Beta Branch add CLOUDFLARE_ZLIBRAUTOMAX='n' disable auto raise gzip compression b…
Discussion in 'Centmin Mod Github Commits' started by eva2000, Jun 11, 2018.
    55,796
    12,271
    7:47 PM
    add CLOUDFLARE_ZLIBRAUTOMAX='n' disable auto raise gzip compression by default
    Add CLOUDFLARE_ZLIBRAUTOMAX='n' by default to disable the new change implemented at Beta Branch - optimise nginx default gzip compression level when cloudflare zlib used by default unless folks want to enable it via persistent config file /etc/centminmod/custom_config.inc the variable, CLOUDFLARE_ZLIBRAUTOMAX='y' prior to recompiling nginx via centmin.sh menu option 4. This is because I realise some folks don't want to auto raise nginx gzip compression level to 9 out of box and prefer the old method which is what this change does by setting to CLOUDFLARE_ZLIBRAUTOMAX='n' by default
    123.09beta01 branch
