Beta Branch Add GENERAL_DEVTOOLSETGCC variable to enable devtoolset-3 GCC 4.9 in …
Discussion in 'Centmin Mod Github Commits' started by eva2000, Oct 5, 2016.
    54,934
    12,240
    3:00 PM
    Add GENERAL_DEVTOOLSETGCC variable to enable devtoolset-3 GCC 4.9 in 123.09beta01
    For 64bit Intel based processor systems, extend devtoolset-3 GCC 4.9 version usage optionally to memcached server, libmemcached, memcache/memcached php extension compilations when you set in persistent config file /etc/centminmod/custom_config.inc the following variable before running centmin.sh menu option 10
    GENERAL_DEVTOOLSETGCC='y'
    By default on 123.09beta01, GENERAL_DEVTOOLSETGCC='n' is disabled.
    123.09beta01 branch
  2. rdan
    1,408
    1:00 PM
    What is this for ? :D
    54,934
    12,240
    3:00 PM
    compile/install/upgrade libmemcached, memcache/memcached php extensions installed via centmin.sh menu option 10 with intel cpu optimisations :)
  4. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    6:00 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    If I'm not using memcache/memcached at all on server, than this is not for me?
    54,934
    12,240
    3:00 PM
    yup
