Master Branch add VHOSTCTRL_CLOUDFLAREINC & VHOSTCTRL_AUTOPROTECTINC variables
Discussion in 'Centmin Mod Github Commits' started by eva2000, Apr 30, 2018.
    60,040
    12,571
    6:55 PM
    Add vhost control variables for VHOSTCTRL_CLOUDFLAREINC & VHOSTCTRL_AUTOPROTECTINC which respectively control whether at vhost creation time, the cloudflare.conf include file and autoprotect-vhostname.conf include files are uncommented (enabled) or commented out (disabled) by default. Variables default to VHOSTCTRL_CLOUDFLAREINC='n' & VHOSTCTRL_AUTOPROTECTINC='y' and be overridden via persistent config file /etc/centminmod/custom_config.inc in which you would set VHOSTCTRL_CLOUDFLAREINC='y' & VHOSTCTRL_AUTOPROTECTINC='n' if you wanted to enable cloudflare.conf include file and disable autoprotect include.
