Master Branch add optional OpenSSL 1.1.0g patch for Cloudflare Equal Cipher Prefere…
Discussion in 'Centmin Mod Github Commits' started by eva2000, Jan 9, 2018.
    37,663
    8,241
    4:52 PM
    add optional OpenSSL 1.1.0g patch for Cloudflare Equal Cipher Preference Groups
    - for 64bit systems only as alot of Cloudflare patches only work on 64bit cpus
    - when Nginx is recompiled via centmin.sh menu option 4 with prior persistent config file /etc/centminmod/custom_config.inc set variables, LIBRESSL_SWITCH='y', OPENSSLEQUALCIPHER_PATCH='y' and OpenSSL version used is 1.1.0g, then OpenSSL 1.1.0g is patched for Cloudflare backported Equal Cipher Preference Groups patch which originally is a BoringSSL feature not available in OpenSSL. Details https://community.centminmod.com/threads/patch-openssl-1-1-equal-preference-groups-of-cipher-suites.12224/
    - this patch allows a server to prefer one of AES-GCM or ChaCha20 ciphers, but to allow the client to pick which one. When coupled with clients that will boost AES-GCM in their references when AES-NI is present, this allows us to use AES-GCM when the hardware exists and ChaCha20 otherwise.
    - with this patch enabled, you need to change your Nginx HTTPS vhost config file's ssl_ciphers to the following:
    ssl_ciphers '[ECDHE-ECDSA-AES128-GCM-SHA256|ECDHE-ECDSA-CHACHA20-POLY1305|ECDHE-RSA-AES128-GCM-SHA256|ECDHE-RSA-CHACHA20-POLY1305]:ECDHE+AES128:RSA+AES128:ECDHE+AES256:RSA+AES256:ECDHE+3DES:RSA+3DES';
