Beta Branch update installers for EL8+ in 130.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Dec 20, 2023.
    6:23 AM
    - as outlined at https://community.centminmod.com/threads/centmin-mod-el8-roadmap-for-2023-2024.24290/, update public 130.00beta01 installers outlined at https://centminmod.com/install.html to enable EL8+ install support so you don't need to use speciailised inatallers for EL8+ outlined at https://community.centminmod.com/threads/how-to-beta-test-centmin-mod-on-almalinux-8-rocky-linux-8-oses.23261/
    - unfortunately EL8 minimum PHP version is 7.2, and EL9 minimum is PHP version 7.4 while CentOS 7 can still support minimum PHP 5.6 so the updated betainstaller*.sh will set and override minimum PHP version supported when it detects EL8 or EL9 OSes while still allowing CentOS 7 EL7 full minimum PHP version support to 5.6
    - add PHP 8.3 default installer
    130.00beta01 branch
    Support Centmin Mod
