Beta Branch add patched brotli rpm withdraw path and ^cmm1 rebuilds to tools/phpf…
Discussion in 'Centmin Mod Github Commits' started by eva2000, Oct 27, 2026 at 10:14 AM.
    60,147
    12,591
    5:59 PM
    add patched brotli rpm withdraw path and ^cmm1 rebuilds to tools/phpfpm-brotli.sh in 140.00beta01
    The patched distro brotli rpms are rebuilt with a ^cmm1 release suffix and
    can now be withdrawn remotely: cmupdate replaces a withdrawn build with the
    distro release, keeping php-fpm on the source-built brotli override first.
    Changes:
    - rpm release suffix .cmm1 -> ^cmm1: sorts above the distro release but
    below any later distro rebuild (.1, .alma.N, .rocky.N, release bumps), so
    a distro fix replaces it; new rpms on the parts mirror under rpm/el{8,9,10}/
    - BROTLI_RPM_REVOKED list: a listed build is not installed, is reported by
    status, and is replaced by the new reconcile subcommand
    - reconcile: puts the php-fpm override in place first (when php-fpm loads
    brotli and PHPFPM_BROTLI_SOURCE allows), then dnf downgrade to the distro
    release with a dnf distro-sync fallback limited to the brotli packages
    - rpm-revert subcommand to go back to the distro release by hand
    - tools/cmupdate.sh runs reconcile at the end of fupdate() (quiet when
    there is nothing to do)
    - inc/cpcheck.inc brotli_rpm_notice: rpm-only check at centmin.sh start,
    prints a warning via the new notice subcommand when a withdrawn build is
    installed, skipped during autoupdate runs
    - on/prepare reconcile a withdrawn build before anything else
    - rpm queries go by file (/usr/lib64/libbrotlidec.so.1), EL8 rpm 4.14.3
    cannot query a NVR containing ^ by name
    - never call dnf distro-sync with an empty package list (whole system)
    140.00beta01 branch
