Not A Bug centmin.sh Add CF range to "permitted"?
Discussion in 'Bug Reports' started by Tracy Perry, Jul 17, 2023.
  1. Tracy Perry
    Tracy Perry Active Member
    280
    118
    Texas
    3:30 AM
    1.21.6
    MariaDB 10.3.36
    I recently found a "guest" coming in from 198.41.144.253
    Apparently there is a new "valid" range for CF IP's that should be included in the Cloudflare config file?
    55,926
    6:30 PM
    Which config file you're looking at locally?
    Seems it's already added to CSF Firewall - this is on test AlmaLinux 9 based Centmin Mod 130.00beta01 that I left alone with it's auto setup cronjob that auto adds new Cloudflare IP ranges to CSF Firewall whitelisting
    crontab -l | grep csfcf
    22 */12 * * * /usr/local/src/centminmod/tools/csfcf.sh auto >/dev/null 2>&1
    Ensure the cronjob was added by Centmin Mod's initial install that runs every 12hrs to add newly detected Cloudflare IP ranges.
    CSF Firewall grep IP shows range = 198.41.128.0/17 was auto added
    csf -g 198.41.144.253
    Table  Chain            num   pkts bytes target     prot opt in     out     source               destination
    No matches found for 198.41.144.253 in iptables
    IPSET: Set:chain_ALLOW Match:198.41.144.253 Setting: File:/etc/csf/csf.allow
    ip6tables:
    No matches found for 198.41.144.253 in ip6tables
    Permanent Allows (csf.allow): 198.41.128.0/17 # cloudflare - Fri Jun  2 10:33:31 2023
    Confirming the IPv4 IPs currently used by Cloudflare and Centmin Mod via tools/csfcf.sh and I do see IP range 198.41.128.0/17
    /usr/local/src/centminmod/tools/csfcf.sh ipv4-only
    173.245.48.0/20
    103.21.244.0/22
    103.22.200.0/22
    103.31.4.0/22
    141.101.64.0/18
    108.162.192.0/18
    190.93.240.0/20
    188.114.96.0/20
    197.234.240.0/22
    198.41.128.0/17
    162.158.0.0/15
    104.16.0.0/13
    104.24.0.0/14
    172.64.0.0/13
    131.0.72.0/22
    And in auto generated cloudflare.conf include file
    cat /usr/local/nginx/conf/cloudflare.conf | grep 198.41
    set_real_ip_from 198.41.128.0/17;
  3. Tracy Perry
    280
    118
    Texas
    3:30 AM
    1.21.6
    MariaDB 10.3.36
    May have caught it in an "in between" state... because it wasn't listed when I checked (and I manually all related cloudflare config files up. ;)
    55,926
    6:30 PM
    Would depend on what you installed Centmin Mod as initial install would run tools/csfcf.sh once to populate
    /usr/local/nginx/conf/cloudflare.conf include file and setup cronjob.
  5. Tracy Perry
    280
    118
    Texas
    3:30 AM
    1.21.6
    MariaDB 10.3.36
    Was when you first invited me to the AlmaLinux/Rocky beta a few months ago.
    But it very likely (if the cron job is a regular sequence) before it got to run...
