Letsencrypt SSL acme ssl obtain ssl success but its invalid and not secure
Discussion in 'Domains, DNS, Email & SSL Certificates' started by R0rke, Jun 28, 2017.
  1. R0rke
    R0rke Member
    127
    Iran
    10:50 AM
    1.11.1
    10.1
    hi just installed centminmod 123.09beta01 recently with fresh os install and centmin setup + no any config or changes just set a dns zone NS For domains then add vhost with default option menu 2 note i enabled letsencrypt detect before :
    • CentOS Version: 7.0
    • Nginx Version Installed: 1.13.1
    • PHP Version Installed: 7.0.20
    • MariaDB MySQL Version Installed: dunno
    • When was last time updated Centmin Mod code base ? : never i just do fresh install 24 hours ago
    • Persistent Config: nothing at all
    • Code:
      cat: /etc/centminmod/custom_config.inc: No such file or directory
    simply i decide to os reload and install centminmod again . but before it i want to report this problem . thanks George
    37,687
    8,247
    4:50 AM
    • If you ran centmin.sh menu option 2 or 22, which letsencrypt option did you select from
      Enter vhost domain name you want to add (without www. prefix): acme3.domain1.com
      You have 4 options:
      1. issue staging test cert with HTTP + HTTPS
      2. issue staging test cert with HTTPS default
      Enter option number 1-4: 1
    Troubleshooting
      ls -lahrt /root/centminlogs
      ACMEDEBUG='y'
  3. R0rke
    R0rke Member
    127
    Iran
    10:50 AM
    1.11.1
    10.1
    i post some related ones as secret gist , i'l send u a private message . check please
    edit :
    i just double check my DNS Settings i doubt the problem is happening because of DNS but as u can see here screencapture-cp3-nicpanel-ca-domain-all-1498646026215.png i make child hosts and dns template on NSD With centmin Menu Option 3 . then set a custom display name server for my Domian like this :
    ns1.site.net
    ns2.site.net
    and here is the DNS Template :
    PHP:
    $TTL 14400
    @       IN      SOA     ns1.MyWebSiteAddressISFilterd.net.      hostmaster.MyWebSiteAddressISFilterd.net. (
    2010091500
                                                    14400
                                                    3600
                                                    1209600
                                                    86400
    Nameservers
    .net.       14400   IN      NS      ns1.MyWebSiteAddressISFilterd.net.
    MyWebSiteAddressISFilterd.net.       14400   IN      NS      ns2.MyWebSiteAddressISFilterd.net.
    A Records
    .net.       14400   IN      A       74.222.**.***
    ftp                     14400   IN      A       74.222.**.***
    localhost       14400   IN      A       127.0.0.1
    mail            14400   IN      A       74.222
    ns1                     14400   IN      A       74.222.**.***
    ns2                     14400   IN      A       74.222.**.***
    pop                     14400   IN      A       74.222.**.***
    smtp            14400   IN      A       74.222.**.***
    www                     14400   IN      A       74.222.**.***
    MX Record
    .net.       14400   IN      MX      10 mail
    TXT Record (for SPF)
    MyWebSiteAddressISFilterd.net.       14400   IN      TXT     "v=spf1 a mx ip4:74.222.**.*** ~all"
    MyWebSiteAddressISFilterd.net3600 IN DS 2371 13 2 6992cdc095c0b02a75fa2c287af2625ac7fe120c6f49bc7af42f4ff51edd225f
    37,687
    8,247
    4:50 AM
    Did you follow NSD example at Domains - Domain name DNS setup on local NSD server ? You need to register your vanity nameservers with your domain registrar before you can setup domain using vanity custom nameservers. Your domain DNS doesn't seem to be working check Global DNS Propagation Checker - What's My DNS? should return your server IP address for A records
    I suggest you use a 3rd party DNS provider instead of NSD i.e. Cloudflare Cloudflare - DNS - Cloudflare DNS Only Configuration
    But you managed to get your letsencrypt ssl cert successfully, so your DNS was working at time of issuance
    37,687
    8,247
    4:50 AM
  6. R0rke
    R0rke Member
    127
    Iran
    10:50 AM
    1.11.1
    10.1
    i set a custom a record with ns.site.net + my main ip address has been seted on nsd .
    but when i set the domains dns to NS1.SITE.NET + NS2.SITE.NET
    GIVES ERROR :
    There are no glue records for at least one of the provided name servers.
    37,687
    8,247
    4:50 AM
    need to contact your dns provider/domain registrar for help in setting up proper vanity custom nameservers
  8. R0rke
    R0rke Member
    127
    Iran
    10:50 AM
    1.11.1
    10.1
    if u mean you need to check i can provide username and password but there is another way i can secuss the connection . by making a child host .
    now i just need to place the nameservers and boom i can see the website loads .
    thing is i use this method on older versions i mean about month ago of centminmod beta
    but honestly i don't know what's happening right now . btw thanks for your fast replay i enabled this option i mean child hosts and just let see what's happening
    37,687
    8,247
    4:50 AM
  10. R0rke
    R0rke Member
    127
    Iran
    10:50 AM
    1.11.1
    10.1
    ok updated . i can see the domain now functioning as well !
    thanks for ur help i'l try to contact them later but it seems the problem solved ( about DNS )
    but we still have problem with obtaining SSL Cert
    37,687
    8,247
    4:50 AM
    There's generally 3 ways of setting up HTTPS SSL certificate for Centmin Mod Nginx HTTP/2 based HTTPS
    Method 1. The traditional way via centmin.sh menu option 2, 22 and selecting yes to self-signed ssl certificates first. Then converting the self-signed ssl certificate to paid or free (Letsencrypt) web browser trusted SSL certificates outlined at How to switch self-signed SSL certificate to paid SSL certificate ? You would still need to follow the same steps outlined at Nginx SPDY SSL Configuration for obtaining and purchasing the paid SSL certificate and most important part is the concatenation of the SSL provider provided filesto create the mentioned /usr/local/nginx/conf/ssl/domaincom/ssl-unified.crt and /usr/local/nginx/conf/ssl/domaincom/ssl-trusted.crtfiles referenced in your Nginx SSL vhost config file.
    You may need to also decide if you want to enable HTTP to HTTPS redirect outlined at How to force redirect from HTTP:// to HTTPS:// ?
    If you didn't answer yes at time of initial nginx vhost creation to self-signed ssl certificates, you can manually setup the self-signed ssl certificate via the vhost generator by checking self-signed ssl box and enter a domain name. This will outline instructions for manually creating and setting up self-signed ssl certificate and nginx vhost settings. Then for web browser trusted ssl certificates you switch follow - How to switch self-signed SSL certificate to paid SSL certificate ?.
    Method 3. Fully manual method for free Letsencrypt SSL certificates.
    So try one of the 2 application guides in method 3
    37,687
    8,247
    4:50 AM
    from your ssllab result, you selected letsencrypt test staging ssl certs and not live ssl certs hence untrusted
    You have 4 options:
    option 1 and 2 = test staging ssl certs
    you should select 3 or 4 for live trusted ssl certs
    following method for existing vhost outlined at Migrating Existing Nginx Vhost From HTTP to HTTP/2 based HTTPS With Letsencrypt SSL Certificates should fix it with live trusted ssl certs
  13. R0rke
    R0rke Member
    127
    Iran
    10:50 AM
    1.11.1
    10.1
    37,687
    8,247
    4:50 AM
