Beta Branch add nginx-length-hiding-filter-module in 123.09beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Aug 18, 2016.
    55,404
    12,256
    8:26 PM
    add a new nginx-length-hiding-filter-module GitHub - nulab/nginx-length-hiding-filter-module: nginx filter module to append random generated string to the end of HTML response for nginx in 123.09beta01 disabled by default and enabled/controlled by 2 variables you set in your persistent config file at /etc/centminmod/custom_config.inc. Enable by setting NGINX_LENGTHHIDE='n' to NGINX_LENGTHHIDE='y' and then running centmin.sh menu option 4 to recompile Nginx server.
    NGINX_LENGTHHIDE='n'         # https://github.com/nulab/nginx-length-hiding-filter-module
    NGINX_LENGTHHIDEGIT='y'      # triggers only if NGINX_LENGTHHIDE='y'
    123.09beta01 branch
    55,404
    12,256
    8:26 PM
    example with module enabled
    then enable in nginx vhost location context match with option length_hiding on
        location /hiding {
            length_hiding on;
    55,404
    12,256
    8:26 PM
    55,404
    12,256
    8:26 PM
    @BamaStangGuy apparently that was fixed for incompatibility with HTTP/2 nginx 1.11.3 ? · Issue #4 · nulab/nginx-length-hiding-filter-module · GitHub so worth retrying/retesting :)
    But I tried again with nginx 1.11.0 and still doesn't work for me heh
    set in nginx vhost
    location /hiding {
        length_hiding on;
    create directory /hiding with index.html page and see if the module inserts a random string into html. Unfortunately, still not seeing the random string
  5. SFLC
    SFLC Active Member
    223
    59
    The Canadas
    12:26 PM
    Just tried this out, not working for me either
