenshot attached.
  12. quicksalad
    quicksalad Member
    228
    13
    7:10 PM
    I'm using 123.08stable.
    Was that private Key prompt triggered by htpasswd_wplogin?
    55,811
    12,272
    11:40 PM
    it would be in the output at end of centmin.sh menu option 22 run
    every centmin.sh menu option logs full output to a log file of it's own in /root/centminlogs so you can find that info there too as well as in wp email you setup would of sent you an email
    55,811
    12,272
    11:40 PM
    yup :)
  15. quicksalad
    quicksalad Member
    228
    13
    7:10 PM
    @eva2000 Thanks
    I realized that first login prompt in mydomain.com/wp-admin
    uses the details:
    Wordpress wp-login.php password protection info:
    wp-login.php protection file /home/nginx/domains/mydomain.com/htpasswd_wplogin
    wp-login.php protection Username: vxxdsdfsdfxcsdfesdfsxxxx
    wp-login.php protection Password: cgfsgfsfrsefsefsefesxxx
    http://xv3dfdfsgegsesdXXXXXXXXXXDsdXXX@mydomain.com/wp-login.php
    2nd login prompt details uses:
    This is the Wordpress login credentials
    The details above was generated after install on Option 22.
    55,811
    12,272
    11:40 PM
    yes that's correct :)
  17. quicksalad
    quicksalad Member
    228
    13
    7:10 PM
    55,811
    12,272
    11:40 PM
    see official site instructions Nginx Vhost & NSD DNS Setup - CentminMod.com LEMP Nginx web stack for CentOS and post in CODE tags your domain.com.conf and domain.com.ssl.conf vhost config files
    When you create a new nginx vhost domain via centmin.sh menu option 2 or 22 or /usr/bin/nv cli command line, you will create the Nginx vhost files and directories. You will get an outputted the path location where it will create the domain name's vhost conf file named newdomain.com.conf (and newdomain.com.ssl.conf if you selected yes to self signed SSL)
    Please post the contents of /usr/local/nginx/conf/conf.d/newdomain.com.conf and if applicable /usr/local/nginx/conf/conf.d/newdomain.com.ssl.conf wrapped in CODE tags (outlined at How to use forum BBCODE code tags | Centmin Mod Community
  19. quicksalad
    quicksalad Member
    228
    13
    7:10 PM
    # For SPDY SSL Setup
    # server {
    #   server_name mydomain.com www.mydomain.com;
    #    return 302 https://$server_name$request_uri;
      listen 443 ssl http2;
      ssl_dhparam /usr/local/nginx/conf/ssl/mydomain.com/dhparam.pem;
      ssl_certificate      /usr/local/nginx/conf/ssl/mydomain.com/mydomain.com.crt;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/mydomain.com/mydomain.com.key;
      # mozilla recommended
      ssl_ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!CAMELLIA:!DES-CBC3-SHA;
      #spdy_headers_comp 5;
      ssl_buffer_size 1400;
      ssl_session_tickets on;
      # enable ocsp stapling
      #resolver_timeout 10s;
      #ssl_stapling on;
      #ssl_stapling_verify on;
      #ssl_trusted_certificate /usr/local/nginx/conf/ssl/mydomain.com/mydomain.com-trusted.crt;
      # ssi  on;
      access_log /home/nginx/domains/mydomain.com/log/access.log combined buffer=256k flush=60m;
      error_log /home/nginx/domains/mydomain.com/log/error.log;
      root /home/nginx/domains/mydomain.com/public;
      location ~ (?:^|/)\. {
       deny all;
    include /usr/local/nginx/conf/wpsupercache_mydomain.com.conf;
      #autoindex  on;
      try_files /wp-content/cache/supercache/$http_host/$cache_uri/index.html $uri $uri/ /index.php?q=$uri&$args;
      # Wordpress Permalinks
        #limit_conn xwpconlimit 30;
        auth_basic "Private";
        auth_basic_user_file /home/nginx/domains/mydomain.com/htpasswd_wplogin;
    location ~* /(xmlrpc\.php) {
    include /usr/local/nginx/conf/wpsecure_mydomain.com.conf;
                listen   80;
                server_name mydomain.com;
                return 301 $scheme://www.mydomain.com$request_uri;
      server_name www.mydomain.com;
      # ssi  on;
       deny all;
      #autoindex  on;
    55,811
    12,272
    11:40 PM
    change the $scheme to https
    from
                listen   80;
    to
                listen   80;
                return 302 https://www.mydomain.com$request_uri;
    use 302 temp redirect until you get it working
