Beta Branch add tools/csfincapsula.sh script to auto whitelist incapsula ips in 1…
Discussion in 'Centmin Mod Github Commits' started by eva2000, Mar 26, 2017.
    43,469
    9,869
    7:15 AM
    add tools/csfincapsula.sh script to auto whitelist incapsula ips in 123.09beta01
    + setup nginx real ip for properly visitor ip detection behind incapsula
    see https://community.centminmod.com/posts/46876/ and https://centminmod.com/nginx_configure_cloudflare.html
    123.09beta01 branch
    43,469
    9,869
    7:15 AM
    Add to 123.09beta01 tools/csfincapsula.sh script for whitelisting and real ip detection setup for Incapsula WAF/CDN/DDOS users similar to tools/csfcf.sh script for Cloudflare users.
    Query Incapsula API for plain text list of their IP addresses
    curl -s --data "resp_format=text" https://my.incapsula.com/api/integration/v1/ips
    199.83.128.0/21
    198.143.32.0/19
    149.126.72.0/21
    103.28.248.0/22
    185.11.124.0/22
    192.230.64.0/18
    45.64.64.0/22
    107.154.0.0/16
    2a02:e980::/29
    Query Incapsula API for plain text list of their IP addresses and manipulating to output format for commands to whitelist in CSF Firewall
    curl -s --data "resp_format=text" https://my.incapsula.com/api/integration/v1/ips | while read i; do echo "csf -a ${i} incapsula"; done
    csf -a 199.83.128.0/21 incapsula
    csf -a 198.143.32.0/19 incapsula
    csf -a 149.126.72.0/21 incapsula
    csf -a 103.28.248.0/22 incapsula
    csf -a 185.11.124.0/22 incapsula
    csf -a 192.230.64.0/18 incapsula
    csf -a 45.64.64.0/22 incapsula
    csf -a 107.154.0.0/16 incapsula
    csf -a 2a02:e980::/29 incapsula
    testing tools/csfincapsula.sh script
     ./csfincapsula.sh
    ./csfincapsula.sh {ips|csf|nginx|auto}
    ./csfincapsula.sh ips
     Downloading Incapsula P list
     Format for Centminmod.com Nginx Installer
      1). add to nginx.conf
      2). add to /etc/csf/csf.allow
    set_real_ip_from 199.83.128.0/21;
    set_real_ip_from 198.143.32.0/19;
    set_real_ip_from 149.126.72.0/21;
    set_real_ip_from 103.28.248.0/22;
    set_real_ip_from 185.11.124.0/22;
    set_real_ip_from 192.230.64.0/18;
    set_real_ip_from 45.64.64.0/22;
    set_real_ip_from 107.154.0.0/16;
    set_real_ip_from 2a02:e980::/29;
    real_ip_header X-Forwarded-For;
    ./csfincapsula.sh nginx
    created /usr/local/nginx/conf/incapsula.conf include file
    contents of /usr/local/nginx/conf/incapsula.conf include file
    cat /usr/local/nginx/conf/incapsula.conf
    include /usr/local/nginx/conf/incapsula_customips.conf;
    now the auto run which adds incapsula ips to CSF firewall whitelist and creates the include file /usr/local/nginx/conf/incapsula.conf automatically.
    ./csfincapsula.sh auto
     Add Incapsula P list to CSF
      Add to /etc/csf/csf.allow
    Adding 199.83.128.0/21 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [199.83.128.0/21] to set [chain_ALLOW]
    Adding 198.143.32.0/19 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [198.143.32.0/19] to set [chain_ALLOW]
    Adding 149.126.72.0/21 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [149.126.72.0/21] to set [chain_ALLOW]
    Adding 103.28.248.0/22 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [103.28.248.0/22] to set [chain_ALLOW]
    Adding 185.11.124.0/22 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [185.11.124.0/22] to set [chain_ALLOW]
    Adding 192.230.64.0/18 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [192.230.64.0/18] to set [chain_ALLOW]
    Adding 45.64.64.0/22 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [45.64.64.0/22] to set [chain_ALLOW]
    Adding 107.154.0.0/16 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [107.154.0.0/16] to set [chain_ALLOW]
    Adding 2a02:e980::/29 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [2a02:e980::/29] to set [chain_6_ALLOW]
    /etc/csf/csf.ignore ignore list
    cat /etc/csf/csf.ignore
    # Copyright 2006-2017, Way to the Web Limited
    # URL: http://www.configserver.com
    # Email: [email protected]
    # The following IP addresses will be ignored by all lfd checks
    # One IP address per line
    # CIDR addressing allowed with a quaded IP (e.g. 192.168.254.0/24)
    # Only list IP addresses, not domain names (they will be ignored)
    127.0.0.1
    199.83.128.0/21
    198.143.32.0/19
    149.126.72.0/21
    103.28.248.0/22
    185.11.124.0/22
    192.230.64.0/18
    45.64.64.0/22
    107.154.0.0/16
    2a02:e980::/29
