Beta Branch add optional OpenSSL 1.1.0g patch for 30-40% ECDSA performance boost
Discussion in 'Centmin Mod Github Commits' started by eva2000, Jan 2, 2018.
    55,926
    6:42 PM
    - when Nginx is recompiled via centmin.sh menu option 4 with prior persistent config file /etc/centminmod/custom_config.inc set variables, LIBRESSL_SWITCH='y', OPENSSLECDSA_PATCH='y' and OpenSSL version used is 1.1.0g, then OpenSSL 1.1.0g is patched for better ECDSA performance. If you use ECC 256bit ECDSA SSL certificates for HTTP/2 HTTPS then you'll have better HTTP/2 HTTPS performance compared to standard ECDSA and the usual default RSA 2048bit SSL certificates OpenSSL - [PATCH]30-40% ECDSA performance improvement - OpenSSL 1.1
    123.09beta01 branch
    55,926
    6:42 PM
    On OVH Core i7 4790K 4C/8T server with CentOS 7.4 64bit and Centmin Mod 123.09beta01 LEMP stack
    With patch resulted in 43.4% faster ECDSA signs/s and 15.4% faster ECDSA verify/s :cool:
    OpenSSL 1.1.0g rsa 2048 signs/s rsa 2048 verify/s ecdsa 256bit signs/s ecdsa 256bit verify/s
    before patch 8278.4 181818.2 121212.1 43450.5
    after patch 8299.9 181818.2 173813.0 50157.2
    before ECDSA OpenSSL 1.1.0g backported patch
    openssl speed -multi 8 rsa2048 ecdsap256
    OpenSSL 1.1.0g  2 Nov 2017
    built on: reproducible build, date unspecified
    options:bn(64,64) rc4(16x,int) des(int) aes(partial) idea(int) blowfish(ptr)
    compiler: ccache gcc -DDSO_DLFCN -DHAVE_DLFCN_H -DNDEBUG -DOPENSSL_THREADS -DOPENSSL_NO_STATIC_ENGINE -DOPENSSL_PIC -DOPENSSL_IA32_SSE2 -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_MONT5 -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DRC4_ASM -DMD5_ASM -DAES_ASM -DVPAES_ASM -DBSAES_ASM -DGHASH_ASM -DECP_NISTZ256_ASM -DPADLOCK_ASM -DPOLY1305_ASM -DOPENSSLDIR="\"/opt/openssl\"" -DENGINESDIR="\"/opt/openssl/lib/engines-1.1\""  -Wa,--noexecstack
    rsa 2048 bits 0.000121s 0.000005s   8278.4 181818.2
     256 bit ecdsa (nistp256)   0.0000s   0.0000s 121212.1  43450.5
    after patch
    rsa 2048 bits 0.000120s 0.000005s   8299.9 181818.2
     256 bit ecdsa (nistp256)   0.0000s   0.0000s 173913.0  50157.2
    55,926
    6:42 PM
  4. Matt
    Matt Well-Known Member
    932
    415
    Rotherham, UK
    9:42 AM
    1.5.15
    MariaDB 10.2
    I've just switched a site to a new certificate using the P-256 key size (Comodo Certificate), so I've added both these flags to the nginx build :)
  5. Jimmy
    390
    4:42 AM
    I have the command to generate the RSA key. Do you have one for this?
    openssl req -new -newkey rsa:2048 -nodes -out <domain>_com.csr -keyout <domain>_com.key -subj...
    Love to give this a try. :)
    55,926
    6:42 PM
    Very nice.. if your adventureous you can also look into dual ECDSA + RSA ssl certificate configurations SSL - Nginx 1.11.0 introduces dual ECDSA + RSA SSL certificate support !
    to generate ECC 256bit ECDSA certificate's required CSR file and private key just replace the keyname variable with your domain or subdomain
    keyname=yourdomain.com
    curve=prime256v1
    openssl ecparam -out ${keyname}.key -name $curve -genkey
    openssl req -new -sha256 -key ${keyname}.key -nodes -out ${keyname}.csr
  7. Matt
    932
    415
    Rotherham, UK
    9:42 AM
    1.5.15
    MariaDB 10.2
    55,926
    6:42 PM
    Yeah that tool is useful too :)
    just becomes
    domain=yourdomain.com
    curve=prime256v1
    country=AU
    state=QLD
    city=Brisbane
    openssl ecparam -out $domain.key -name $curve -genkey
    openssl req -new -key $domain.key -nodes -out $domain.csr -subj "/C=$country/ST=$state/L=$city/O=$domain/CN=$domain"
  9. rdan
    1,412
    4:42 PM
    Is it possible I can have the URL via PM?
    I would like to test it with UC Browser on XP SP3 machine.
    Thanks!
  10. rdan
    1,412
    4:42 PM
    You only have 3 Cert also?
  11. Jimmy
    390
    4:42 AM
    Thanks, works great!
  12. Jimmy
    390
    4:42 AM
    I tried to re-issue a cert using the above and it gave me the warning:
    I guess the cheaper certs don't allow these? In my case, a Comodo Positive SSL.
  13. rdan
    1,412
    4:42 PM
  14. Jimmy
    390
    4:42 AM
    I just purchased a cert on Namecheap (Positive SSL) and everything worked fine.
    It appears that ssls is the issue. Thanks @RoldanLT
    For what it's worth, I sent in a support ticket to ssls.
  15. rdan
    1,412
    4:42 PM
    Is it possible I can have your URL via PM?
    Thanks!
  16. Jimmy
    390
    4:42 AM
    Site is behind a username / password because I'm working on the project. I figured that would be a good site to test everything out on.
    I'm probably not going to do any other sites until ssls upgrades.
