Beta Branch add PHPMSSQL_ALWAYS variable for 123.09beta01+
Discussion in 'Centmin Mod Github Commits' started by eva2000, Jul 5, 2016.
    55,802
    12,272
    12:04 PM
    To enable PHP mssql & PDO_ODBC drivers for PHP communicating with Microsoft SQL Server, you now need to set 2 variables in persistent config file that you either create or append to these 2 variables:
    PHPMSSQL='y'
    PHPMSSQL_ALWAYS='y'
    then run centmin.sh menu option 5 to recompile PHP to enable MS SQL sever extension support in PHP 5.4-5.6. The mssql extension is only supported in PHP 5.4-5.6 while PDO_ODBC driver support is available in PHP 5.4-5.6 and PHP 7.
    example mssql and PDO_ODBC driver support in PHP 5.6.23
    php --ini
    /etc/centminmod/php.d/mailparse.ini,
    /etc/centminmod/php.d/mssql.ini,
    /etc/centminmod/php.d/zendopcache.ini,
    contents of .ini file for /etc/centminmod/php.d/mssql.ini
    cat /etc/centminmod/php.d/mssql.ini
    extension=mssql.so
    php --ri pdo
    PDO
    PDO support => enabled
    PDO drivers => mysql, odbc, sqlite
    php --ri mssql
    mssql
    MSSQL Support => enabled
    Active Persistent Links => 0
    Active Links => 0
    Library version => FreeTDS
    mssql.allow_persistent => On => On
    mssql.max_persistent => Unlimited => Unlimited
    mssql.max_links => Unlimited => Unlimited
    mssql.min_error_severity => 10 => 10
    mssql.min_message_severity => 10 => 10
    mssql.compatability_mode => Off => Off
    mssql.compatibility_mode => Off => Off
    mssql.connect_timeout => 5 => 5
    mssql.timeout => 60 => 60
    mssql.textsize => Server default => Server default
    mssql.textlimit => Server default => Server default
    mssql.batchsize => 0 => 0
    mssql.datetimeconvert => On => On
    mssql.secure_connection => Off => Off
    mssql.max_procs => Unlimited => Unlimited
    mssql.charset => no value => no value
    php --ri PDO_ODBC
    PDO_ODBC
    PDO Driver for ODBC (unixODBC) => enabled
    ODBC Connection Pooling => Enabled, strict matching
    php -m
    [PHP Modules]
    bcmath
    bz2
    calendar
    Core
    ctype
    curl
    date
    dom
    enchant
    ereg
    exif
    filter
    ftp
    gd
    geoip
    gettext
    gmp
    hash
    iconv
    igbinary
    imagick
    imap
    intl
    json
    libxml
    mailparse
    mbstring
    mcrypt
    memcache
    memcached
    mhash
    mssql
    mysql
    mysqli
    mysqlnd
    openssl
    pcntl
    pcre
    PDO
    pdo_mysql
    PDO_ODBC
    pdo_sqlite
    Phar
    posix
    pspell
    readline
    redis
    Reflection
    session
    shmop
    SimpleXML
    snmp
    soap
    sockets
    SPL
    sqlite3
    standard
    sysvmsg
    sysvsem
    sysvshm
    tidy
    tokenizer
    xml
    xmlreader
    xmlrpc
    xmlwriter
    xsl
    Zend OPcache
    zip
    zlib
    [Zend Modules]
    Zend OPcache
    123.09beta01 branch
    55,802
    12,272
    12:04 PM
    Retesting to see if the MSSQL extension support works for PHP 7.2.5. PHP 7 uses PDO_ODBC driver instead of MSSQL extension
    MSSQL extension removed in PHP 7.0.0 so Centmin Mod PHP-FPM 7.x uses PDO_ODBC driver instead PHP: Introduction - Manual
    Set in persistent config file /etc/centminmod/custom_config.inc prior to PHP 7.2.5 compile via centmin.sh menu option 5
    PHPMSSQL='y'
    PHPMSSQL_ALWAYS='y'
    php -v
    PHP 7.2.5 (cli) (built: May 19 2018 00:29:49) ( NTS )
    Copyright (c) 1997-2018 The PHP Group
    Zend Engine v3.2.0, Copyright (c) 1998-2018 Zend Technologies
        with Zend OPcache v7.2.5, Copyright (c) 1999-2018, by Zend Technologies
