Beta Branch acmetool.sh 1.0.14 fix for certonly-issue DNS mode renew routine
Discussion in 'Centmin Mod Github Commits' started by eva2000, Oct 26, 2016.
    55,797
    12,271
    11:15 AM
    addons/acmetool.sh DNS mode issuance for letsencrypt ssl certificates needed a minor fix for when you are issuing staging test ssl certs as it requires passing --staging flag to the --renew command in underlying acme.sh tool which acmetool.sh uses
    123.09beta01 branch
    55,797
    12,271
    11:15 AM
    test run of DNS mode via certonly-issue for acmedns1.domain.com and acmedns2.domain.com
    where i ran DNS mode issuance of staging test letsencrypt ssl certificate for just acmedns1.domain.com first and added the appropriate DNS TXT verification record and issued staging test letsencrypt ssl certificate.
    cd /usr/local/src/centminmod
    addons/acmetool.sh certonly-issue acmedns1.domain.com
    then re-ran it again to add acmedns2.domain.com to the same acmedns1.domain.com certificate for a SANs multi domain staging test letsencrypt ssl certificate
    addons/acmetool.sh certonly-issue acmedns1.domain.com,acmedns2.domain.com
    output for the re-run
    updating acme.sh client...
    [Wed Oct 26 03:22:51 UTC 2016] Installing to /root/.acme.sh
    [Wed Oct 26 03:22:51 UTC 2016] Installed to /root/.acme.sh/acme.sh
    [Wed Oct 26 03:22:52 UTC 2016] Installing alias to '/root/.bashrc'
    [Wed Oct 26 03:22:52 UTC 2016] OK, Close and reopen your terminal to start using acme.sh
    [Wed Oct 26 03:22:52 UTC 2016] Installing alias to '/root/.cshrc'
    [Wed Oct 26 03:22:52 UTC 2016] Installing alias to '/root/.tcshrc'
    [Wed Oct 26 03:22:52 UTC 2016] Installing cron job
    0 0 * * * "/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null
    [Wed Oct 26 03:22:52 UTC 2016] Good, bash is found, so change the shebang to use bash as prefered.
    https://github.com/Neilpang/acme.sh
    v2.6.2
    acme.sh updated
    [DNS mode] issue & install letsencrypt ssl certificate for acmedns1.domain.com
    testcert value =
    /root/.acme.sh/acme.sh --staging --issue --force --dns -d acmedns1.domain.com -d acmedns2.domain.com -k 2048 --useragent centminmod-centos7-acmesh-dns --log /root/centminlogs/acmetool.sh-debug-log-261016-032248.log --log-level 2
    [Wed Oct 26 03:22:53 UTC 2016] Using stage api:https://acme-staging.api.letsencrypt.org
    [Wed Oct 26 03:22:57 UTC 2016] Registering account
    [Wed Oct 26 03:23:05 UTC 2016] Already registered
    [Wed Oct 26 03:23:12 UTC 2016] Update success.
    [Wed Oct 26 03:23:12 UTC 2016] Multi domain='DNS:acmedns2.domain.com'
    [Wed Oct 26 03:23:12 UTC 2016] Verify each domain
    [Wed Oct 26 03:23:12 UTC 2016] Getting webroot for domain='acmedns1.domain.com'
    [Wed Oct 26 03:23:12 UTC 2016] _w='dns'
    [Wed Oct 26 03:23:12 UTC 2016] Getting new-authz for domain='acmedns1.domain.com'
    [Wed Oct 26 03:23:21 UTC 2016] acmedns1.domain.com is already verified, skip.
    [Wed Oct 26 03:23:21 UTC 2016] Getting webroot for domain='acmedns2.domain.com'
    [Wed Oct 26 03:23:21 UTC 2016] _w='dns'
    [Wed Oct 26 03:23:21 UTC 2016] Getting new-authz for domain='acmedns2.domain.com'
    [Wed Oct 26 03:23:29 UTC 2016] acmedns1.domain.com is already verified, skip dns-01.
    [Wed Oct 26 03:23:29 UTC 2016] Add the following TXT record:
    [Wed Oct 26 03:23:29 UTC 2016] Domain: '_acme-challenge.acmedns2.domain.com'
    [Wed Oct 26 03:23:29 UTC 2016] TXT value: 'CzmNS456s8mQu9cnWnOcRL4TEnChJl9ssyBRipmZubY'
    [Wed Oct 26 03:23:29 UTC 2016] Please be aware that you prepend _acme-challenge. before your domain
    [Wed Oct 26 03:23:29 UTC 2016] so the resulting subdomain will be: _acme-challenge.acmedns2.domain.com
    [Wed Oct 26 03:23:29 UTC 2016] Please add the TXT records to the domains, and retry again.
    [Wed Oct 26 03:23:29 UTC 2016] Dns not added, skip.
