Beta Branch add optional variable CLOUDFLARE_ZLIB_OPENSSL in 123.09beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Aug 18, 2018.
    55,796
    12,271
    7:48 PM
    Add optional variable, CLOUDFLARE_ZLIB_OPENSSL='n' which is disabled by default. Enabling CLOUDFLARE_ZLIB_OPENSSL='y' via persistent config file allows custom OpenSSL to be dynamically built against Cloudflare zlib library if on 64bit systems only
    123.09beta01 branch
  2. rdan
    1,412
    5:48 PM
    What are the things need to run to apply this?
    55,796
    12,271
    7:48 PM
    No don't enable this. AFAIK from memory it isn't working right - hence disabled by default.
  4. rdan
    1,412
    5:48 PM
    I just enable this then run menu 5 / php upgrade
    then menu 4 / nginx upgrade.
    It isn't affected?
    Or I need to run those menu again now that I remove this from custom_config?
    Thanks!
    55,796
    12,271
    7:48 PM
    run then again :)
