Beta Branch add Clang LTO Nginx build control variable in 140.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Sep 10, 2024.
    53,531
    12,134
    12:11 PM
    - For EL8 and EL9 OSes, when optional CLANG='y' enabled to build Nginx with Clang compiler instead of GCC compiler, previously enabled Clang LTO linker by default. This update adds a control variable setting CLANG_LTO_ENABLE='y'. Allowing end users to optionally disable Clang LTO linker via CLANG_LTO_ENABLE='n' prior to Nginx compiles via centmin.sh menu option 4. This allows finer grain control of whether Nginx is built with Clang + LTO or Clang without LTO.
    140.00beta01 branch