    [Wed Oct 26 03:23:29 UTC 2016] Please check log file for more details: /root/centminlogs/acmetool.sh-debug-log-261016-032248.log
     DNS mode requires manual steps below
     Once DNS updated for acmedns1.domain.com, run SSH command:
      /root/.acme.sh/acme.sh --force --renew --staging -d acmedns1.domain.com -d acmedns2.domain.com
     SSL certs will be located : /root/.acme.sh/acmedns1.domain.com
     If want to install cert into Nginx vhost, run SSH command:
      /root/.acme.sh/acme.sh --installcert -d acmedns1.domain.com -d acmedns2.domain.com --certpath /usr/local/nginx/conf/ssl/acmedns1.domain.com/acmedns1.domain.com-acme.cer --keypath /usr/local/nginx/conf/ssl/acmedns1.domain.com/acmedns1.domain.com-acme.key --capath /usr/local/nginx/conf/ssl/acmedns1.domain.com/acmedns1.domain.com-acme.cer --reloadCmd /usr/bin/ngxreload --fullchainpath /usr/local/nginx/conf/ssl/acmedns1.domain.com/acmedns1.domain.com-fullchain-acme. key
     SSL certs will be installed at : /usr/local/nginx/conf/ssl/acmedns1.domain.com/
    notice acmedns1.domain.com already verified from previous dns verification and is valid for 90 days so can be skipped
    so only acmedns2.domain.com needed adding a TXT DNS verification record
    once added and TXT DNS propagated, do 2nd step of issuing ssl cert as instructed in above text
    and output
    [Wed Oct 26 03:24:31 UTC 2016] Using stage api:https://acme-staging.api.letsencrypt.org
    [Wed Oct 26 03:24:31 UTC 2016] Renew: 'acmedns1.domain.com'
    [Wed Oct 26 03:24:36 UTC 2016] Registering account
    [Wed Oct 26 03:24:42 UTC 2016] Already registered
    [Wed Oct 26 03:24:50 UTC 2016] Update success.
    [Wed Oct 26 03:24:50 UTC 2016] Multi domain='DNS:acmedns2.domain.com'
    [Wed Oct 26 03:24:50 UTC 2016] Verify each domain
    [Wed Oct 26 03:24:50 UTC 2016] acmedns1.domain.com is already verified, skip dns-01.
    [Wed Oct 26 03:24:50 UTC 2016] Verifying:acmedns2.domain.com
    [Wed Oct 26 03:25:03 UTC 2016] Success
    [Wed Oct 26 03:25:03 UTC 2016] Dns not added, skip.
    [Wed Oct 26 03:25:03 UTC 2016] Verify finished, start to sign.
    [Wed Oct 26 03:25:13 UTC 2016] Cert success.
    -----BEGIN CERTIFICATE-----
    MIIFEjCCA/qgAwIBAgITAPr/ma3iGnBEZcJ5Ue7MwtZOzjANBgkqhkiG9w0BAQsF
    ADAiMSAwHgYDVQQDDBdGYWtlIExFIEludGVybWVkaWF0ZSBYMTAeFw0xNjEwMjYw
    MjI1MDBaFw0xNzAxMjQwMjI1MDBaMCQxIjAgBgNVBAMTGWFjbWV0b29sZG5zMS5o
    dHRwMnNzbC54eXowggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIBAQDBeE81
    7SgQPmcZN1NZ5Tuv6RHPWn/ezS3+rKiuYh8bcCxkGYpkjQFCLI367VBuNHaQHdiW
    sBV4vAO6pXV/XqraFbyRU/UswjG0uB6NyDkliEXBabcyKJXAkPLz+j2AT9ldWoh9
    SrM6DV0GwG0YvkZbulVocVdHeQom2yI89bs2xzMNQwKDrUpXv0l7L+EEBWfLmDu+
    SHQ0lOq+wqOEIwD4GPj1H94l9d4LxjnfoeVg7Y3UhTMVAcC5doSapIO/wghG5jfK
    EmW2zvtr4VSxJ21sKh6VsKBwyZ1imzih90sBbesrwqPeVBEPvRxO/3K9Fet9sW3B
    A4laxCenxq/g4PgRAgMBAAGjggI9MIICOTAOBgNVHQ8BAf8EBAMCBaAwHQYDVR0l
    BBYwFAYIKwYBBQUHAwEGCCsGAQUFBwMCMAwGA1UdEwEB/wQCMAAwHQYDVR0OBBYE
    FLXscKI40fsxyoljkahs7hanxklHHkhsknaxujakshaAFMDMA0a5WCDMXHJw8+Eu
    yyCm9Wg6MHgGCCsGAQUFBwEBBGwwajAzBggrBgEFBQcwAYYnaHR0cDovL29jc3Au
    c3RnLWludC14MS5sZXRzZW5jcnlwdC5vcmcvMDMGCCsGAQUFBzAChidodHRwOi8v
    KwYBBQUHAgEWGmh0dHA6Ly9jcHMubGV0c2VuY3J5cHQub3JnMIGrBggrBgEFBQcC
    AjCBngyBm1RoaXMgQ2VydGlmaWNhdGUgbWF5IG9ubHkgYmUgcmVsaWVkIHVwb24g
    YnkgUmVseWluZyBQYXJ0aWVzIGFuZCBvbmx5IGluIGFjY29yZGFuY2Ugd2l0aCB0
    aGUgQ2VydGlmaWNhdGUgUG9saWN5IGZvdW5kIGF0IGh0dHBzOi8vbGV0c2VuY3J5
