Beta Branch add checks to APC Cache and Xcache reinstall menu options 7 and 6
Discussion in 'Centmin Mod Github Commits' started by eva2000, Jun 27, 2015.
    54,946
    12,240
    4:24 PM
    make sure a conflicting opcache isn't already installed, if detected prompt to use menu options 9 and 8 instead will are install NOT reinstall functions which properly take care of existing conflicting opcache configuration files.
    123.08beta03 branch
    * 123.08beta03 branch is the merging of the 3 branches - .08 beta 02 + 123.08lua + 123.08livestats so the new beta has both Nginx Lua + LuaJIT support + new Nginx vhost traffic statistics
