Xenforo Admincp logs out users every 2 min; caching issue?
Discussion in 'Forum software usage' started by poly1, Jan 15, 2015.
  1. poly1
    poly1 New Member
    5
    11:24 AM
    1.7.7
    5.5.41
    Hello,
    I am running a Xenforo 1.4.3-based forum, using Centmin .07, with the following setup:
    • Xen-based dedicated VPS, CentOS 6.6
    • php 5.6.4
    • nginx 1.7.7
    • memcached w/Zend opcache
    • MariaDB
    Everything works great, especially the caching (stats pages confirm this). However, since enabling memcached and/or Zend, I've been noticing that site staff, myself included, are being logged out of the Admin control panel after approx. 2 minutes, regardless of whether or not they are inactive. This issue only happens in the Admin panel, not the rest of the forum. I've Googled the issue, without a satisfactory answer, however some of the discussions I found seem to point toward the culprit being a caching issue.
    My question is, is there a way to fix the caching issues so that users no longer get automatically logged out of the admin panel every 2 minutes? Alternatively, is there a way to disable caching for the admin panel only? Any help would be greatly appreciated. Thanks :)
    55,916
    12,281
    11:24 AM
    Centmin Mod out of box and defaults do not do any php related caching beyond static file caching. So it shouldn't be related. Have you checked if it's related to any Xenforo addons ?
    When did this logging out start happening ? since day 1 with Centmin Mod and/or particular Xenforo version ? or since particular Centmin Mod software updates ?
    It's my first time hearing of such issues as it isn't common for me or folks I know using Xenforo + Centmin Mod
  3. poly1
    poly1 New Member
    5
    11:24 AM
    1.7.7
    5.5.41
    I guess I should rephrase my original post: I'm not 100% certain when exactly the logout problem with the admin panel started. I handle mostly backend affairs for my site, so I don't spend much time logged in. A few of the other staff reported the problem to me, and they seem convinced that caching is to blame. Aside from verifying that the automatic logout is a real thing, I haven't been able to pinpoint a cause. I guess I should be looking at Firebug/Google Developer Tools, and posting this query to the Xenforo site. Thanks anyways for your quick response :)
  4. rdan
    1,412
    9:24 AM
    Maybe their IP is not static and changing every few minutes.
  5. KeVo
    KeVo Active Member
    180
    71
    8:24 PM
    1.11.x
    10.1.18
    I was having an issue of where my XenForo installation absolutely refused to allow me to log in to my admin CP at times, and when I did manage to sign in, it would sign me back out a couple of minutes later.
    I found the issue to be Cloudflare. Not sure if you're using this service, but if anyone else is using them and having issues, I figured I'd share. It was odd because it was still screwy even after adding a page rule exemption to the admin.php
  6. rdan
    1,412
    9:24 AM
    How did you manage to fix it?
    I'm using Cloudflare too.
  7. KeVo
    KeVo Active Member
    180
    71
    8:24 PM
    1.11.x
    10.1.18
    I didn't exactly "fix it" to say the least. I simply put the Cloudflare on pause.
  8. rdan
    1,412
    9:24 AM
    I'm using cloudflare and I don't have this kind of problem though :).
  9. KeVo
    KeVo Active Member
    180
    71
    8:24 PM
    1.11.x
    10.1.18
    Would you mind sharing your cloudflare settings and any page rule exemptions you may have with the settings within possible exemptions?
  10. rdan
    1,412
    9:24 AM
    I added admin.php on page rules and turn off almost everything.
  11. KeVo
    KeVo Active Member
    180
    71
    8:24 PM
    1.11.x
    10.1.18
    What do you leave on?
  12. rdan
    1,412
    9:24 AM
    SS
  13. KeVo
    KeVo Active Member
    180
    71
    8:24 PM
    1.11.x
    10.1.18
    Your domain, do you have it written out as "http:// domain . com/admin.php" or "domain.com/admin.php"?
    Can I also get a SS of your cloudflare settings? I know it's a pain, but I'd be grateful :)
  14. rdan
    1,412
    9:24 AM
    Page rule pattern: *domain.com/admin.php*
    Security settings:
    I only intended to use their CDN.
  15. KeVo
    KeVo Active Member
    180
    71
    8:24 PM
    1.11.x
    10.1.18
    I'll give your settings a go and see how it works out for me. THANKS A BUNCH!
  16. KeVo
    KeVo Active Member
    180
    71
    8:24 PM
    1.11.x
    10.1.18
    @RoldanLT, your Cloudflare settings appear to have worked for my centmin/xenforo combo. I'm not experiencing any trouble logging into my admin CP now.
