Beta Branch add addons/opendkim.sh for dkim setup for 123.09beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Apr 13, 2016.
    60,129
    12,590
    1:31 AM
    already does that in code for addons/opendkim.sh but there's a check for the vhostname i.e. = domain.com which if matches hostname.domain.com then wont' be added
    strange worked for me so will double check
  2. pamamolf
    4,128
    5:31 PM
    Ok microsoft don't like my emails but that's ok i give up with them even if i have rdns spf dkim and dmark all ok they push my email to spam :)
    Checking there the headers i can see:
    dkim=pass (identity alignment result is pass and alignment mode is relaxed)
    so dkim now seems to work :)
  3. pamamolf
    4,128
    5:31 PM
    Is hostname and domain the same and domain not need a separate entry there?
    60,129
    12,590
    1:31 AM
    separate entries for host.domain.com and domain.com as this script is only for host.domain.com in out of box centmin mod setups unless you add full email @domain.com for in/out bound to your server to be locally hosted.
    but i did fix up at Beta Branch - fixes for addons/opendkim.sh in 123.09beta01 | Centmin Mod Community
  5. pamamolf
    4,128
    5:31 PM
    Great it seems also that it needs to comment this line ? as KeyTable is in used:
    /etc/opendkim.conf
    #KeyFile        /etc/opendkim/keys/default.private
    60,129
    12,590
    1:31 AM
    no need KeyFile is ignored if KeyTable enabled
    ##  Gives the location of a private key to be used for signing ALL messages. This
    ##  directive is ignored if KeyTable is enabled.
    ##  Gives the location of a file mapping key names to signing keys. In simple terms,
    ##  this tells OpenDKIM where to find your keys. If present, overrides any KeyFile
    ##  directive in the configuration file. Requires SigningTable be enabled.
    KeyTable        /etc/opendkim/KeyTable
    ##  Defines a table used to select one or more signatures to apply to a message based
    ##  on the address found in the From: header field. In simple terms, this tells
    ##  OpenDKIM how to use your keys. Requires KeyTable be enabled.
    SigningTable    refile:/etc/opendkim/SigningTable
  7. pamamolf
    4,128
    5:31 PM
    Before your fix the script had commented this line at KeyTable:
    #default._domainkey.example.com example.com:default:/etc/opendkim/keys/default.private
    so i will have to test again now :)
    60,129
    12,590
    1:31 AM
    That's just a commented reference to remind me of the format for entries
  9. pamamolf
    4,128
    5:31 PM
    and this one also at SigningTable:
    #*@example.com default._domainkey.example.com
    I think both must be enabled to get signed emails from a domain or not?
    60,129
    12,590
    1:31 AM
    no they are commented as reference only
  11. pamamolf
    4,128
    5:31 PM
    Ok two last questions :)
    Actually the first one is to have a check for Postfix version and if it is < 2,6 version to use:
    milter_protocol = 2
    and if it is > 2,6 version to use:
    milter_protocol = 6
    and last one does it make any difference as i can see at:
    /etc/opendkim.conf
    Socket inet:8891@localhost
    but on:
    /etc/postfix/main.cf
    we use:
    smtpd_milters = inet:127.0.0.1:8891
    So is it better to adjust them to use ip or localhost both ?
    Thank you so much !!!!!
    60,129
    12,590
    1:31 AM
    Postfix before-queue Milter support
    Doesn't matter
    indeed a bug in opendkim.sh :)
  13. SFLC
    SFLC Active Member
    223
    59
    The Canadas
    5:31 PM
    This is too good to be true,
    spf, dkim, dmarc are things ive never understood for years and could never get working right especially with gmail, it's become a habit, everytime i email a friend i have to tell them to check their spam folders because my emails likely there.
    now with this addon its working right and all it took was a few button clicks
    i am now certain that @eva2000 is the most valuable man on earth, thank you!!
  14. Jimmy
    11:31 AM
    @eva2000 could this thread be moved to the addons forum? Lots of great info in this thread, shouldn't be in the github commits IMO.
    60,129
    12,590
    1:31 AM
    @Jimmy it's a commit if you see 1st post so should stay here :)
    i'll add a permanent redirect though
  16. Jimmy
    11:31 AM
    That's understandable. But if you look at the main commits forum, every other thread has 0 replies except this one which has 54. This is not your normal commit thread. It's become more of an addon thread, discussing the addon.
    Redirect works. Too bad you could just leave the first post and move the rest to the addons forum.
  17. SFLC
    SFLC Active Member
    223
    59
    The Canadas
    5:31 PM
    how do you rerun opendkim, i ran it from the addons and it installed and worked, however later on I installed dovecot and removed it and now my emails are not being signed, i tried rerunning from the addons folder but it goes back to the command prompt again so im not sure what its doing.
    do i have to delete the older keys and if so where are they stored
    60,129
    12,590
    1:31 AM
    You can clean up old runs with command
    addons/opendkim.sh clean
    then a new set of dkim and spf records are made
    60,129
    12,590
    1:31 AM
