Beta Branch add LETSENCRYPT_DETECT variable to control addons/acmetool.sh detecti…
Discussion in 'Centmin Mod Github Commits' started by eva2000, Aug 30, 2016.
    55,375
    12,255
    4:27 PM
    add LETSENCRYPT_DETECT variable to control addons/acmetool.sh detection & integration
    in 123.09beta01, add LETSENCRYPT_DETECT variable to control Letsencrypt integration via addons/acmetool.sh auto detection in centmin.sh menu option 2, 22, and /usr/bin/nv nginx vhost generators. You can control whether or not to enable or disable integration detection in these menu options using persistent config file which you can create if it doesn't exist at /etc/centminmod/custom_config.inc.
    Currently, defaults to LETSENCRYPT_DETECT='n' to disable detection integration support of addons/acmetool.sh during beta testing phase Letsencrypt - Official acmetool.sh testing thread for Centmin Mod 123.09beta01 | Centmin Mod Community so that beta testers only can enable it for beta testing.
    You can enable addons/acmetool.sh integration detection by setting LETSENCRYPT_DETECT='y' in persistent config file /etc/centminmod/custom_config.inc.
    123.09beta01 branch
    55,375
    12,255
    4:27 PM
    no no.. centmin.sh option 22 and 2 are separate
    • centmin.sh menu option 22 for wordpress + nginx vhost
    • centmin.sh menu option 2 for normal nginx vhost
    enabling LETSENCRYPT_DETECT='y', will enable letsencrypt tools/acmetool.sh detection routines in both centmin.sh menu option 2 and 22 respectively - meaning they will prompt for letsencrypt specific questions.
  3. elargento
    elargento Member
    352
    3:27 AM
    Finally was able to install it before read your post. Thank you for your patience. :nailbiting:
  4. rc112
    rc112 Member
    126
    14
    2:27 PM
    @eva2000 I have it in my custom file but it prompt me
    [ LETSENCRYPT_DETECT is not enabled ]
    Ignore this message if you do not want HTTPS based web site otherwise
    read below carefully.
    Here is the file
    ZONEINFO=Asia/Taipei  # Set Timezone
    LETSENCRYPT_DETECT='y' # Use acmetool.sh
    ZOPCACHEDFT='y'
    PHP_VERSION='7.1.15'
    NGINX_IPV='y'
    PHP_PGO='y'  # Use PHP 7.x with Profile Guide Optimizations (PGO)
    NGXDYNAMIC_BROTLI='y'
    NGINX_LIBBROTLI='y'
    CLOUDFLARE_ZLIBPHP='y' # use Cloudflare optimised zlib fork for PHP-FPM zlib instead of system zlib
    CLOUDFLARE_PATCHSSL='y'   # set 'y' to implement Cloudflare's chacha20 patch  [https://github.com/cloudflare/sslconfig](https://github.com/cloudflare/sslconfig)
    NGINX_DYNAMICTLS='y'    # set 'y' and recompile nginx  [https://blog.cloudflare.com/optimizing-tls-over-tcp-to-reduce-latency/](https://blog.cloudflare.com/optimizing-tls-over-tcp-to-reduce-latency/)
    OPENSSLECDSA_PATCH='y' # https://community.centminmod.com/posts/57725/
    OPENSSLECDHX_PATCH='y' # https://community.centminmod.com/posts/57726/
    [22:37][root@centmin ~]# cat /etc/centminmod/acmetool-config.ini
    # options for KEYLENGTH
    # 2048, 3072, 4096, 8192, ec-256, ec-384
    KEYLENGTH='ec-256' #ECC 256 bit ECDSA SSL
    #PUSHALERT='n'
    #pushover_email=''
    55,375
    12,255
    4:27 PM
    wonder if it's character set issues again try converting the files to unix format using these 2 commands
    dos2unix /etc/centminmod/acmetool-config.ini
    dos2unix /etc/centminmod/custom_config.inc
  6. rc112
    rc112 Member
    126
    14
    2:27 PM
    @eva2000 I tried the command above and ran option 22 but still prompt me with self-signed SSL. I got the problem ever since having custom config in place. Should I recompile or anything to take effect? Thanks.
  7. rc112
    rc112 Member
    126
    14
    2:27 PM
    @eva2000 Problem solved. It works after running option 4 to recompile. Thank you so much for you support.
    55,375
    12,255
    4:27 PM
    oh that would make sense if nginx failed to compile the first time round sort of
    but if nginx already working previously, it should cause it to ignore LETSENCRYPT_DETECT='y' in /etc/centminmod/custom_config.inc
  9. hnit
    hnit New Member
    24
    11:57 AM
    Hi eva, been a while since I logged in here. I wanted to give centmin another try after I messed up last time.
    I did a fresh beta install last night using one-liner on an aws machine.
    For some reason, the file doesn't exist for me.
    What should I do here now?
    create a file and add LETSENCRYPT_DETECT='y' to it?
    I want to use option 22 for wordpress vhost
    Regards
    hnit
    55,375
    12,255
    4:27 PM
  11. hnit
    hnit New Member
    24
    11:57 AM
    Thanks for the command shortcut. I figured out the creating part just now too.