    cHQub3JnL3JlcG9zaXRvcnkvMA0GCSqGSIb3DQEBCwUAA4IBAQBlHXsgil0JbbVy
    IxdeFErYOn9RXjqB7BymXXmrIY/0Np6C7G6VRp9mSqxgfaUJKS30Wmb45LDOIIQ2
    4BNOBQ5MS8OE56p85f0SOCFhE9/KKALOk5je3UPdkFvcsFJCXQ1DMbsKhxmFjYOT
    2acjmmIG5DsgV6DawkuY8Ilbrlc4mDwdeMLsUlHolcljzysgaAy6B36blL6WwaDA
    i042AHTR4dMj9wnsH+si8VQpSfDiB6heHGuCsXq8jy9DQaVE8h6HQ/4InKtIbI1P
    +ZQ8zy9i
    -----END CERTIFICATE-----
    [Wed Oct 26 03:25:13 UTC 2016] Your cert is in  /root/.acme.sh/acmedns1.domain.com/acmedns1.domain.com.cer
    [Wed Oct 26 03:25:13 UTC 2016] Your cert key is in  /root/.acme.sh/acmedns1.domain.com/acmedns1.domain.com.key
    [Wed Oct 26 03:25:15 UTC 2016] The intermediate CA cert is in  /root/.acme.sh/acmedns1.domain.com/ca.cer
    [Wed Oct 26 03:25:15 UTC 2016] And the full chain certs is there:  /root/.acme.sh/acmedns1.domain.com/fullchain.cer
    so
    • ssl cert available at /root/.acme.sh/acmedns1.domain.com/acmedns1.domain.com.cer
    • ssl cert private key at /root/.acme.sh/acmedns1.domain.com/acmedns1.domain.com.key
    • fullchain.cer for nginx at /root/.acme.sh/acmedns1.domain.com/fullchain.cer
    55,797
    12,271
    11:15 AM
    notice in initial certonly-issue run the instructions if you want to install the issued ssl cert to nginx vhost
    The nginx vhost = acmedns1.domain.com has to exist before you can run that --installcert command.
    You can use centmin.sh menu option 2 or /usr/bin/nv command line to create acmedns1.domain.com first as outlined at Nginx Vhost & NSD DNS Setup - CentminMod.com LEMP Nginx web stack for CentOS
    using nv command is easy in SSH type with -s y flag for self-signed ssl cert and https vhost generation
    nv -d acmedns1.domain.com -s -y -u YOURDESIRED_FTPUSERNAME
    or via centmin.sh menu option 2 and making sure to answer yes to self-signed ssl cert as that auto generates the https nginx vhost config file too
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    11). MariaDB 5.2/5.5 & 10.x Upgrade Sub-Menu
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Install/Re-Install
    24). Exit
    Enter option [ 1 - 24 ]
    one nginx vhost created, you can run the instructed command to install the DNS mode obtained letsencrypt ssl certificate
    this will install the letsencrypt ssl certificate files to /usr/local/nginx/conf/ssl/acmedns1.domain.com/ directory and you will need to edit your acmedns1.domain.com.ssl.conf vhost for these 3 lines which are the default generated self-signed ssl cert
      ssl_certificate      /usr/local/nginx/conf/ssl/acmedns1.domain.com/acmedns1.domain.com.crt;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/acmedns1.domain.com/acmedns1.domain.com.key;
      # enable ocsp stapling
      #resolver_timeout 10s;
      #ssl_stapling on;
      #ssl_stapling_verify on;
      #ssl_trusted_certificate /usr/local/nginx/conf/ssl/acmedns1.domain.com/acmedns1.domain.com-trusted.crt;
    to
      ssl_certificate      /usr/local/nginx/conf/ssl/acmedns1.domain.com/acmedns1.domain.com-acme.cer;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/acmedns1.domain.com/acmedns1.domain.com-acme.key;
      #ssl_stapling on;
      #ssl_trusted_certificate /usr/local/nginx/conf/ssl/acmedns1.domain.com/acmedns1.domain.com-acme.cer;
    then restart nginx
    You can uncomment the last 4 lines if using live letsencrypt ssl certificate but leave commented out if using staging test letsencrypt ssl certs as OCSP stapling isn't supported for test staging ssl certs.
      ssl_stapling on;