    php --ini
    /etc/centminmod/php.d/mcrypt.ini,
    php --ri pdo
    PDO
    php -m
    [PHP Modules]
    bcmath
    bz2
    calendar
    Core
    ctype
    curl
    date
    dom
    enchant
    exif
    filter
    ftp
    gd
    geoip
    gettext
    gmp
    hash
    iconv
    igbinary
    imagick
    imap
    intl
    json
    ldap
    libxml
    mailparse
    mbstring
    mcrypt
    memcache
    memcached
    mysqli
    mysqlnd
    openssl
    pcntl
    pcre
    PDO
    pdo_mysql
    PDO_ODBC
    pdo_sqlite
    Phar
    posix
    pspell
    readline
    redis
    Reflection
    session
    shmop
    SimpleXML
    snmp
    soap
    sockets
    sodium
    SPL
    sqlite3
    standard
    sysvmsg
    sysvsem
    sysvshm
    tidy
    tokenizer
    xml
    xmlreader
    xmlrpc
    xmlwriter
    xsl
    Zend OPcache
    zip
    zlib
    [Zend Modules]
    Zend OPcache
    php-config
    Usage: /usr/local/bin/php-config [OPTION]
    Options:
      --prefix            [/usr/local]
      --includes          [-I/usr/local/include/php -I/usr/local/include/php/main -I/usr/local/include/php/TSRM -I/usr/local/include/php/Zend -I/usr/local/include/php/ext -I/usr/local/include/php/ext/date/lib]
      --ldflags           [ -L/usr/local/lib64]
      --libs              [-lcrypt  -lc-client  -lzip -lzip -lz -lexslt -ltidy -largon2 -lresolv -lcrypt -lsodium -ledit -lncurses -laspell -lpspell -lrt -lldap -llber -lstdc++ -lcrypt -lpam -lgmp -lX11 -lXpm -lpng -lz -ljpeg -lwebp -lenchant -lbz2 -lz -lrt -lm -ldl -lnsl  -lxml2 -lz -lm -ldl -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lssl -lcrypto -lcurl -lxml2 -lz -lm -ldl -lssl -lcrypto -lfreetype -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lssl -lcrypto -ldl -lm -licui18n -licuuc -licudata -ldl -lm -licuio -lodbc -lxml2 -lz -lm -ldl -lnetsnmp -lssl -lssl -lcrypto -lm -lxml2 -lz -lm -ldl -lcrypt -largon2 -largon2 -lxml2 -lz -lm -ldl -lxml2 -lz -lm -ldl -lxml2 -lz -lm -ldl -lxml2 -lz -lm -ldl -lxslt -lxml2 -lz -ldl -lm -lssl -lcrypto -lcrypt ]
      --extension-dir     [/usr/local/lib/php/extensions/no-debug-non-zts-20170718]
      --include-dir       [/usr/local/include/php]
      --man-dir           [/usr/local/php/man]
      --php-binary        [/usr/local/bin/php]
      --php-sapis         [ cli embed fpm phpdbg cgi]
      --configure-options [--enable-fpm --enable-opcache --enable-intl --enable-pcntl --with-mcrypt --with-snmp --enable-embed=shared --with-mhash --with-zlib --with-gettext --enable-exif --enable-zip --with-libzip --with-bz2 --enable-soap --enable-sockets --enable-sysvmsg --enable-sysvsem --enable-sysvshm --enable-shmop --with-pear --enable-mbstring --with-openssl --with-mysql=mysqlnd --with-libdir=lib64 --with-mysqli=mysqlnd --with-mysql-sock=/var/lib/mysql/mysql.sock --with-curl --with-gd --with-xmlrpc --enable-bcmath --enable-calendar --enable-ftp --enable-gd-native-ttf --with-freetype-dir=/usr --with-jpeg-dir=/usr --with-png-dir=/usr --with-xpm-dir=/usr --with-webp-dir=/usr --with-t1lib=/usr --enable-pdo --with-pdo-sqlite --with-pdo-mysql=mysqlnd --with-pdo-odbc=unixODBC,/usr --enable-inline-optimization --with-imap --with-imap-ssl --with-kerberos --with-readline --with-libedit --with-gmp --with-pspell --with-tidy --with-enchant --with-fpm-user=nginx --with-fpm-group=nginx --disable-fileinfo --with-ldap --with-ldap-sasl --with-password-argon2 --with-sodium --with-config-file-scan-dir=/etc/centminmod/php.d --with-xsl]
      --version           [7.2.5]
      --vernum            [70205]
