Additions to custom_config.inc for persistent NGINX .conf
Discussion in 'Feature Requests & Suggestions' started by ethanpil, Dec 16, 2016.
  1. ethanpil
    ethanpil Active Member
    173
    55
    7:32 AM
    I would guess that most centminmod users are fairly experienced with linux/nginx/servers, etc, and its quite common to customize the nginx.conf files.
    Usually we append or prepend to the location{} command of vhosts in NGINX. Or maybe play with try_files commands, or even setup unique and favorite custom nginx configurations.
    It will be quite useful to make these customization more automated, persistent and reproducible.
    Some examples:
    1. Often, I manually create sites for wordpress Option 2 instead of 22 because I have my special caching and security settings and exceptions for WP.
    2. Often I install another PHP framework or application that has its own recommended NGINX directives.
    3. I am thinking of prepending try_files to check if there is a __BILLING.html file in the root folder which I am creating when account is past due (and deleting when paid), to make a simple billing enforcement for clients.
    Anyway I have many specialized kinds of servers with some unique commands always used in nginx and with centmin its hard to update without worry of losing all the extra work. Each new server is also a lot of configuration. I wish I can easily tell centminmod I always want it to add this to conf files when creating a new domain, or updating a conf file. Its easy to modify centmin source code but then its not persistent for updates and not easy to replicate across server.
    My idea is to add these optional settings to /etc/centminmod/custom_config.inc:
    NGINX_LOCATION_PREPEND=filename1
    NGINX_LOCATION_APPEND=filename2
    NGINX_LOCATION_BEFORE=filename3
    NGINX_LOCATION_AFTER=filename4
    RUN_AFTER_NEWVHOST=filename1
    Lets see how this works:
    When centminmod is writing the location{}  block of a new vhost, then prepend the contents of filename1  at the top of location{
    NGINX_LOCATION_APPEND=filename1
    When centminmod is writing the location{}  block of a new vhost, then append the contents of filename1  at the end of  location{  }  --before the closing brace
    NGINX_LOCATION_BEFORE=filename1
    When centminmod is writing the location{}  block of a new vhost, then include the file of filename1  before location{}
    NGINX_LOCATION_AFTER=filename1
    When centminmod is writing the location{}  block of a new vhost, then include the file of filename1  after location{}
    This way its for anyone setup all common favorite nginx settings on servers and can easily replicate customization across them and can also upgrade without worry.
    I can easily setup my own default wordpress configurations and exceptions for plugins, or even custom try_files blocks if I want to get crazy.
    Bonus :)
    To go even farther, I would love to be able to execute a custom bash script at the end of vhost creation with vars accessible to the script like vhostname and vhostpath . This can be used if I want to setup my own notifications or databases, files, frameworks, etc...
    So, with these functions for all new servers we can install as usual and then simply upload our unique customizations /etc/centminmod or even /etc/centminmod/custom and then all customization will be persistent and easily reproducible. It can even become a way to create 'plugins'.
    I would love to see these power tools added to the incredible system, it will really make persistent customization a breeze.
    49,869
    11,482
    7:32 AM
  3. ethanpil
    173
    55
    7:32 AM
    As you see, in the original thread I have the same request... :)
    This variation is more useful and generic... Would make it very easy to automate deployment of CMM...
  4. ethanpil
    173
    55
    7:32 AM
    Maybe I am silly. Isn't this just a matter of editing two files?
