Beta Branch add opt-in compact dmotd SSH login banner in 140.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, May 19, 2026.
    60,129
    12,590
    1:45 AM
    Adds DMOTD_COMPACT='n'-by-default master switch plus 11 per-section
    sub-toggles to config/motd/dmotd.sh so admins can shrink the SSH login
    banner from ~63 lines to ~24-29 lines for limited-vertical-space
    terminals. Default behaviour is byte-for-byte unchanged for existing
    installs — admins opt in via /etc/centminmod/custom_config.inc.
    Changes:
    - DMOTD_COMPACT master switch (default 'n') for compact layout
    - DMOTD_CSFVERCHECK toggle (default 'y') to silence csf_version_checker
    - DMOTD_CVECHECK_COMPACT independent toggle (default 'n') for cmsec
    one-line summary; vulnerable/indeterminate CVEs always auto-expand
    - 9 ENABLEMOTD_*COMPACT sub-toggles for selective per-section opt-out
    - Header / memory / df-hT / CSF-banner / docs-links collapse in
    motd_output() — df-hT filters tmpfs/devtmpfs/efivarfs/squashfs/overlay
    - Merged status footer collects ngxver, phpver, gitenv_askupdate,
    needrestart, check_git_major_branch, csf_version_checker into one
    array rendered after all checks complete
    - ngxver/phpver run serially under DMOTD_COMPACT='y' (subshell array
    writes don't survive 'wait'); parallelism preserved in legacy mode
    - cmsec compact path makes a single cmsec.sh --json invocation instead
    of --dmotd + --json (halves CVE-check work on every login)
    - Pushover alert paths unchanged
    - example/custom_config.inc documents the new toggles
    140.00beta01 branch
    60,129
    12,590
    1:45 AM
  3. iaTa
    iaTa Member
    102
    3:45 PM
    MariaDB 10.11.x
    Love the new Fancy Compact DMOTD.
    Do you have any plans to do something similar with the centmin main menu?
