PHP-FPM 502 Bad Gateway Timeout HELP
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by skringjer, Apr 21, 2019.
  1. skringjer
    skringjer NoobMaster69
    208
    26
    9:06 AM
    Nginx 1.21.6
    One thing more i wanted to ask due to these errors
    nginx: [emerg] "fastcgi_connect_timeout" directive is duplicate in /usr/local/nginx/conf/php-mycustom.conf:19
    nginx: [emerg] "fastcgi_send_timeout" directive is duplicate in /usr/local/nginx/conf/php-mycustom.conf:19
    I removed the directives like fastcgi_connect_timeout and some others from /usr/local/nginx/conf/php-mycustom.conf
    Why did i face this issue? Cuz in the original php.conf these directives were present. but nginx restarted fine, i want to have them in mycustom.conf too
    60,089
    12,584
    2:06 PM
    Glad to hear :)
    60,089
    12,584
    2:06 PM
    did you comment out the old php.conf include file in nginx vhost ?
    post contents of /usr/local/nginx/conf/php-mycustom.conf
    cat /usr/local/nginx/conf/php-mycustom.conf
  4. skringjer
    208
    26
    9:06 AM
    Nginx 1.21.6
    Yes i commented that out
    # pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
        location ~ \.php$ {
            if (!-e $request_filename) { rewrite ^/(.*) /index.php?_page_url=$1 last; }
            fastcgi_pass 127.0.0.1:9000;
            fastcgi_index index.php;
            fastcgi_param MOD_X_ACCEL_REDIRECT_ENABLED on;
            include fastcgi_params;
    # might shave 200+ ms off PHP requests
    # which don't pass on a content length header
    # slightly faster page response time at the
    # expense of throughput / scalability
    #sendfile on;
    #tcp_nopush off;
    #keepalive_requests 0;
    fastcgi_connect_timeout 60s;
    fastcgi_send_timeout 180s;
    fastcgi_read_timeout 300s;
    fastcgi_buffer_size 512k;
    fastcgi_buffers 512 16k;
    fastcgi_busy_buffers_size 1m;
    fastcgi_temp_file_write_size 4m;
    fastcgi_max_temp_file_size 4m;
    fastcgi_intercept_errors off;
    # next 3 lines when uncommented / enabled
    # allow Nginx to handle uploads which then
    # passes back the completed upload to PHP
    #fastcgi_pass_request_body off;
    #client_body_in_file_only clean;
    #fastcgi_param  REQUEST_BODY_FILE  $request_body_file;
    #new .04+ map method
    fastcgi_param HTTPS $server_https;
    # comment out PATH_TRANSLATED line if /usr/local/lib/php.ini sets following:
    # cgi.fix_pathinfo=0
    # as of centminmod v1.2.3-eva2000.01 default is set to cgi.fix_pathinfo=1
    fastcgi_param  PATH_INFO          $fastcgi_path_info;
    fastcgi_param  PATH_TRANSLATED    $document_root$fastcgi_path_info;
    fastcgi_param  QUERY_STRING       $query_string;
    fastcgi_param  REQUEST_METHOD     $request_method;
    fastcgi_param  CONTENT_TYPE       $content_type;
    fastcgi_param  CONTENT_LENGTH     $content_length;
    fastcgi_param  SCRIPT_NAME        $fastcgi_script_name;
    fastcgi_param  REQUEST_URI        $request_uri;
    fastcgi_param  DOCUMENT_URI       $document_uri;
    fastcgi_param  DOCUMENT_ROOT      $document_root;
    fastcgi_param  SERVER_PROTOCOL    $server_protocol;
    fastcgi_param  REQUEST_SCHEME     $scheme;
    fastcgi_param  HTTPS              $https if_not_empty;
    fastcgi_param  HTTP_PROXY         "";
    fastcgi_param  GATEWAY_INTERFACE  CGI/1.1;
    fastcgi_param  SERVER_SOFTWARE    nginx/$nginx_version;
    fastcgi_param  REMOTE_ADDR        $remote_addr;
    fastcgi_param  REMOTE_PORT        $remote_port;
    fastcgi_param  SERVER_ADDR        $server_addr;
    fastcgi_param  SERVER_PORT        $server_port;
    fastcgi_param  SERVER_NAME        $server_name;
    # Set php-fpm geoip variables
    fastcgi_param GEOIP_COUNTRY_CODE $geoip_country_code;
    fastcgi_param GEOIP_COUNTRY_CODE3 $geoip_country_code3;
    fastcgi_param GEOIP_COUNTRY_NAME $geoip_country_name;
    fastcgi_param GEOIP_CITY_COUNTRY_CODE $geoip_city_country_code;
    fastcgi_param GEOIP_CITY_COUNTRY_CODE3 $geoip_city_country_code3;
    fastcgi_param GEOIP_CITY_COUNTRY_NAME $geoip_city_country_name;
    fastcgi_param GEOIP_REGION $geoip_region;
    fastcgi_param GEOIP_CITY $geoip_city;
    fastcgi_param GEOIP_POSTAL_CODE $geoip_postal_code;
    fastcgi_param GEOIP_CITY_CONTINENT_CODE $geoip_city_continent_code;
    fastcgi_param GEOIP_LATITUDE $geoip_latitude;
    fastcgi_param GEOIP_LONGITUDE $geoip_longitude;
    # PHP only, required if PHP was built with --enable-force-cgi-redirect
    fastcgi_param  REDIRECT_STATUS    200;
  5. skringjer
    208
    26
    9:06 AM
    Nginx 1.21.6
    if i remove all of these
    Then mycustom.php works otherwise nginx dosent restart.
    60,089
    12,584
    2:06 PM
    duplicate errors are due to you including fastcgi_params file as centminmod php.conf and your custom copy already has all fastcgi_params and additional settings added natively in the file
    so comment out this fastcgi_params include file and re-enable/uncomment all the settings you commented out
  7. skringjer
    208
    26
    9:06 AM
    Nginx 1.21.6
    Thank you very much eva, everything is perfect, optimized and secure, i am just running some final tests now.
    1 Thing, why is the the upload and download speed not going above 40 Mbs? though i have 1 Gbits uplink both on the server and on my PC.
    Is there some os tuning required?
    60,089
    12,584
    2:06 PM
    depends on speed of your web host provider's network/peering and geographic distance between you and your server too. 1Gbit uplink is just that a physical link - what your real speed is depends on your web host and it's upstream connectivity relative to your geographic location. There's also underlying disk I/O performance of your server as download/uploads will read/write to disk.
    60,089
    12,584
    2:06 PM
    Oh as you were using PHP 7.3.4, your 502 might be related to a PHP 7.3.4+ bug which I backported a fix from yet to be released PHP 7.3.7. So you can try updating 123.09beta01 via cmupdate and then re-run centmin.sh menu option 5 to recompile current PHP 7.3.5 release - though PHP 7.3.6 is available too and officially announced in 2-3 days from now Beta Branch - backport PHP 7.3.7 due bug fix into PHP 7.3.4-7.3.6 in 123.09beta01
