Beta Branch Add maintenance mode variables for nginx, php and mariadb updates
Discussion in 'Centmin Mod Github Commits' started by eva2000, Feb 14, 2016.
    55,926
    6:59 PM
    Added support for 3 new variables:
    NGINX_UPDATEMAINTENANCE=n
    PHP_UPDATEMAINTENANCE=n
    MARIADB_UPDATEMAINTENANCE=n
    If you set to yes in /etc/centminmod/custom_config.inc file. then whenever you run nginx, php or major mariadb upgrade, you put all sites on server into 503 maintenance mode first https://community.centminmod.com/posts/26485/ and once updated, disable 503 maintenance mod after.
    set in newly created or existing /etc/centminmod/custom_config.inc persistent config file
    NGINX_UPDATEMAINTENANCE=y
    PHP_UPDATEMAINTENANCE=y
    MARIADB_UPDATEMAINTENANCE=y
    123.09beta01 branch
  2. pamamolf
    4,101
    428
    11:59 AM
    Nginx-1.26.x
    Where is this file located in case that we need to edit it with another type of message?
    55,926
    6:59 PM
    it's same file already located in each nginx vhost public web root at /home/nginx/domains/domain.com/public/maintenance.html
  4. rdan
    1,412
    4:59 PM
    Latest 09btea new install.
    When I comment out: #include /usr/local/nginx/conf/maintenance.conf;
    Can't start Nginx with this error:
    Where can I remove that variable?
    55,926
    6:59 PM
    why disable and comment it out ? out of box default it isn't used unless you run sitestatus off/on command
  6. rdan
    1,412
    4:59 PM
    Found it now on php.conf
    location ~ \.php$ {
    #include /usr/local/nginx/conf/503include-only.conf;
  7. rdan
    1,412
    4:59 PM
    Just want to minimize Nginx config :)
    55,926
    6:59 PM
    honestly i wouldn't start removing them.. centmin mod may in future rely on them for other anchors additions etc :)
  9. rdan
    1,412
    4:59 PM
    I am reading all updates, so I should know when it comes :D.