    centmin.sh #at the top where setting defaults
    #Dont include additional NGINX conf directives by default
    NGINX_LOCATION_PREPEND=''
    NGINX_LOCATION_APPEND=''
    NGINX_LOCATION_BEFORE=''
    NGINX_LOCATION_AFTER=''
    RUN_AFTER_NEWVHOST=''
    inc/nginx_addvhost.inc - At top:
    #load custom NGINX configuration content
    if [ "${NGINX_LOCATION_PREPEND}" != '' ] && [ -f "${CONFIGSCANBASE}/{NGINX_LOCATION_PREPEND}" ];
    then
       NGINX_LOCATION_PREPEND_CONTENT=$( cat {NGINX_LOCATION_PREPEND} )
    else
       NGINX_LOCATION_PREPEND_CONTENT=''
    fi
    if [ "${NGINX_LOCATION_APPEND}" != '' ] && [ -f "${CONFIGSCANBASE}/{NGINX_LOCATION_APPEND}" ];
    then
       NGINX_LOCATION_APPEND_CONTENT=$( cat {NGINX_LOCATION_APPEND} )
    else
       NGINX_LOCATION_APPEND_CONTENT=''
    fi
    if [ "${NGINX_LOCATION_BEFORE}" != '' ] && [ -f "${CONFIGSCANBASE}/{NGINX_LOCATION_BEFORE}" ];
    then
       NGINX_LOCATION_BEFORE_CONTENT=$( cat {NGINX_LOCATION_BEFORE} )
    else
       NGINX_LOCATION_BEFORE_CONTENT=''
    fi
    if [ "${NGINX_LOCATION_AFTER}" != '' ] && [ -f "${CONFIGSCANBASE}/{NGINX_LOCATION_AFTER}" ];
    then
       NGINX_LOCATION_AFTER_CONTENT=$( cat {NGINX_LOCATION_AFTER} )
    else
       NGINX_LOCATION_AFTER_CONTENT=''
    fi
    Then 123.09beta01/inc/nginx_addvhost.inc
    Add in line 648, and add in line 746
    $NGINX_LOCATION_BEFORE_CONTENT
    Add in line 648, add in line 765
    $NGINX_LOCATION_AFTER_CONTENT
    Add in line 650, and add in line 748
    $NGINX_LOCATION_PREPEND_CONTENT
    Add in line 665, add in line 763
    $NGINX_LOCATION_APPEND_CONTENT
    Add in Line 533
    if [ "${RUN_AFTER_NEWVHOST}" != '' ] && [ -f "${CONFIGSCANBASE}/{RUN_AFTER_NEWVHOST}" ];
    then
       source RUN_AFTER_NEWVHOST
    fi
    49,869
    11,482
    7:32 AM
    maybe looks good but as I've been sick for past 3 weeks and still sick it's not the time to test and look into yet :)
    49,869
    11,482
    7:32 AM
    2 line 648s ?
  7. ethanpil
    173
    55
    7:32 AM
    Of course mate! Feel better. I was just trying to verify my thought. I hope we can test it once you feel better...
    Sorry about that. The second 648 should be 675. Seems I can no longer edit the original post...
    Add in line 675, add in line 765
  8. ethanpil
    173
    55
    7:32 AM
    Hope you are feeling better?Any chance we can test this soon? :)
    49,869
    11,482
    7:32 AM
    not yet :)
  10. ethanpil
    173
    55
    7:32 AM
    Just checking in on my dreams... o_O:)
    49,869
    11,482
    7:32 AM
    Not yet :)
    Probably won't be until after 123.09beta01 goes stable.
  12. ethanpil
    173
    55
    7:32 AM
    I was recently thinking that instead of the above complex scenario, it may be wiser and easier to simply store the entire location{} directive in an external file, and include that within nginx_addvhost.inc
    So, instead of append and prepend in location{} as I described above, we move the default location{} code to /inc/nginx_addvhost_location.inc and/or /inc/nginx_addvhost_location_wp.inc as you see fit.
    Then we can just have a default setting in /etc/centminmod/custom_config.inc like this
    NGINX_LOCATION_CUSTOM=N
    Then in inc/nginx_addvhost.inc
    if [ "${NGINX_LOCATION_CUSTOM}" != 'N' ] && [ -f "${CONFIGSCANBASE}/{NGINX_LOCATION_CUSTOM}" ];
    then
       source "${CONFIGSCANBASE}/{NGINX_LOCATION_CUSTOM}"
    else
       source "/inc/nginx_addvhost_location.inc"
    fi
    We can base our code of the default /inc/nginx_addvhost_location.inc that you provide, or customize as needed.
    What do you think about this simpler and more powerful method?
    49,869
    11,482
    7:32 AM
    Yeah that is much simpler though you would also have to pay attention to order of location contexts throughout the vhost. Whatever method we decide on, needs alot of testing first too :)
  14. ethanpil
    173
    55
    7:32 AM
    I'm excited to test, when the time comes. :whistle:
    49,869
    11,482
    7:32 AM
