Master Branch add PHP 7.0.33, 7.1.33 & 7.2 mysqlnd fix patch for MariaDB in 123.09b…
Discussion in 'Centmin Mod Github Commits' started by eva2000, Nov 13, 2020.
    45,633
    10,356
    9:27 PM
    add PHP 7.0.33, 7.1.33 & 7.2 mysqlnd fix patch for MariaDB in 123.09beta01
    - control backport fix enablement via variable PHP_MYSQLND_PATCH_FIX='y' which is enabled by default will apply backported fixes to PHP <= 7.2 on PHP compilation at initial install or via centmin.sh menu option 5. If you want to test with backported fixes disabled, just set in persistent config file /etc/centminmod/custom_config.inc the variable PHP_MYSQLND_PATCH_FIX='n' and then run centmin.sh menu option 5 to recompile your version of PHP. This only applies for PHP 5.6.40, 7.0.33, 7.1.33, 7.2.x as PHP 7.3, 7.4 and 8.0 are not affected.
    - backport fix from PHP 7.3 for mysqlnd optimization which fixes MariaDB 10.5.7, 10.4.16, 10.3.26, 10.2.35 and 10.1.48 release issue as these versions have stricter packet validation as a security measure [MDEV-24121] Recent MariaDB update appears to have introduced a DB connection issue for PHP < 7.3 (or anything using PDO) - Jira outlined at MariaDB - MariaDB 10.5.7, 10.4.16, 10.3.26, 10.2.35 and 10.1.48 now available
    - fix for PHP 5.6.40 has less testing done as backported patch needed reworking as originally didn't apply cleanly
    - to update, run cmupdate command, then run centmin.sh menu option 5 to recompile your choice of EOL 7.0.33 or 7.1.33 or any PHP 7.2.34 or higher version. PHP 7.3+, 7.4+ and 8.0+ already natively has this fixed. If you manually applied patch outlined at MariaDB - MariaDB 10.5.7, 10.4.16, 10.3.26, 10.2.35 and 10.1.48 now available, you'd have additional step before cmupdate run to remove the manual patch created patch files via SSH commands below:
    cmdir
    rm -f patches/php/php*-mysqlnd-fix.patch
    cmupdate
    ./centmin.sh
